| View previous topic :: View next topic |
| Author |
Rob & Karen
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
Posted: Sat Dec 29, 2007 10:23 pm Post subject: Klean Heat Shelf Life |
We just installed a Wallas 1300 and are using Klean Heat for fuel. I bought three jugs from Home Depot thinking that it may be a seasonal item around here. Scan Marine cautioned that Kerosene deteriorates quickly and that fresh fuel is important. I was wondering what experience others have had with storing Klean Heat for any length of time. How long have you kept it without problems? Do you use any additives in it?
Thanks for any information.
Rob & Karen |
| Back to top |
tsturm
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Sat Dec 29, 2007 10:57 pm Post subject: Re: Klean Heat Shelf Life |
| Rob & Karen wrote: | We just installed a Wallas 1300 and are using Klean Heat for fuel. I bought three jugs from Home Depot thinking that it may be a seasonal item around here. Scan Marine cautioned that Kerosene deteriorates quickly and that fresh fuel is important. I was wondering what experience others have had with storing Klean Heat for any length of time. How long have you kept it without problems? Do you use any additives in it?
Rob & Karen |
http://zenstoves.net/MSDS/KLEANHEAT.pdf
Sealed in the container, out of direct sunlite & at room temp it will probably outlast all of us. Once you open it I would guess a year!
| Back to top |
BrentB
Joined: 15 Jul 2006 Posts: 2455 City/Region: Greenwood
State or Province: IN
Posted: Sat Dec 29, 2007 11:11 pm Post subject: |
It is my understanding the shelf-life is 2 years for an unopened container and 6 months for an open one. _________________ Brent Barrett |
| Back to top |
Dora~Jean
Joined: 09 Mar 2004 Posts: 1338 City/Region: Thousand Oaks
Vessel Name: Dora~Jean
Photos: Dora~Jean
Posted: Sun Dec 30, 2007 12:55 am Post subject: |
I am using 2 yr old Klean Heat right now, just burned about 14 hrs total during my outing this week. No problems. This is synthetically manufactured (formula unknown), the shelf life will most likely be different than kerosene. I also heard (from Scan Marine I believe) that when kerosene deterioates, it begins to leave a residue or precipitates at the bottom of the container. Not sure about that one, but I checked my containers, no solids. _________________ Steve
"Great works are performed not by strength, but perseverance" (Samuel Johnson) |
| Back to top |
terraplane
Joined: 09 Dec 2004 Posts: 522 City/Region: chesapeake bay
C-Dory Model: R-25 Tug
Vessel Name: BANJO
Photos: Sally's Sister
Posted: Sun Dec 30, 2007 8:34 am Post subject: kleen heat use |
Right now i'm burning a jug that is over two years old...kept in unheated barn area. No problems. I always start on highest setting and shut off in highest setting to burn off carbon,I'm told.
terraplane |
| Back to top |
C-WEED
Joined: 14 Mar 2004 Posts: 328 City/Region: New Brockton
State or Province: AL
Vessel Name: C-Weed
Photos: C-WEED
Posted: Sun Dec 30, 2007 12:19 pm Post subject: |
Just make sure the jugs sit completely on the shelf. I had two that got moved around a bit and hung off maybe an inch on one end. And it happened to be the end closest to the wall that you don't see. This will make the container sag just enough to make a nice tiny crack.
Drip...drip...drip... I noticed a moist stain on the outside of the garage foundation block and went to investigate. What a mess... _________________ Chris |
| Back to top |
