Looking for Fix for Stuck Window
Magoo
PostPosted: Wed Apr 28, 2004 3:24 pm    Post subject: Looking for Fix for Stuck Window Reply with quote
Hi There, A while back, I remember reading a good dissertation on fixing a jammed window. Now I’m in need of the knowledge and of course don’t remember what I read. Embarassed Embarassed I tried searching the archives to no avail… Cry does anyone happen to remember the topic and care to advise??
Thank You
Magoo
PostPosted: Wed Apr 28, 2004 3:32 pm    Post subject: Reply with quote
Magoo, the diagram is here http://www.c-brat.net/modules.php?set_albumName=Cabin,Interior&id=Sticky_Side_Window&op=modload&name=gallery&file=index&include=view_photo.php
I found that if I push forward first and then back, it frees up. Sometimes I've got to use a screwdriver (carefully) to help. Use silicon on the channel
Rooster 27509
Vessel Name: Catch-22
Photos: Catch-22
PostPosted: Thu Apr 29, 2004 8:54 pm    Post subject: Reply with quote
Charlie your good.
thanks I can use this one too
Beer
UncleRichie
City/Region: Bainbridge Is.
Vessel Name: C-Critter
Photos: C-Critter
PostPosted: Fri Apr 30, 2004 12:49 pm    Post subject: Reply with quote
Hi,
When you get the window unstuck slide it back as far as you can and take a old tooth brush and a vacume and clean the fuzzy stuff in the track. Water and dirt get into that stuff and it gets like concrete, I have been doing that to mine and have had no problems since.
Richard
Magoo
PostPosted: Fri Apr 30, 2004 2:48 pm    Post subject: Reply with quote
Thanks guys, I'll let ya know if this does the trick!!
Magoo[/quote]
John J
City/Region: Annapolis
State or Province: MD
Vessel Name: John J
PostPosted: Sun May 02, 2004 9:37 am    Post subject: Silicon spray Reply with quote
I had tyhis problem too. I gave the tracks a shot of silicon from spray can. Worked like a charm!
Mike
Page generation time: 0.0826s (PHP: 36% - SQL: 64%) - SQL queries: 19 - GZIP disabled - Debug on
