Battery Isolator Test
MichaelOnTheClaraMae
City/Region: Charleston
State or Province: SC
Photos: Clara Mae
PostPosted: Thu Oct 18, 2007 7:29 am    Post subject: Battery Isolator Test Reply with quote
I know a battery isolator contains diodes that permit current to flow in one direction only. Power from an alternator and/or shore charger supplied to the power-in stud of the battery isolator flows to each of the power-out studs connected to each battery bank. Current cannot flow back from one battery bank to another battery bank.
Accordingly, there should be continuity between the power-in stud and each of the individual power-out studs. And in turn, there should be no continuity between one power out stud and another. Correct?
Thanks in advance for helping out the electrically challenged.
Michael
PostPosted: Thu Oct 18, 2007 8:10 am    Post subject: Reply with quote
Michael-
You are correct.
Here are two sources that deal with testing a battery isolator:
Installation and Test Instructions for Norco Battery Isolator
RV Doctor Question of the Month Second Question
Joe.
Photos: Clara Mae
PostPosted: Thu Oct 18, 2007 8:22 am    Post subject: Reply with quote
Mine is indeed bad and I have a replacement on order. Thanks for your help Joe.
Michael
PostPosted: Thu Oct 18, 2007 11:21 am    Post subject: Reply with quote
Consider that diode isolators cause a voltage drop of about half a volt--thus it is difficult to keep the battery fully charged.
A combiner, does not have the voltage drop, and it s a better solution for battery combining and isolation.
Photos: Clara Mae
PostPosted: Thu Oct 18, 2007 2:06 pm    Post subject: Reply with quote
I read that Bob and if I were putting together a new boat, a combiner is likely what I would use. But the Clara Mae has done great getting 5 years out of her original four 2-year batteries and always with power to spare. I have routinely run the fridge off of the two-battery bank for four plus days without recharging. So I am going to stick with the original configuration for now. Kind of a "don't fix what is not broken" approach. I, and I am sure others here on the site, appreciate the suggestion though.
Michael
Page generation time: 0.0261s (PHP: 65% - SQL: 35%) - SQL queries: 22 - GZIP disabled - Debug on
