tilt motor
ifishalot2@yahoo.com
City/Region: saratoga
C-Dory Year: 1988
PostPosted: Fri Nov 09, 2007 12:40 am    Post subject: tilt motor Reply with quote
motor has no tilt motor so to raise up the motor got to do it by hand 1982 evinerude 70 hp outboard is there one or a universal unit Thanks
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Fri Nov 09, 2007 10:42 am    Post subject: Re: tilt motor Reply with quote
The cheapest easiest way would be to find a used Johnson / Evinrude with trim-tilt and swap the nec. parts! Find the Oldest OMC Dealer in your area and go check out his bone yard! Mr. Green Beer
blackfish
City/Region: saltair
Vessel Name: raincoast
Photos: Raincoast
PostPosted: Fri Nov 09, 2007 10:51 am    Post subject: Reply with quote
I have a 92 50hp Evinrude it was swapped from power trim to tiller controls
I believe it works in reverse
most marine shops have lots of this old motors kicking around
digger
City/Region: Spokane
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Fri Nov 09, 2007 12:59 pm    Post subject: Universal tilt Reply with quote
CMC Manufacturing makes a universal trim/tilt for $470 available through West Marine, but it does set back the engine 6" so it might cause a problem when you try to tilt your engine, cosidering the engine box of your new boat. Page 294 in West Marine Catalogue.
previous snoopy-c owner, previous c-miner owner, current C-Sik owner(22 angler)
Adeline
City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
PostPosted: Fri Nov 09, 2007 1:00 pm    Post subject: Reply with quote
Here is a good discussion about your project. If you search for "adding tilt and trim" you'll get many more results.
Pete
Page generation time: 0.0615s (PHP: 37% - SQL: 63%) - SQL queries: 22 - GZIP disabled - Debug on
