paper charts vs: navionic chips
Goto page 1, 2, 3, 4, 5  Next
patrick and linda
City/Region: somerset
State or Province: KY
C-Dory Year: 1986
Vessel Name: "Fan-A-Sea"
Photos: Misty Seas
PostPosted: Fri Feb 08, 2008 10:26 am    Post subject: paper charts vs: navionic chips Reply with quote
hello,
i would like to purchase one or the other but not both. i currently have a raychart 435 chartplotter/gps system. i'm going to be traveling the icw, in the florida area, west side.
seeking wisdom on which charts to purchase, paper vs: navionic chip cf/16xg, retails for $199.. or thereabout.
responses are greatly appreciated.
thanks
pat
PostPosted: Fri Feb 08, 2008 10:40 am    Post subject: Reply with quote
Pat, in my book they are mutually exclusive. I'd get both.
You can find ICW chartbooks which are less expensive than buying all the paper charts individually and that give much more info. The chip will cover the whole shebang. Always good to have a backup, you won't be sorry (only a little poorer!)
Hi Pat,
I like to have both onboard. We found chartbooks available for most of Florida - much handier and less expensive than buying each chart separately. You can also download (and print) NOAA charts for free (or use them with a laptop onboard). Used with our chartplotter, AND a good cruising guide, the paper charts make your life easier by having the "big picture" and detail.
I know there are folks who run with just a chartplotter... some old pilot habits don't go away - even with a bag full of Jepps IFR books, I always had VFR charts, as well. Good info makes the cruising less stressful, IMHO.
ahpeterson
PostPosted: Fri Feb 08, 2008 10:42 am    Post subject: Reply with quote
I'm a purist. While I love my plotter, I would never set out on unfamiliar (or really any) waters without proper paper charts.
I've always been partial to chart books, as they are much easier to manage than proper NOAA charts (especially with the limited space in a C-dory). So, while I would consider going out with only paper charts, I'd never go out with only electronic charts. While electronics can break, it would take a fairly massive flood or fire to make your paper charts not work. And if you've got a flood or fire, you've got bigger things to worry about than your navigation references.
View user's profile Send private message Send e-mail Visit poster's website AIM Address Yahoo Messenger MSN Messenger
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Fri Feb 08, 2008 10:44 am    Post subject: Reply with quote
+1 for both Mr. Green Beer
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Fri Feb 08, 2008 11:23 am    Post subject: Ditto Reply with quote
Ditto on the advice Pat, don't 'let go last lines' without two means of navigation. I always carry paper charts, divider, parallel ruler, and hand held GPS just in case the primary system fails.
I also like to plan trips using the paper charts. Some say you can use the chartplotters but I like to look at the big picture and write down eta's, magnetic courses to be followed, etc. If your primary system craps out, and you're on course, just follow the compass (and backup GPS).
Captain Matt
garyk
City/Region: Ketchum
State or Province: ID
Vessel Name: AMIGO 11
Photos: Amigo II
PostPosted: Fri Feb 08, 2008 11:28 am    Post subject: Reply with quote
Pat,
We have a Raymarine C80 chart plotter with all the current up dates. It is backed up by a Garmin 176C hand held GPS, with Marine Blue Charts, mounted on the port side for the co-pilot. Some paper charts, but used only for planing, never for navigation.
This past two summers we made two trips to Alaska,covered 6000 mi.
We rely totaly on the electronics. We have explored back country, narrow channels, rocky passages, etc. The chart is always directly in front of the helm. The 1st mate double checking with the Garmin when in tight places.
We have found the systems, Garmin and Raymarine, a given rock location may differ by a few feet, but when zoomed in tight, both agree, within six feet. Most of the time they place the object in the same place.
We depend on the sonar when in tight places, but found the contour lines very accurate, especially when zoomed in.
With this system, we have two independed electrical sources, The hand held uses four AA batteries, not rechargables.
Making these trips with only paper charts would have been very difficult. We would have had the cabin full of charts.
Hope this helps,
Gary
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Fri Feb 08, 2008 11:51 am    Post subject: Reply with quote
I vote for both. I have a C-80 with navionics chips, a Garmin GPSMAP76C for backup and ditchbag, and paper charts. I don't get the large scale individual charts equivalent to 7.5 minute topo charts, rather I carry small scale charts that give enough detail over a large area that in a pinch I could navigate by them and are really the best for route planning. But then I'm a very cautious guy.
Patti and Barry
formerly C-Cakes, now
rving around N. America
PostPosted: Fri Feb 08, 2008 11:52 am    Post subject: Reply with quote
When we came through the ICW we depended on two methods of navigating: MapTech chart kits and the chartplotter on the computer. Times have changed and we now have dedicated chartplotters. However we used both, and one still should use both the paper trail and the electronic picture. Tux Film Email Lips Rose
For the paper charts, when the ICW meanders (and it does, coming up the East Coast) Judy would mark off the bouys on the Chartkit, and look ahead to the next one. I'd look at the computer, with GPS, and see exactly where we were. Worked great and we only went aground 1/2 dozen times (6 ft keel.) The chartkits are (relatively) cheap and they keep you out of trouble. I think they now even come with a CD, because all the charts are now free on the Internet. Also the chartkits let you plan where you can anchor (in conjunction with the cruising guide,) how things are ahead of you etc.
