Sea Angel
Joined: 29 Dec 2003 Posts: 736 City/Region: Virginia Beach, VA
Photos: Sea Angel
Posted: Mon Jul 28, 2008 5:01 pm Post subject: Search Lites |
Has anyone had any experience with mounting a remote search lite on
the brow of a CD25? Sea Angel has a roof mounted (with small wedge)
4KW RADAR. I do have height restrictions for storeage in my marina.
I have tried a 'dummy' lite on the bow rail but it seems to block too much
of my field of view.
If I mount the lite on the roof, I think it will give a 'soft' sector for my
radar view and I don't know what the radar would do to the lite controls
that may be in its head assembly.
Suggestions? Maybe a wedge mount on the brow to allow a lower
placement of the lite base, but high enough to open the center window? I
don't know what the cosmetics would look like. I do have a handheld spot.
Art _________________ Art ka1rx
CBRAT #208
USCGAUX (RET), USN(RET)
Broadcast TV ENG(RET)
ka1rx@verizon.net
SKYPE: Art.Bartlett4 |
Posted: Mon Jul 28, 2008 8:42 pm Post subject: |
Art-
Difficult problem!
How about a half height (or so) mount between the bow roller and the top of the bow rail to keep it down as much as possible but still forward of the bow rail and it's potential blinding reflections?
A railmaker could bend a tube to fit in there and weld a S. S. plate to it.
Might be useful to mount other things on, too.
Sea Angel
Photos: Sea Angel
Posted: Mon Jul 28, 2008 9:34 pm Post subject: |
Hi Joe,
Thanks for the idea. I will have to get my dummy lite 'thingy' and
see how line-of-site is impacted. I don't think I even considered
this approach due to the proximity of the Delta anchor and rigging, but
worth a better look.
There is a spray we used in the TV studio, like an acrlyic spray, that
dulled the chrome on the studio set. I don't know if this would prevent the
type of glare that would impact the night vision. I could also wrap the rails
with a decorative wrap of nylon twine/line. The white line would go with
the hull color; even paint it like the boatswain mates did in the navy. This
may allow for a cabin "top" mount.
Art |
Posted: Mon Jul 28, 2008 11:14 pm Post subject: |
Art- Except for the cosmetic factor, mounting the light on top of the radar dome would keep it above and out of the way of everything. A screwy idea, perhaps, but it would satisfy the "no conflict" problems. The small wires would not interfere with the radar, as mastlight poles don't either. (Too small and too close.)
Joe.  |
DaveS
Joined: 01 Nov 2003 Posts: 3204 City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
Posted: Mon Jul 28, 2008 11:23 pm Post subject: Re: Search Lites |
Sea Angel wrote: |
Art |
Hi Art,
On the second page of my photo album is a pix of the search light mounted on the bow rail of Sea Shift. Les of EQ marine installed this one for me (he also installed one on Da Nag at the same time).
I have never noticed an obstructed field of vision due to its' presence. (Great,....now that you've mentioned it, I'll probably begin to notice it.... ). This "set up" has proved to me to be a very efficient and beneficial location.
Les, welded a flat plate to mount the "Go Light" on and it is hardwired to the cockpit and also has a handheld remote control for operating away from the helm.
On my former 16', I had a Go Light mounted on the roof and yes there was glare from the bow pulpit. _________________ Dave S.
"Sea Shift"
C-Brat #16 |
Joined: 01 Mar 2005 Posts: 7484 City/Region: from island boy to desert dweller
Posted: Mon Jul 28, 2008 11:43 pm Post subject: |
Perhaps not the solution you are looking for, but we use a portable magnetic base light on Wild Blue. It "sticks" on the anchor roller and I run the 12v cord back to the helm. No, it's not an elegant, permanent light; but we find we don't do a lot of running at night. It's easy and fast to stick on, and out of the way the rest of the time. We also use a hand held gazillion-watt light to find nav aids and check that there is nothing floating in front of us... yep, the arm out the window.
Jim B. |
Posted: Tue Jul 29, 2008 12:15 am Post subject: Search Lites |
Art, It has been discussed here some before, but I didn't find the thread, about spot lights and mounting positions and back glare, from having the light mounted where it lights up the light colored portions of the boat and the glare affecting the night vision. I carry a hand held spot light but have never used it. Until this last week, I have never been underway at night, in the dark. I can tell you that just the brightness from the C-120 plotter display, turned on in the night light mode, still made enough glare on the windows that it was hard to distinguish outside detail. I wound up opening the center window, standing in the center and looking out through the open wind to be able to see to steer. My opinion, (and that just what it is [$0.02]) is that unless a search light was mounted forward far enough to not light up the boat at all it would only make things harder to see, not easier. One caveat, if it could be coned down (to a very narrow beam) so that it did not light up the boat it may work to mount it farther aft than the bow pulpit rail or such. _________________ Though in our sleep we are not conscious of our activity or surroundings, we should not, in our wakefulness, be unconscious of our sleep. |
Dora~Jean
Joined: 09 Mar 2004 Posts: 1515 City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
Posted: Tue Jul 29, 2008 12:20 am Post subject: |
I could only find one picture in my album that shows my installation, I put it just above the brow on the slanted forward section of the roof, just in front of the radar. No noticeable effect on the radar. I do get reflections from the bow railing at night which can be eliminated with removable black pipe insulation. This location works pretty good for me.
