Ram Mounts???
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Fri Mar 14, 2008 8:08 pm    Post subject: Ram Mounts??? Reply with quote
I am thinking about moving my C80 display to under the electronics shelf, and using a Ram swing arm mount upside down. Has anyone else used the Ram Swing Arm? If so, what is your opinion? I have a Ram ball and socket style that my Lowrance unit is on, and it seems to be OK...
TIA,
Steve
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Fri Mar 14, 2008 8:13 pm    Post subject: Reply with quote
I use Ram mounts for my gps on my motorcycle...strong and safe...you can buy them at West Marine or Cabela's
Joel
SEA3PO
PostPosted: Fri Mar 14, 2008 9:29 pm    Post subject: Reply with quote
I used a RAM swing arm mount for a Furuno CRT radar--weight several times that of the RayMarine. No problems over 35,000 miles of sailing--the one I used was the double swing--and moved the heavy radar over 24" from one position to the other.
I have use both the double ball, single ball and Laptop mounts--all have worked well. Great products.
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Fri Mar 14, 2008 10:11 pm    Post subject: Re: Ram Mounts??? Reply with quote
TIA,
Steve
Les put my E-80s on Ram Swing Arms as part of my winter refit project. I have yet to try them out but am fully confident that they will work well, as he has used them many times before.
Doryman
M/V Lori Ann
Anacortes, WA
Page generation time: 0.0337s (PHP: 64% - SQL: 36%) - SQL queries: 17 - GZIP disabled - Debug on
