Anyone running an EP-20 interface
chewyjackson
PostPosted: Thu Feb 07, 2008 1:11 am    Post subject: Anyone running an EP-20 interface Reply with quote
Just curious if any of you with Suzukis are running the ep-20 interface.
I have the part on order and am going to do a little cutting and splicing to hopefully get it to interface with my C-80
PostPosted: Thu Feb 07, 2008 8:31 am    Post subject: Reply with quote
Let us know how you make out. I don't know what that interface is but I'm trying to interface my Suzi 115's with an E80 system and autopilot. Not sure I want that much info on the screen but gadgets intrigue me..
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Thu Feb 07, 2008 9:30 am    Post subject: Reply with quote
Yes I am using it with the 4 Inch gauge. Very accurate fuel readings even at idle.
Jody Kidd
KE7WNG
Northern, Utah
chewyjackson
PostPosted: Fri Feb 08, 2008 12:20 am    Post subject: Reply with quote
Its an interface that you plug directly into the engine. Its set up on a Lowrance based NMEA 2000 system, which raymarine does not directly have.
Raymarine does have seatalk2 connections which is NMEA 2000 in disguise. There is another member here that has done this, but not directly to the Suzuki interface. Now that raymarine has a subpage for engine management, you can save this to your customized page set.
I'm waiting for all the stuff to get here. It shouldn't take that long to install, so I'll have to post up the project when I get it done as I know a lot of you c-dory guys run raymarine stuff.
Page generation time: 0.0391s (PHP: 61% - SQL: 39%) - SQL queries: 22 - GZIP disabled - Debug on
