Davit & puller
Alasgun
Guest
PostPosted: Sat May 10, 2008 9:40 am    Post subject: Davit & puller Reply with quote
Having completed the puller / davit project, I thought some of you would appreciate some photos. Their in the cockpit & accessories forum (detail photos), eat your heart out!
Mike on Huda Thunkit
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Sat May 10, 2008 11:28 am    Post subject: Reply with quote
Your link to your photo album is locked (at least to me!), requires some sort of LOG IN which I'm unaware of. Anybody else have this problem?
"Attention!
The album or photo that you were attempting to view either does not exist, or requires user privileges that you do not possess. Log in and try again."
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
C-Hawk
Vessel Name: C-Hawk
Photos: C-Hawk
PostPosted: Sat May 10, 2008 11:40 am    Post subject: Reply with quote
That is one nice setup. The pics start here
2008- CD22- "C-Hawk" Sold
KJ6VVB
A Brat I am, At sea I be
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Sat May 10, 2008 11:48 am    Post subject: Reply with quote
It was locked for me as well but I was able to access it through the link C-Hawk posted. Thats indeed one nice set up. What make is it? It blends into the boat well.
marvin
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Sat May 10, 2008 3:32 pm    Post subject: Reply with quote
It must have corrected itself-I just check the pix and it worked fine. Great job Mike.
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
PostPosted: Sat May 10, 2008 9:16 pm    Post subject: Reply with quote
Yes, Mike's link gave me a message that said it either didn't exist or I did not have sufficient privileges, and then sent me to a login page too...
"Attention!
PostPosted: Sat May 10, 2008 9:17 pm    Post subject: Reply with quote
Ken - not working for me at 6:20 p.m., not sure what the deal is...
PostPosted: Sat May 10, 2008 9:21 pm    Post subject: Reply with quote
Yes, this worked for me too - opened in a new tab. How did you get in, Roger? Mike's link is keeping at least some of the rest of us out! Mike - good work!
Alasgun
Guest
PostPosted: Sat May 10, 2008 9:26 pm    Post subject: Davit / Puller Reply with quote
What part of GO TO COCKPIT & ACCESSORIES then click on DETAIL PHOTOS aren't you guys getting? Or just use the link provided by C-hawk.
Mike
blackfish
City/Region: saltair
Vessel Name: raincoast
Photos: Raincoast
PostPosted: Sat May 10, 2008 9:59 pm    Post subject: Reply with quote
very nice setup !
those electra-dyne pullers are pricey, did you make the davit?
C-Hawk
Vessel Name: C-Hawk
Photos: C-Hawk
PostPosted: Sun May 11, 2008 12:43 am    Post subject: Reply with quote
Go to the Forums page and scroll down to the Library section, Cockpit and Accessories, page 3 of the detail photos.
Very simple-- in the left column on the Home Page, under "Recent C-Dory Photo Activity" I saw where Mike had posted a recent photo- clicked on that link and --- viola--- there they were.
I got the same message as everyone else when I clicked on his photo link in his profile. He did not post the pics in his photo album.
Alasgun
Guest
PostPosted: Sun May 11, 2008 10:50 am    Post subject: Davit & Puller Reply with quote
Quite some time ago, I began thinking about the davit portion of this project. I have seen all the styles out there and was less than eager to go with one of them. The best of the group (IMO) was the one Less was working on but it has 2 big draw backs as well. Mounting on the gunnel, you loose the ability to safely go forward on that side of the boat, and being a fixed davit you have to contend with the workboat look all the time.
Originally I was going to use the starboard side and simply use the area behind the head which is totally unused space. Then I got into shrimping and needed to switch sides to mount the puller.
The davit is made from aircraft grade aluminum and all support hardware is Nitronic 50 Stainless. Exotic materials were not necessary but why not use the best stuff on your own boat? It has been proofed to 600 lbs which is way conservative but more than sufficient for my needs. For hoisting the dingy or in a MOB situation I will use a small block and tackle arrangement. The puller will do any heavy lifting.
On the port side I use that rear cabinet for life jackets and fishing gear and once everything was shoehorned in, I only lost 1 lifejacket slot.
The puller is a commercial lobster pot puller and was chosen for it's ability to bulkhead mount. It only stands off the wall 2 1/2 inches and will surely do what I want, pulling shrimp pots.
I have had brief conversations with C-dory about the davit and when I get home this time a disc of construction photos will be forwarded to them. Who knows, you may have a factory davit option some day!
Mike
Page generation time: 0.0573s (PHP: 71% - SQL: 29%) - SQL queries: 26 - GZIP disabled - Debug on
