EdCich
Vessel Name: LOWFLYER
Posted: Fri May 21, 2004 12:57 am Post subject: Bulging Fuel Tanks |
Is there anyone else out there having problems with bulging sides on plastic tanks? Just had both tanks replaced by C-Dory in mid February because the starboard tank was bulging. They didn't have the latest new tanks according to Bill so they put in what he called F-8 tanks which looked just like the originals on my 2000 22' Cruiser. They looked great when I picked the boat up but now both tanks are bulged on all sides and concave on top.
I have not observed any leakage but when I first reported the tank bulge to C-Dory way back in May of 03 I was advised that the tank should be replaced. I've never had a good explanation of the problem. Any thoughts as to how concerned I should be would be appreciated.
Ed C |
AnchortownJim
Vessel Name: Coho
Photos: Coho
Posted: Fri May 21, 2004 1:25 am Post subject: |
Yes, the tanks on my 2003 22' Cruiser are bulging just a bit. Have not worried too much about them, but maybe I should. Would love to see any C-Dory Marine person chime in here and give us a definitive word on tanks. If bulging is precursor to tank failure, I really would like to know that.
Jim |
Anita Marie
Joined: 01 Nov 2003 Posts: 826 City/Region: Oak Harbor
Vessel Name: Anita Marie
Posted: Fri May 21, 2004 2:55 am Post subject: |
I am picking my boat up at the factory tomorrow and one of the warrenty issues is bulging fuel tanks. I will post there response that the factory gives me but I know that they did not replace them. |
Joined: 02 Nov 2003 Posts: 8555 City/Region: Birch Bay, WA
Posted: Fri May 21, 2004 9:40 am Post subject: |
Our tanks bulge significantly (2003 22' Cruiser), had not given it a second thought...I will be REAL interested to see what they tell Fred about the issue.
PS_Rick wrote: | I am picking my boat up at the factory tomorrow and one of the warrenty issues is bulging fuel tanks. I will post there response that the factory gives me but I know that they did not replace them. |
Anita Marie
Posted: Fri May 21, 2004 6:28 pm Post subject: |
The factory removed the starboard pieces forward of the tanks, repositioned the tanks and then installed thicker starboard. It is quite a bit better but not perfect. I have looked at most boats and I thought mine was the worst. I think I will take some pictures and post them to see what people think.
Fred |
Jeff M
Posted: Fri May 21, 2004 8:48 pm Post subject: |
More often than not the plastic tanks will bulge. For some reason it is more prevalent on the starboard side. This bulging does not hurt anything. We have not had any failures due to the tank bulging. We are now using a heavier bulkhead material and leaving a small gap between the bulkhead and the tank. _________________ Jeff Messmer |
Anita Marie
Posted: Fri May 21, 2004 10:11 pm Post subject: |
I want to say the the factory did repair my fuel tanks to my satisfation. They did exactly what they said they would do and in a timely manner. I have posted some pictures of the repair.
Factory tank repair |
EdCich
Posted: Sat May 22, 2004 3:16 pm Post subject: Bulging Tanks |
Thanks for the replies. Both my "new" tanks are bulged about an inch on all sides. I'm really puzzled as to why some do and some don't. Any thoughts.
Ed C |
Posted: Sat May 22, 2004 3:59 pm Post subject: |
I've got ten year old tanks on Captain's Choice and really don't notice any bulging to speak of. They didn't put bulkheads in front of the tanks at that time, there's just a naugahyde "curtain" across the whole area that hides the tanks and the bilge pump well. _________________ CHARLIE and PENNY CBRAT #100
K4KBA |
Adeline
Joined: 03 Nov 2003 Posts: 985 City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
Posted: Sat May 22, 2004 4:15 pm Post subject: |
My tanks have always bulged when full. Pete _________________ Pete
Posted: Sat May 22, 2004 6:23 pm Post subject: |
My main tank always bulges. The boat tanks not noticeably so.
