Wallas stove/heater fuse
goldpan
City/Region: Campbell River
Photos: REEL KNOTTY
PostPosted: Wed Apr 30, 2008 12:05 pm    Post subject: Wallas stove/heater fuse Reply with quote
I have read there is a fuse which is often the problem and may be mine. Can someone tell me where it is and the type? Thanks
Dreamer
Photos: Dreamer
PostPosted: Wed Apr 30, 2008 3:45 pm    Post subject: Reply with quote
If you missed this post, It's a keeper. Everything you want to know about your Wallas. Just click Download.
http://www.c-brats.com/viewtopic.php?t=7763&highlight=wallas+repair
Dreamer- Sold 25 Feb. 2013
goldpan
Photos: REEL KNOTTY
PostPosted: Wed Apr 30, 2008 4:18 pm    Post subject: Reply with quote
Thanks for the reply I had already gone through that article but did not see any discussion of fuse or recognize a fuse in any of the pictures.
SeaSpray
City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
PostPosted: Wed Apr 30, 2008 10:31 pm    Post subject: Reply with quote
The fuse is what I think is called a spade type. It is plastic and flat with two flat prongs out the bottom and the rating on the top. Same as used in cars. I think it is located on the main circuit board. You should be able to see it by standing on your head and looking up at the circuit board.
Good Luck,
Steve
smittypaddler
City/Region: Neenah, Wisconsin
Vessel Name: Na Waqa
PostPosted: Wed Apr 30, 2008 11:36 pm    Post subject: It's a 2-amp fuse Reply with quote
It's a 2-amp fuse. When I was having problems with my Wallas, and had blown several in a row, I called the dealer, who told me to put in a bigger fuse. I've had a 5-amp in mine for several years.
Almas Only
City/Region: Richmond
Vessel Name: Alma's Only
Photos: Alma's Only
PostPosted: Thu May 01, 2008 5:58 am    Post subject: Reply with quote
Here's the photo you requested.
Your fuse might be a different color, depending on it's amp rating. I'm using a 3 amp. Also, you might or might not have the spare fuse, one blade of which inserts into a female spade connector attached to a short wire.
If you going to replace the active fuse, I suggest you first pull the main power supply fuse located near the battery + terminal. That way, you won't short anything out on the unit's electronics panel.
http://www.c-brats.com/modules.php?set_albumName=Cabin%2CInterior&id=122506_001&op=modload&name=gallery&file=index&include=view_photo.php
2003 CD22 Cruiser with Honda 90
goldpan
Photos: REEL KNOTTY
PostPosted: Thu May 01, 2008 1:23 pm    Post subject: Reply with quote
thanks for all the help
i did find it last night after standing on my head as instructed above.
this is such a great site.
Page generation time: 0.0305s (PHP: 58% - SQL: 42%) - SQL queries: 24 - GZIP disabled - Debug on
