Wet Cabin Floor
PostPosted: Mon May 17, 2004 9:47 pm    Post subject: Wet Cabin Floor Reply with quote
Patty here. Every time we go out in Daydream we have a wet cabin floor. This last weekend the entire carpet was saturated, and it sits ON TOP of dry deck. This water is not due to splashing that might occur while running. When we got home, Pat and I checked absolutely every possible water source for leaks and came up empty (hoses to and from the fresh water tank, the hose from the bilge pump, etc.). We will ask C-Dory to check it out, I guess, when we take the boat in for its 200 hour service pretty soon. In the meantime, does anyone have a suggestion. I am so totally ticked about this. I want to walk on my nice rug barefoot in the evening!! Angry
MIKE MANNELL
City/Region: Vancouver, WA.
Vessel Name: GUNNY-D
PostPosted: Mon May 17, 2004 10:35 pm    Post subject: Reply with quote
Pat,
Did you have your ICE BOX under the pilot seat with ice in it? I used my ice box only once and I had water above the dry decking due to the worthless Ice Box! I find it hard to believe that the factory hasn't addressed the issue. I've read several posts from other Brats out there who have had the same problem. I plan on contacting the factory regarding this matter. I wonder if anyone else has?
Mike
GUNNY-D
22 Cruiser
B~C
City/Region: Bend
Vessel Name: Blue~C
Photos: Blue~C
PostPosted: Mon May 17, 2004 11:16 pm    Post subject: Reply with quote
Oscar
Ken
1999 22' boaterhome
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Mon May 17, 2004 11:44 pm    Post subject: Reply with quote
They don't have an ice box. The reason I know that is because I am the one that removed it.
Oscar ain't THAT big.
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
Anita Marie
City/Region: Oak Harbor
Vessel Name: Anita Marie
PostPosted: Tue May 18, 2004 12:13 am    Post subject: Reply with quote
Pat did you check the plug that goes from the cabin to the cockpit? I still think that may be your problem, unless you have a leak in your fresh water tank. Is it wet only when the boat is in the water?
PostPosted: Tue May 18, 2004 7:49 am    Post subject: Reply with quote
The icebox on Captain's Choice has a drain that runs aft to an outlet in the cabin rear bulkhead in the cockpit. I had to pull out the box one time to gete the seat out for reupholstry and couldn't get it reconnected. We don't use it anyway, just use an ice chest in the cockpit, plan to pull it out and replace with drawers/shelves as many have done. Check the drain.
Jeff M
PostPosted: Tue May 18, 2004 11:16 am    Post subject: Reply with quote
i don't have any additional ideas. Give me a call and we will get it in and get it figured out for you.
Jeff
Jeff Messmer
C-Hawk
Vessel Name: C-Hawk
Photos: C-Hawk
PostPosted: Tue May 18, 2004 12:19 pm    Post subject: Reply with quote
Pat-
Check out my postings on the trouble I had with my boat--
http://groups.msn.com/CDoryOwnersGroup/general.msnw?action=get_message&mview=0&ID_Message=606&LastModified=4675423169891461543
The stem guard was leaking- fixed that, then found the anchor locker to be leaking- fixed that. All problems were attributed to the lack of QC in the factory.
Check under the porta-potty and open the 6" access port to inspect for water in the V-berth
2008- CD22- "C-Hawk" Sold
KJ6VVB
A Brat I am, At sea I be
Catman
C-Dory Year: 2017
Photos: Bambina
PostPosted: Tue May 18, 2004 12:21 pm    Post subject: Reply with quote
Wow, how's that for service, Patti?
Thumbs Up
My IRA
City/Region: Springfield
C-Dory Year: 2013
Vessel Name: Aidiam
Photos: My IRA
PostPosted: Tue May 18, 2004 3:13 pm    Post subject: Reply with quote
Check the Rub Rail! You can shine a light on the inside of the hull and detect any water entering through the rub rail screws. I had to reseal the top and underside of the rail on our 22 (1992). I plan to do the same on our new 25.
Jerry and Helen
1984 Arima Explorer sold 1985
1985 Arima 17 SR sold 1992
1992 C-Dory 22 Cruiser sold 8/96
1992 OLympic 26XLF Sold 10/2000
1989 Arima 19 SR sold 2003
2004 C-Dory 25 sold 10/05
1992 Bounty 25 Offshore Pilot sold 6/2010
2006 Arima 17 SC sold 9/2012
2013 C-Dory 23 Venture
Almas Only
City/Region: Richmond
Vessel Name: Alma's Only
Photos: Alma's Only
PostPosted: Tue May 18, 2004 7:09 pm    Post subject: Reply with quote
We had an occasional wet floor problem on our last outing, and determined that the source was the stove hot air exhaust port. I haven't had time to do diagnostics, but presume that the leak is from high waves pushing water up into the corrugated tube ducting, and the water flowing out between the ducting and the thru-hull fitting to which it is clamped.
Easy dry land test will be to stick a plastic tube into the thru-hull from the outside, sealing the tube in the thru-hull hole with plumbers putty, and then blowing a few mouthfulls of water into the tube until there's enough to totally submerge the connection. With a clear plastic hose, I'll be able to see the actual level.
Then, go inside the cabin, and poke around under the stove with a flashlight and see if water is seeping in.
If that's the source, which I expect it will be in my case, I'll need to go to an automotive parts store and get some high temp sealant, and redo the connection.
I'll let you know how it turns out. Let me know about yours.
David on Alma's Only
2003 CD22 Cruiser with Honda 90
PostPosted: Tue May 18, 2004 7:34 pm    Post subject: Reply with quote
Yup, we took that out, put 'er back in and ran a lot of water in the cockpit to see if it got wet under that spot. It did not. Grrrrrrrr Mad
Rooster 27509
Vessel Name: Catch-22
Photos: Catch-22
PostPosted: Tue May 18, 2004 8:28 pm    Post subject: Reply with quote
(water tracks)
Pat what we did to find our leak on the Catch-22 was to put some sawdust on the cabin floor. This was after taking our dry deck out, and we could see a small "very small" stream coming from the foot pump for the fresh water system.
Like tracks in the sand, simple but water comes from someplace and you can track it back to its source.
good luck
CatyMae n Steve
City/Region: Jefferson, OR
Vessel Name: CatyMae
Photos: CatyMae
PostPosted: Wed Oct 19, 2005 9:53 pm    Post subject: Reply with quote
what happened? what was to cause? We're chasing a leak now and can't seem to pinpoint it...grrrr...n we have no Oscar! Wink
UncleRichie
City/Region: Bainbridge Is.
Vessel Name: C-Critter
Photos: C-Critter
PostPosted: Wed Oct 19, 2005 10:34 pm    Post subject: Reply with quote
Hi,
I had the same problem, do you have the foot pump for water? Mine had a leak at one of the fittings at the pump. They are nylon and one worked loose it would only leak when I pumped water. Bout drove me crazy before I found it. A little rtv sealant and no more problems.
Richard
Page generation time: 0.0525s (PHP: 66% - SQL: 34%) - SQL queries: 28 - GZIP disabled - Debug on
