Wandering Taco Meter
Forty Two
City/Region: Prince William Sound
C-Dory Year: 2017
Vessel Name: Black Cat
Photos: Barrel O Monkeys
PostPosted: Sat Jun 21, 2008 8:47 pm    Post subject: Wandering Taco Meter Reply with quote
My Tomcat has twin Honda 90s, with a bit over 500 hours each. First trip out this year, the port Tachometer started acting up - sometimes reading higher than the starboard meter, even though the engines were running the same speed - as far as I could tell by sound and vibration and throttle position. Any ideas why this might happen and any ideas about how to fix it? I really don't want to trailer the boat all the way back to the dealer. Summer is short and I really need my boat to be in the water instead of sitting in the dealers yard for the next 6 weeks.[/i]
John & Susan
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Sat Jun 21, 2008 9:25 pm    Post subject: Reply with quote
fishbob,
Hope you can get it fixed easily, but I wouldn't lose any short summer fishing time on it. If your other tach is working, just set the throttles even and keep on fishing-fix it in the fall.
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
PostPosted: Sat Jun 21, 2008 9:33 pm    Post subject: Reply with quote
On Journey On, the tach (Honda 150) started reading low and wandering. Someone posted that the fix was to hit the tach. Did that once or twice and hasn't done it since. Guess you have to show it who's boss.
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Sun Jun 22, 2008 12:50 am    Post subject: Reply with quote
My guess would be a bad ground on the meter. Check all your connections.
Gary Johnson
KB7NFG
Forty Two
C-Dory Year: 2017
PostPosted: Sun Jun 22, 2008 2:46 am    Post subject: Reply with quote
Got it -
Whack it.
Check the wiring,
Then ignore it.
Simple, cheap, and keeps me fishing.
Thanks.
jhwilson
City/Region: Mitchell County
Vessel Name: Placid C
Photos: Placid C
PostPosted: Sun Jun 22, 2008 8:55 am    Post subject: Reply with quote
My 2002 Honda 90 did this a couple of years ago, started reading 1200 to 1500 high. I tapped on the RPM gauge glass and the needle fell back to normal. I learned this from the pilot's in old movies. It has happened a couple of times since and I have tapped with the same result. I'll check the ground one of these days.
Just kidding about the old movies.
Harper
Pat and Harper, Mitchell County, NC
Tom on Icarus
City/Region: Campbell River, Vancouver Island
Vessel Name: Tranquil~C
Photos: Tranquil~C
PostPosted: Sun Jun 22, 2008 9:07 am    Post subject: Reply with quote
I too have had my tach wander and I too give it a good couple of raps with my knuckle.........problem solved.
Tom
Fairbro
City/Region: Prescott
Vessel Name: Minnie Swann
Photos: Minnie Swann
PostPosted: Sun Jun 22, 2008 10:09 am    Post subject: Reply with quote
Did you check your battery connections to that motor? I had identical symptoms and a loose battery cable was the problem. Tighten with a wrench. As a result of ignoring it I had to replace the charging coil in the motor.
It's something in the water!
PostPosted: Sun Jun 22, 2008 11:22 am    Post subject: Reply with quote
The most common cause is loose/corroded connections. As suggested, use hex nuts, instead of wing nuts (or at least use a wrench to tighten the wing nuts on the battery--clean all of the terminals, and use a contact cleaner on any large motor bundle connectors--then use a corrosion block to keep them clean/free of corrosion. Putting motor handles at the same position may not work, because of difference in linkage adjustment.
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Mon Jun 23, 2008 1:42 am    Post subject: Re: Wandering Taco Meter Reply with quote
Wandering Taco's??? There aint no stinking Taco's Mr. Green Beer Laughing Laughing
Fairbro
PostPosted: Mon Jun 23, 2008 10:57 am    Post subject: Reply with quote
Before I solved my whacky tachy problem I syncronised my motors by watching the center plume where the wakes from the motors meet. Keep it in the center of the transom and you are pretty much OK. Watch it swing either way when you make adjustments to just one throttle.
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Wed Jun 25, 2008 8:25 pm    Post subject: tach. wandering Reply with quote
I have had the same problem on my tach. on my 90 Honda. When inquiring at the Honda shop about a new tach. he asked if I had pushed the reset button on the back of my tach. I did not know there was one. So.I pushed it several times and the tach. has been perfect since. ???????? I am just passing on what happened.
Hope it helps.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Jack in Alaska
PostPosted: Sun Sep 07, 2008 5:05 pm    Post subject: "taco" problem Reply with quote
After 2 1/2 months & 60 hours since pushing the button on the back of the tach. it is still steady and true. (>:}
Don't ask me why but it worked.
PostPosted: Mon Sep 08, 2008 2:48 pm    Post subject: Wandering taco meter Reply with quote
And here I was thinking that a "Wandering Taco Meter" was some new device to let me know when the Mexican deli truck was getting close so I could calibrate my time clock. Embarassed
Page generation time: 0.0667s (PHP: 53% - SQL: 47%) - SQL queries: 31 - GZIP disabled - Debug on
