Winterizing honda 135
mccml
City/Region: Montoursville, PA
Vessel Name: Crystal Sea
Photos: Crystal C
PostPosted: Sun Oct 21, 2007 9:25 pm    Post subject: Winterizing honda 135 Reply with quote
This is my first winter with my CD25 and I was wondering if most people change the oil at the end of the season and then after 6 months when they are getting ready to put it back in the water do you change the oil again before you run it? Or should I let it go for the winter and just change it in the spring before I start running it again? Any thoughts or advice?
Our Anchor holds,
Mark and Carol
(Crystal Sea)
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sun Oct 21, 2007 9:38 pm    Post subject: Re: Winterizing honda 135 Reply with quote
Chang Engine Oil, Lower Unit gear oil, add Fuel stabilizer and if you want to get real fancy pull the plugs & squirt a little ATF in each hole, replace the plugs. When Spring comes hook up the muffs & run it until
the smoke stops. Good for another 100 hrs. Mr. Green Beer
PostPosted: Mon Oct 22, 2007 2:18 am    Post subject: Winterizing Reply with quote
Since I'm not a mechanic, and my OB's are still under warranty (twin Yamaha 40's) I take them back to the Yami dealer. His advice is to: Chang Engine Oil, Lower Unit gear oil, add Fuel stabilizer, run it through the system and Fog the cylinders. If you want to replace the plugs, do that at the beginning of the season. Then save them and use them just for winterizing again. If you are fogging an EFI engine, do not do it through the air intakes. It will ruin the air/oxygen sensors. Instead pull the plugs and spray each cylinder individually. They also change out the fuel filters, and air filters if needed.
Page generation time: 0.0854s (PHP: 29% - SQL: 71%) - SQL queries: 20 - GZIP disabled - Debug on
