Operating Tempature of Ranger 21
dmcinfo
City/Region: sacramento, ca
PostPosted: Sat Jun 28, 2008 10:08 pm    Post subject: Operating Tempature of Ranger 21 Reply with quote
After warm up, what should the operating temperature of the motor be? 2006 Ranger 21 EC.
2006 Ranger EC 21
Ron Cowan
City/Region: Athens
State or Province: AL
C-Dory Year: 1985
C-Dory Model: 22 Classic
Vessel Name: Elk-Tenn
Photos: Elk-Tenn
PostPosted: Sun Jun 29, 2008 8:24 am    Post subject: Reply with quote
Does your 21EC have an actual temperature guage? I have the last 2006 21 built before they changed to the EC and mine does not have a guage. It only has the alarm, which is sensitive. A couple of time the water strainer became partially blocked and the alarm sounded at once. I have considered adding a guage because I have always had a concern with idiot lights and alarms only. Want to see a number even though the signal comes from the same place. Just feel when a number does not look right you check more than waiting on a signal that may not be working.
Ron
Ready to go with the '85 22' Classic
C-WEED
City/Region: New Brockton
Vessel Name: C-Weed
Photos: C-WEED
PostPosted: Sun Jun 29, 2008 6:00 pm    Post subject: Reply with quote
For peace of mind. Try a good quality infared/lazer thermometer. It will give an accurate reading. Find out what thermostat temperature is used. Then with the engine up to operating temp take a reading at the thermostat housing. The temp should be very close to the thermostate setting.
The same can be done with the temp alarm system. Find out what temp it should alarm and then monitor temps both before and after it alarms. You might just have a sensor that trips to early. Or might have flow troubles.
You can also take a reading at the hose inlet and outlet of the radiator (if your boat is a closed system) to get an idea of the cooling effect of the radiator. Once you get an idea of what normal readings are at variouse locations on the engine, you can then determine when cooling issues arise.
Chris
Page generation time: 0.0383s (PHP: 38% - SQL: 62%) - SQL queries: 16 - GZIP disabled - Debug on