charlie |
CAVU
Vessel Name: CAVU
Photos: CAVU
Posted: Fri Sep 03, 2004 10:57 pm Post subject: |
I just discovered a problem with my fuel tank. I think the starboard tank bulged somehow and pulled the plastic strip in front of the tank out of the cockpit floor. I put two pictures on my photo album. Best I can tell, the front covering board is atch to this strip and the tank has a hold-down strap atch to the top of the covering board. If tank bulged it would cause a vertical pull on the covering board? Has anyone else had a problem with this? I am unsure how to repair it. As I understand it the bottom is end-grain balsa covered with a thin veneer of fiberglass. I wouldn't think either one would be very good at holding screws against a vertical pull. I would welcome any ideas. The port tank seems fine. Thanks. _________________ Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas |
Almas Only
Vessel Name: Alma's Only
Photos: Alma's Only
Posted: Sat Sep 04, 2004 7:27 am Post subject: |
Here's a blow by blow, if you want to do a fix. We've had one tank replaced by the factory, and both now bulge to some extent, but not as much as the first had. The condition appears stable. Here's what we've done, and it seems to be a good fix. I'll post some photos later:
1: Get both tanks essentially empty, either by running the motor, or by siphoning. If siphoning, do so into your car's tank, rather than 5 gallon gas cans, so you don't have to worry about overflow onto the driveway. REMEMBER, the fuel-air mixture which remains in the tanks is highly explosive, and, if ignited by static or any other means, will put you in a nursing home or grave. Don't get careless. SEE THE NOTE AT THE END OF THIS ITEM BEFORE YOU EMPTY THE TANKS.
2: unscrew the clamp which holds the strap to the forward vertical panel, remembering that there is probably considerable tension on the strap because of distortion of the tank. I've not had any luck getting the strap d-rings to release when under high tension, but you sure can give it a try.
3: unscrew the fuel tank retainers (front and side) from the deck, clean out the holes as best you can after making sure they're dry, and plug with 3m 4200, being sure to avoid air pockets. Suggest using a wood match stick or toothpick to press up and down through the 4200 to release the air, then give it some more 4200, and repeat until no more air escapes. Wipe flush, but don't worry about it being too pretty, since nothing will show, anyway.
4: push each fuel tank securely against the side and rear of the boat, and mark the outline around the front and inside. This is important because a near empty fuel tank, if not restrained, will move around without your knowing, and you'll end up securing it in the wrong spot. It doesn't hurt to do this on a hot day, so the tanks have undergone whatever heat expansion they're inclined to do. Make sure there isn't debris around the tank which prevents you from getting a good fit.
5: clean up the front retaining panel and screws (or just replace the screws), and if necessary, reconfigure the lower strip. On ours the vertical panel was 1/2 inch starboard, and the horizontal 1x1 starboard (give or take), screwed to the 1/2 inch from the rear. I reversed the screws, so that the 1x1 is secured from the front. That way, I can separate the panel from the 1x1 and pull the fuel tank, without disturbing the 1x1, and it's screws which attach to the deck of the boat. This reversal results in some degradation of the holding power of the screws which secure the 1x1 to the 1/2, but you can just add a few more, and be pretty close to the initial strength. I don't think step 5 is critical, so if your 1x1 or equivalent is something other than starboard, don't mess with it.
