Out board storage for CD22
bshillam
City/Region: Bellingham
C-Dory Year: 1981
Vessel Name: Heaven To Me
Photos: My Heaven
PostPosted: Tue Jan 29, 2008 12:52 pm    Post subject: Out board storage for CD22 Reply with quote
We just picked up a long shaft Honda 2 horse. Anyone have great ideas for the storage of the outboard on a CD22? I love the mounting bracket one can buy for a CD25, but alas there is no rail on a CD22 for that process. I do have the rail that runs slightly above the engines - anyone figured out how to mount something to this? Question I really don't want to have it hanging out in the cockpit while underway or even think about laying it down on the roof. Embarrased Something a bit more sturdy would be nice - maybe even a troller mount? I have twin Hondas in the back now.
Thanks brats for the help.
MOOSE
State or Province: MN
Vessel Name: MOOSE
Photos: MOOSE
PostPosted: Tue Jan 29, 2008 1:44 pm    Post subject: Reply with quote
Based on my experience, I think you are going to have real trouble trying to propel a CD22 with a 2HP.
Al
bshillam
C-Dory Year: 1981
Photos: My Heaven
PostPosted: Tue Jan 29, 2008 2:09 pm    Post subject: I would agree Reply with quote
OOPS - I am strickly using the 2 horse to use on our new tender.
Valkyrie
City/Region: Loudonville
State or Province: OH
Vessel Name: Valkyrie II
Photos: Valkyrie
PostPosted: Tue Jan 29, 2008 3:16 pm    Post subject: Reply with quote
We have the same Honda 2 LS as you and used to put a foam pad on the roof, tie the OB down and then put our Achilles LT-4 on top of the OB and tie that to the rails, as well.
Your best bet, and one we're going to duplicate can be found in C-Dancer's album. It will work great, providing you have the factory SS rail across the splashwell.
Nick
"Valkyrie"
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Tue Jan 29, 2008 3:25 pm    Post subject: Reply with quote
I thought you couldn't lay a 4-stroke on its side Question Question Question
Doryman
M/V Lori Ann
Anacortes, WA
Valkyrie
Photos: Valkyrie
PostPosted: Tue Jan 29, 2008 4:08 pm    Post subject: Reply with quote
You have to lay it on its side, but only the side that has the "nubs" or supports for that purpose. Look at your Honda and you'll see what I mean.
You can't support a four stroke on its "back", as you would a two stroke.
Nick
"Valkyrie"
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Tue Jan 29, 2008 4:10 pm    Post subject: H2 Reply with quote
Bryrick,
I have been pondering the same question. I think what I will do is to build a mount that would ride in the splash well, then lay the H2 across the well, proper side up. and as far forward as possible. I am thinking that a cradle for the lower unit, and the mount clamps should hold it securely.
One would have to be careful with main engine tilt, etc., but I think it would work. Before I get too carried away, I plan to get busy with a tape measure.
Steve
Les Lampman
Dealer
City/Region: Whidbey Island
PostPosted: Tue Jan 29, 2008 4:41 pm    Post subject: Reply with quote
You can lay a 4-stroke down; it just has to be on the correct side (they usually have "feet" on the lay down side).
Les
www.marinautboats.com
amy and karl
City/Region: Graham
Vessel Name: C-DAISY
Photos: C-DAISY
PostPosted: Tue Jan 29, 2008 6:49 pm    Post subject: Reply with quote
Bryrick, here is link for a product that we considered. Not sure you would want to use a trolling bracket. Karl on C-Daisy
http://www.weaverindustries.com/docs/75707_Weaver_book_rp.pdf
bshillam
C-Dory Year: 1981
Photos: My Heaven
PostPosted: Tue Jan 29, 2008 7:05 pm    Post subject: Swim step? Reply with quote
I think the biggest challenge is going to be mounting it to the rear as I've got twins. I have been thinking of adding the swim step and then mounting it from there. But I've already got a latter for the side so thats kind of redundant. Crook I did notice though a CD22 in one of the albums that had twins and an engine mount too on the Port side. It looked real sharp all done up. Thumbs Up
Jazzmanic
Photos: C-Dancer
PostPosted: Tue Jan 29, 2008 7:13 pm    Post subject: Reply with quote
Thanks Nick.
I guess I'll chime in although I don't have a picture of it in action. I think my system is similar to what you described bshillam. I used the transom bar as the horizontal rail for the rail mount poly board I bought at West Marine. I bought a used 3' stainless steel bar to insert into the vertical hole of the poly board. I bought a couple of pieces of ss hardware. One called an outside eye end that I screwed on the bottom of the vertical bar and the other a deck base which I screwed onto the bottom of the splash well and then used the pin to connect to the outside eye. I then put a square of rubber material on the bottom of the splash well where the skeg sits to protect the fiberglass. It works really well and looks pretty cool, 3 Suzi's all in a row!
Here's the link to my album called "Projects" which shows the parts. Dinghy Motor Rail Mount
Hope this helps.
Peter
C-Dancer
amy and karl
City/Region: Graham
Photos: C-DAISY
PostPosted: Tue Jan 29, 2008 8:07 pm    Post subject: Reply with quote
Sorry, just realized the link I posted for Weaver Industries doesn't get you directly to it. It's called the MotoSto and it's on page 14. karl
bshillam
C-Dory Year: 1981
Photos: My Heaven
PostPosted: Tue Jan 29, 2008 8:29 pm    Post subject: Price Reply with quote
Have you priced that out yet? It looks like it might work out well for location on the transom.
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Tue Jan 29, 2008 8:58 pm    Post subject: Reply with quote
Just a thought, but how about mounting it to the outside of the back of the cabin wall, opposite side from the door swinging open. This gets the extra weight as far forward as possible (except in the cabin or on the bow). Either fab a bracket or see if one of those Weaver accessories will adapt. I'd mount it so the engine was facing sideways for minimum intrusion into the cockpit. Might have to reenforce the wall?
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
amy and karl
City/Region: Graham
Photos: C-DAISY
PostPosted: Wed Jan 30, 2008 7:16 am    Post subject: pricing Reply with quote
Here is one source.
Here is another. karl
Page generation time: 0.0518s (PHP: 67% - SQL: 33%) - SQL queries: 32 - GZIP disabled - Debug on
