Spike38
Joined: 29 May 2008 Posts: 63 City/Region: Punta Gorda
Posted: Tue Jul 22, 2008 10:31 am Post subject: Depth transducer location? |
I'm planning to install a Garmin plotter/sounder combination, am deliberating on transducer location and wondering what the arguments are for and against transom mount vs. thru-hull aside from the thru-hull presumably being more effectively located. There's also the "shoot through the hull" possibility but not recommended in cored hulls as I understand it (though I've seen one C-Dory with transducer inside the hull). This last would be ideal - no holes - if it worked, but evidently accuracy becomes questionable. Any and all opinions on transducer location/installation will be appreciated. Also, I note that one member regrets not using a "mounting block" for his transom mount transducer. How would this be used? Should I use this method if I decide on a transom location? Thanks. |
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
Posted: Tue Jul 22, 2008 2:28 pm Post subject: |
Theres a thread somewhere on here about mounting transducer to a block rather than directly to your hull. Typically the blocks are made of starboard or cutting board material and attached to the hull with two screws. Mounting holes being overdrilled and epoxy filled. The advantage to this is replacing the transducer from time to time or moving them around or adding a second you don't wind up with mulitple holes in your transom. In my case I added a water speed wheel and may soon change my transducer. I noticed the other day that Gander mountain is selling a piece of material just for this. It's about 9 inches long and maybe three inches wide and 3/4 inch thick and comes with holes in either end plus mounting screws. The starboard I had on hand was only 1/2 thick and I laminated two pieces of it together using 5200 and wasn't happy with the result so I mounted directly to the transom. Advantage to the block is you can adjust, replace or add transducer to the mounting block. _________________ marvin |
Jack in Alaska
Joined: 17 Aug 2004 Posts: 1191 City/Region: Anchorage/Ninilchik
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
Posted: Tue Jul 22, 2008 5:38 pm Post subject: Transducer mounting |
When mounting my Hummingbird Matrix 37 transducer years ago I made an adjustable mount that can be controlled/adjusted from inside the boat while on the water. It works very well and also allows the whole thing to slide up out of harms way when beaching the boat if it should set down on a rock etc..
I have the transducer and the temp/speed sensor side by side on it.
Just recently I acquired a Garmin plotter/sonar and it has a separate transducer and want to keep both depth sounders operational. I am contemplating removing the speed/temp sensor and mounting the new transducer in it's place. As there is not enough room I may try "gluing" the speed/temp sensor directly to the hull with 5200.
I made it out of 1/4" Lexan and cut the pieces on a table saw very carefully. Lexan is unbreakable and extremely durable unlike acrylic.
Cut one piece 25" long and 5" wide. mounting piece
Cut 2 pieces 17" long and 3/4" wide. spacer pieces
Cut 2 pieces 17" long and 1" wide. capture strips
The 1" piece goes on top of the 3/4" piece with the excess towards the center "capturing" the wide piece. I drilled through the two pieces top and bottom and into the transom and screwed (using 1 1/4" No.10 stainless screws) them to the boat sealing all with 5200. Put a stainless washer behind the double strips to allow space for the wide piece to go up/down. Keep the double strips approx. 3" from the boat bottom as this will allow the full 5" of the mounting piece to accept sensors and still move up and down.
I drilled 1/8" holes as close together as possible in a vert. line above the top of the transom in the 5" piece so it can be adjusted in small increments and stopped with a small screw in the appropriate hole. I put a handle on top to be able to pull/push it up/down.
It has been on my boat for over 20 yrs. and shows no signs of any deterioration. It works really slick.
Hopefully this is not too confusing as it is really a simple thing. _________________ On the HIGH TIDE-II, wife Carolyn and I.....Another summer fishing on the HIGH TIDE II in the Cook Inlet at Cape Ninilchik, Alaska.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Bare hull & trailer sold in Nov. |
Posted: Tue Jul 22, 2008 5:56 pm Post subject: |
Jack-
Sounds like quite an inventive solution!
I found the following photo in your album. Would it be possible to get a close up for all to see?
breausaw
Vessel Name: Triple J
Photos: Triple J
Posted: Tue Jul 22, 2008 8:35 pm Post subject: |
If I had to do it over I’d seriously look at trying an in-hull transducer mounted in the aft bilge, I believe this section of the hull is solid fiberglass. _________________ Jay
matt_unique
Vessel Name: Napoleon
Photos: Napoleon
Posted: Tue Jul 22, 2008 10:18 pm Post subject: Shoot thru hull |
You'll have to check with C-Dory about the C-25, but the Tomcat is built with a solid square area toward the stern that has no coring for shoot thru hull transducers. I installed one of these and it works great! I would personally avoid drilling like The Plague. There are several good solutions using starboard and such but they also involve drilling.
Good luck. _________________ Captain Matt
Former owner of Napoleon (Tomcat) Hull #65 w/Counter Rotating Suzuki 150's. |
Jack in Alaska
Posted: Wed Jul 23, 2008 3:20 pm Post subject: double transducers???? |
Before I install a 2nd transducer right next to my present one I need to ask............
will they interfere with one another in operation causing both to give bad data????