When installing, make sure you mount it far enough aft to not interfere with the anchor/nav light pole. No noticeable effect having the pole in front of the anchor light either.
. _________________ Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
+4 Previous, 1/2 sail, 1/2 power |
Dene
Vessel Name: Fear Naut & Terra-Sea-Ta
Posted: Tue Jul 29, 2008 1:17 am Post subject: |
Art,
I bought a boat with the search light on the cabin as shown by the pictures. Good place to mount but I see little value in the thing. I think a more valuable light is a portable, rechargeable 5000 candlelight flashlight. Store it and pull it out as needed.
My two bits.
-Greg |
Dora~Jean
Photos: Dora~Jean
Posted: Tue Jul 29, 2008 10:51 am Post subject: |
Greg,
I thought the same way a couple of years ago, used my handheld. But after having the remote controlled spotlight, it is a real blessing. When you're trying to manuever and avoid objects while working twin engines, it's difficult to pick up a spotlight. Also difficult to tell a crew member to look "over there", then "over here", then straight ahead about every 10 seconds. I haven't used it much, maybe 3 times per year, but I really appreciate it when I need it. My 2c. |
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
Posted: Tue Jul 29, 2008 11:37 am Post subject: |
While browsing for magnetic remote spotlights I found this universal rail mount which looks quite substantial. The same company has a multitude of spotlights, a few with magnetic bases.
M/V Lori Ann
Anacortes, WA
Cosmic C
Joined: 10 Feb 2004 Posts: 97 City/Region: St Lawrence River & Bucks Cty
State or Province: NY
Vessel Name: Cosmic C
Photos: Cosmic C
Posted: Wed Jul 30, 2008 11:09 am Post subject: |
There are a couple of pictures of our bow-rail mounted spotlight in our album. We've never had a problem with visibility (it sits above the line of sight) and having t far forward eliminates annoying reflections and glare. |
Posted: Wed Jul 30, 2008 1:39 pm Post subject: |
Here's Cosmic C's bow light:
The off-center bow rail was replaced.
and mine on Sea Wolf:
I don't find it offensive, either, and it works best right there!
Joe.  |
Bad Boy
Vessel Name: Cat Fever
Photos: Cat Fever
Posted: Wed Jul 30, 2008 2:48 pm Post subject: Spotlight |
I have had several boats with spotlight at various locations. The best location that I experienced is on the bow rail. Any spotlight aft of the bow rail invariably shows up as a glare on the rails or on the white of the foredeck.
On my new Tomcat, I chose not to have any spotlight at all, choosing to use the portable handheld, instead. Mounting on the front bow rail looked like it would block my line of sight. I also have the cockpit steering station, so I can take my spotlight to the outside steering station. Generally, I only use the spotlight in short bursts and a handheld enables me to quickly shine it quickly in the direction I want without waiting for the rotation. |
Joined: 02 Nov 2003 Posts: 21468 City/Region: Pensacola
Posted: Wed Jul 30, 2008 7:36 pm Post subject: |
I also use hand held both corded and rechargable spotlights (1 million to 2 million CP). I have owned several boats with permently mounted remote controled spotlights--and although they are handy, those on the roof have enough back light scatter to ruin the night vision. Also the bow railing mount is very good, or a low deck mount on the bow--but this often is obscured by the anchor/and causes back reflections.
We also have a "Tractor" flood light/spotlight, with a mag mount, and it mounts very nicely on the Delta anchor. Generally one does not run spotlights for prolonged times--just to highlight items.
Our current favorite light is a Vector, three power, 1 mill cp,(Vector 1555CLFW) it is about 4" diameter, has a pistol grip and three different brightnesses--controlled by the number of trigger pulls. The low power is sufficient to spotlight what we need in 90% of cases when we need a spotlight (which is not very often). We have many of thousands of hours of night cruising, and the use of a spotlight has been in the dozens of times max.
I cannot over ephasize the value of retention of night vision. It will allow you to see that dim running light or a boat against the background lights or stars etc. _________________ Bob Austin