The chartplotter, computer or dedicated, is mandatory to see where you are. There's a lot of swamps, inlets, etc. that spread all over the place. And those electronic charts are even more accurate then they used to be.
Capn Bobs ICW guide was detailed and had a LOT of local information. Also cheap. I understand this it's being updated. It really told of the local anchorages and marina. Moon
patrick and linda
C-Dory Year: 1986
Photos: Misty Seas
PostPosted: Fri Feb 08, 2008 12:06 pm    Post subject: Reply with quote
I AGREE WITH ALL RESPONSES. MY GOAL WAS TO LIMIT EXPENSES AND PURCHASE THE SINGLE BEST PROGRAM. BEING LOST IS NOT A CONCERN AS I'LL BE TRAVELING IN PROTECTED WATERS, HAVING LAND ON BOTH SIDES. I GENERALLY CARRY BOTH PAPER AND CHIP FOR THE OTHER AREAS THAT WE BOAT IN, AND PROBABLY SHOULD DO THE SAME FOR THIS TRIP. IN OPEN WATERS I'M LOADED WITH CHARTS, ELECTRONICS, SEXTON, CELL PHONE, MULTIPLE VHF'S, AND EMPTY WINE BOTTLE WITH (SEND HELP) NOTE INSIDE.
WHAT I'M HEARING IS , DO IT RIGHT! WELL HEARD.
THANKS AGAIN,
PAT
PS. CAPT. MATTIE, I APPRECIATE THE OFFER, WILL LET YOU KNOW SOON. SAVINGS IS SAVINGS, REGARDLESS OF THE AMOUNT. CAN'T GO BROKE MAKING MONEY.
matt_unique
City/Region: Boston
Photos: Napoleon
PostPosted: Fri Feb 08, 2008 12:51 pm    Post subject: Last option Reply with quote
Ha ha ha! I have to admit an empty wine bottle with a "Send Help!" note inside is not part of my current inventory. With some of the currents we have up here it might be a solid option though....
patrick and linda
C-Dory Year: 1986
Photos: Misty Seas
PostPosted: Fri Feb 08, 2008 1:18 pm    Post subject: Reply with quote
HEY, I'M ON THE OHIO RIVER. I CAN TELL YOU ABOUT CURRENTS.
PAT
WWW.AUTOHOMELIFE.NET
PostPosted: Fri Feb 08, 2008 1:41 pm    Post subject: Reply with quote
PAT
I'm fairly religious but wouldn't consider taking a ranking member of the church on a long cruise....
Oh, wait, maybe you meant sextant! Rolling Eyes
Spell check wouldn't have even caught that one Exclamation
Sounds like a great trip...
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Fri Feb 08, 2008 2:34 pm    Post subject: Reply with quote
You guys kill me.....Ha ! My wife once caught me navigating with a place mat.... but I have always been that type of guy.... now I use the GPS ...I do have a spare that we carry.... but paper charts are to bulky and never handy ....
If I was planning an extended voyage I would buy a "routebook type guide" for casual reading and planning.....but the GPS does it all....so why worry.
Joel
SEA3PO
PostPosted: Fri Feb 08, 2008 2:58 pm    Post subject: Reply with quote
Remember that the GPS chart plotter is a rather recent instrument which many of us have become dependant upon. We try and have paper charts for all of our voyages. There are good reasons--including that the overview is not well seen on a chart plotter. The more you zoom out, the less detail is available (ie how high is the bridge?) On the other hand, if you zoom in, there is the "y" in the ICW where you don't know which way to go, especiall if the difference between the channels is only a few degrees--so the paper chart is almost essential for "planning".
We normally run with two chart plotters--one zoomed in to a mile or so, the other at 5 or more miles (depending on where we are.). We back up with a computer which has all of the electronic charts of the US on the hard drive.
We have voyaged several hundred thousand miles with no GPS. We have even used a detailed road map to "navigate" the coast of Yugoslovia. We have gone up inlets in the PNW where there was no chart available. All of these were done safely. It remains the prudent navigator who stays out of trouble--but takes as many precautions as he can to avoid difficult situations.
For planning the old chart or chart book works well. You can save some $ by contacting consignment shops for used charts or chart books, or watch on some of the forums where people sell charts. When we were full time world cruising, we had several thousand charts aboard--and often traded them, or purchased them for a dollar or so. They were very rarely up to date, but we had an up to date light list or coast pilot.
Page 1 of 5
Page generation time: 0.0591s (PHP: 53% - SQL: 47%) - SQL queries: 28 - GZIP disabled - Debug on