6: put the front retainers back in place, vertical against the front of the tanks, and be sure that the the clamp and any retainers which attach the straps slightly clears the top of the tank, rather than resting up against the front side. If necessary, redrill the strap retaining holes through the 1/2 inch starboard, and plug the old ones with 4200. Then, put the front panel in place, mark the holes to be drilled in the floor, and mask along the exposed sides between the 1x1 and deck. I prefer to make a small (1/ inch pilot hole, and then drill to final size, which should allow the mounting screws to have enough bite in the fiberglass to make a firm fit, but not so much that you delaminate the glass. I always countersink slightly to prevent delamination. Watch out here, because if you sink either drill bit too far, you'll go through the balsa, and come out through the bottom of the boat. Use a probe wire after the first 1/8 inch hole, and probe down through the balsa until you hit the top of the underside, mark the depth, and be carefull drilling the rest of your holes, because the depth could vary. If the drill motor prevents you from getting totally perpendicular to the deck, just do the best you can, and get the screws to feed essentially perpendicular with a firm hand on the screwdriver, and a little patience. Practice on one screw, before drilling the holes for the rest, and make any adjustments in drill size that are necessary to get the final fit you want. I like to use a dental tool to open up a little cavity in the top of the balsa. Insert the mounting screws slightly in the holes to cut threads in the fiberglass and push out any balsa to the depth the screw will go when in place, then unscrew, and pack the holes with 4200. Lay a bead of 4200 where the 1x1 will rest on the deck, put the starboard in place, shoot some 4200 in the holes through the starboard, then insert the screws. Since my holes were oversized from a prior attempt, I used bolts, which are secured in place totally by the 4200, and don't actually contact the fiberglass. I don't like to be too careful cleaning up 4200 around screw or bolt heads, and just leave a bead showing to be extra sure that I've got a water tight seal. Reattach and tension the strap after the 4200 has cured.
7: I trashed the 1x1 starboard side retainer strips because they trapped water in an area where I want it to move to the sump at the drain plug, and not be forever trying to work it's way into the screw holes where the 1x1 is secured to the deck. Instead, I bought an aluminum angle piece at Lowes or HDepot, cut it into sections, and used two sections on each side to secure the tanks in place laterally. Again, mask, drill, countersink, etc. Given the forces which are generated when masses such as full fuel tanks try to slide back and forth in a boat, I added a marine ply thrust block, which transfers the force from one tank to the other, without affecting the aluminum retainers. Some pretty rough water hasn't made a dent on this setup. Except for the front 1/2 panel, which has considerable give, I was careful to restrain the tanks, be it with aluminum or a thrust block, only along the edges. That's where the deflection from loading with fuel, heat changes, etc. will be the least. I wouldn't add a thrust block or any other retainer which applied force to the center of a fuel tank side, because if it (or they) are inclined to deflect there, you are going to be dealing with forces which could rupture one or both tanks, or damage the side of the boat.
ONE NOTE: Before doing any of this, you should find out whether your tanks change shape when they're full of gas, hot, cold, etc. If you have considerable change, you can make some compensations during your work. The last thing you want to do is to go through this effort with empty tanks, thinking you've solved the problem, only to discover that you now have well secured tanks which distort when filled, and push everything you did all out of shape. _________________ 2003 CD22 Cruiser with Honda 90 |
CAVU
Vessel Name: CAVU
Photos: CAVU
Posted: Sat Sep 04, 2004 12:46 pm Post subject: |
Alma's Only,
Thanks for the detailed reply. Some excellent ideas which I will try. The only thing I wasn't real clear about is how you arranged the marine ply thrust block? Would this go along the floor from the bottom edge of one tank to the bottom edge of the other? |
Posted: Sat Sep 04, 2004 3:44 pm Post subject: |
Cavu-
A very thorough and detailed explanation!
This is the kind of answer that makes this site so much more valuable than just a chit-chat bazaar!
I understand the need to separate the fuel into two tanks for the following reasons:
1. to control the shifting of ballast/balance,
2. to provide added safety through having two different fuel pick-up points,
3. to provide access to the bilge well at the rear of the transom between the tanks, and
4. to allow visual evaluation of the amount of fuel remaining through the translucent plastic tanks, but
do you think aluminum tanks would be a better solution than plastic given the apparent problems involving the flexibility of the plastic tanks, and the difficulty involved in mounting them to the hull?
I'm thinking of replacing my original tanks, and the above problem doesn't make me want to use the standard factory solution if I can have solid aluminum tanks properly mounted with welded on flanges directly screwed into the floor below , and braced to the engine well above and the gunnel and transom walls on the sides with struts as necessary.
Just a thought to consider. Joe. _________________ Sea Wolf, C-Brat #31