Thanks |
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
Posted: Wed Jul 23, 2008 3:46 pm Post subject: Re: double transducers???? |
Jack in Alaska wrote: | Before I install a 2nd transducer right next to my present one I need to ask............
Thanks |
Unfortunately, yes. I went through the whole investigation thing trying to figure out how to get a second fishfinder at my aft helm also. In the end I installed a mount for a 2nd Raymarine display there so that display can migrate back and forth between the cabin and the cockpit. I use a shoot-through transducer just as Matt described.
M/V Lori Ann
Anacortes, WA
Posted: Wed Jul 23, 2008 5:28 pm Post subject: |
Warren's second display unit on the same basic unit is an easy logical solution, providing you don't want two diffeent types of units.
Hee's an edited set of posts from another recent thread:
Posted: Sun Mar 09, 2008 2:37 pm
I've been told that running multiple transducers won't work due to signal interference between the units. Is this not the case? I have thought about adding a second 'ducer, but was concerned that it wouldn't work.
-Rod
flrockytop wrote:
My cd19 had a Lowrance on it when I bought it. I added a Navman. Both are 50/200 machines. The Lowrance transducer is mounted on the stern I first tried shooting the Navman transducer through the hull. This did not work so well. When running both on 200, the signal from the Lowrance would sometimes overpower the Navman so much that it would not pick up at all. If I turned on the Navman first then, usually, they would both work. Even then I would pickup some sawtooth interference lines in the Navman display. I could run one on 50 the other on 200 and they would work. I moved the Navman transducer to the stern on the other side of the motor (about 2 feet apart). At this location they both will work.
I have used two at the same time on other boats with similar results.
Sometimes they will work and sometimes they won't. When widely spaced in shoal water, they will work OK. If the transducers/sounders are significantly different frequency, they will work.
If they are both the same frequency and close together, they will probably not work.
Unfortunately almost all of the fathometers use 200 mhz transducers currently. There used to be 215, 192, 200 etc...There is a Garmin at 235 (I belive)--but it will cost $500 with the head and transducer.
Bob
Full text HERE
Joe:  |
Spike38
Posted: Thu Jul 24, 2008 1:39 pm Post subject: |
Thanks for the good ideas! Matt and Doryman, how did you discover the solid uncored hull section was there - and its location? I haven't received the 25 manual yet but am not expecting that kind of detail even if such a hull area exists in the boat. |
breausaw
Photos: Triple J
Posted: Thu Jul 24, 2008 2:25 pm Post subject: |
Something I saw the other day while waiting to go through the Whittier tunnel was the transducer mounted on a trim tab end; was going to talk with the guy but the light went green. I’ve been holding off on mounting the paddle wheel that came with my fishfinder but now thinking of attaching it to one of my tabs.
The boat I saw was a high-end off-shore aluminum class vessel so this retrofit must have work ok for the guy. |
matt_unique
Photos: Napoleon
Posted: Thu Jul 24, 2008 2:50 pm Post subject: Location |
Spike38 wrote: | Thanks for the good ideas! Matt and Doryman, how did you discover the solid uncored hull section was there - and its location? I haven't received the 25 manual yet but am not expecting that kind of detail even if such a hull area exists in the boat. |
In my case I heard about it from other C-Brat's and Frank Walters from C-Dory. It definitely not obvious unless you are looking very closely. I knew exactly where to look and it still took me a while to find it.
The manuals provide some good information, but they are also riddled with errors and completely false information (i.e. capacities, weights, warranty in some cases, etc.) |
Joined: 07 Nov 2003 Posts: 7932 City/Region: marysville
Posted: Thu Jul 24, 2008 4:52 pm Post subject: |
I would be worried about putting a transducer on the trim tab as it would give a false depth if it is tilted. It has to be pointed straight down to get a correct depth. in a hundred feet of water a twenty degree angle on you trim tab could add 20 ft or more to your depth (just guessing so put the slide rule away joe) Also at speed you will have a lot of air and turbulence coming under the tab from the boat so you will not get a good signal if you get one at all. only at slow speed would you get a reading. Just what I have seen on other boats. I have seen a lot of transducers on trim tabs and it reminds me that "just because you can does not mean you should" _________________ Thomas J Elliott
Sawdust
Joined: 01 Nov 2003 Posts: 1400 City/Region: Oak Harbor
C-Dory Model: 22 Classic
Photos: C-Salt
Posted: Thu Jul 24, 2008 7:37 pm Post subject: |
Tom,
You are probably right on the 20 degrees - but I ran with the ducer on one of the trim tabs for years. Really liked it and may do it again. Because, using about 200 KC, the transmitted signal is pretty broad I didn't notice much error. Got good arches (dunno why)... and I could easily adjust it to see my balls (Don, no!!)... best drop this !!!
Duster _________________ 1984 22 Classic |
Wandering Sagebrush
Joined: 21 Jan 2005 Posts: 2783 City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
Posted: Thu Jul 24, 2008 8:20 pm Post subject: Transducer Mount |
I have seen a transducer that was mounted on a sailboat genoa track and car. The owner lifted the transducer out of the water when he was moored. It kept the transducer clean and out of harms way.
Steve |
