Question about the flush valve joint on the Honda 135/150
PostPosted: Sat Mar 08, 2008 10:36 pm    Post subject: Question about the flush valve joint on the Honda 135/150 Reply with quote
Is anyone here using that to flush the motor? I was told by a Honda dealer that they recommended we flush the motor by using a set of the ears (muffs) over the water intake; reason being that the water was warmed better and that it went all through the water system, where using the flush valve didn't.
What's the general consensus?
Thanks in advance.
http://captnjim.blogspot.com/
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Sat Mar 08, 2008 10:44 pm    Post subject: Reply with quote
Don't know about Honda, but my Yamaha service center said to use a barrel or bag to flush, or if that isn't available, mouse ears. I was using the flush port, salt crusted up on the water pump housing, they had to replace it when they put new seals in, they said that was the reason, flush port.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
Page generation time: 0.0493s (PHP: 31% - SQL: 69%) - SQL queries: 20 - GZIP disabled - Debug on
