Single engine or twins?
DaveFran
City/Region: Wilmington
Vessel Name: Dah Who
PostPosted: Mon Dec 17, 2007 4:14 pm    Post subject: Single engine or twins? Reply with quote
The great debate is whether a 25' cruiser needs two engines to manuver or is a single engine enough?
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Mon Dec 17, 2007 4:24 pm    Post subject: Great debate Reply with quote
Indeed a great debate. If you do a search there are many threads on the subject. In the search title bar, write the words "single and twins" without the quotes and you will be reading for hours.
I questioned the very same when I began my C-dory research into the C-25.
Captain Matt
Dragonfly
City/Region: Cameron
Vessel Name: FireFly
Photos: Dragonfly
PostPosted: Mon Dec 17, 2007 4:45 pm    Post subject: Singles or Twins Reply with quote
We have a CD-25 with a 135 Honda and we are very pleased with the handling and performance. Fully loaded on flat water it's done 26.7 knots by GPS. On the St. John's River in Florida last month we poked along for a week and burned 44 gallons of gas but I believe we go slower than most. The nearest salt water to us is South Port N.C. Larry
"Imagination will often carry us to worlds that never were.
But without it we go nowhere".
Carl Sagan
flapbreaker
City/Region: Hillsboro
Vessel Name: Playin' Hooky
Photos: Playin' Hooky
PostPosted: Mon Dec 17, 2007 5:50 pm    Post subject: Re: Single engine or twins? Reply with quote
Both will propel the boat.
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Mon Dec 17, 2007 5:56 pm    Post subject: Reply with quote
DaveFran: I see you are a new member on the C-Brat site! Welcome. It is great to have new folks on board.
Take a look up top at some of the "main menu" ares from the home and/or just about any other page. The second one is Forums. Most things have been talked about in depth several time. I am not suggesting that you do not ask questions.... but, I know how it is when you are new on some sites. I can spend much time just going down the second menu column under "FORUMS" and scrolling down for "sub areas".
Happy Boat Hunting, take your time, look around, go to some gatherings and see the boats in the water with stuff on them. A large difference than boats under the bright lights and flat concrete floors at a boat show. Boat shows are great to just get on the boat, to appreciate and/or truly evaluate the boats, you need to get on the water.
Welcome again.
Byrdman
Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
PostPosted: Mon Dec 17, 2007 6:17 pm    Post subject: Reply with quote
Although you might some some increased maneuverability with twins, they are set closely together and it will not be like in a twin screw inboard power boat or the Tom Cat.
I personally find that in boats the size of the CD 25 that a single is very good for maneuvering. Personally the only reason I would consider twins would be for the faster speed if you had to run on one of the twins vs a kicker--I would not make that decision based on maneuverability. Remember that an outboard moves the thrust, and is much more maneuverable than a similar sized inboard.
ryder
City/Region: duncan
PostPosted: Wed Dec 19, 2007 12:58 am    Post subject: Reply with quote
I just got my new 22 a few months ago. I had the same dilemma. Twins or single and kicker. I was initially going to go twins, then I found out the boat won't plane with one engine anyway. So why twins? Then I thought why use a big motor for fishing? Better to use a kicker. All in all it made more sense for a single with a kicker. But that was just me.
good luck
ryder
"Shoot for the moon , if you miss you're still among the stars"
Page generation time: 0.1225s (PHP: 22% - SQL: 78%) - SQL queries: 24 - GZIP disabled - Debug on
