hull stains
blackfish
City/Region: saltair
Vessel Name: raincoast
Photos: Raincoast
PostPosted: Sat Oct 13, 2007 5:13 pm    Post subject: hull stains Reply with quote
Hi all
we are looking at buying a used c-dory that has spent most of its life
in the water, it has bottom paint but from the pics it appears to have
some staining just above the water line
do you think i can remove these stains?
I'm not familiar with fiberglass boats our current boat is aluminum so of course staining is not a real problem
PostPosted: Sat Oct 13, 2007 6:43 pm    Post subject: Reply with quote
I'm pretty sure you can get it off. The trick is to do it without disturbing the gel coat or at least a minimum amount. Lots of traffic on the site about cleaning the hull.
PostPosted: Sat Oct 13, 2007 8:16 pm    Post subject: Reply with quote
There are many ways to clean a hull. I would start with a product which has oxylic acid as its primary ingredient. (Davis Fiberglass Stain remover gel is an excellent example)--Bar Keeper's friend and Zud, both also have oxylic acid--but contain a mild abrasive, so I would avoid them at first.
Then you want to compound the boat with a moderate rubbing compound. Then 3M Finessit, and a final coat of Colinate Fleet paste wax, and there is a good chance you will not tell the boat from new. The C Dories have an excellent reputation of gel coat quality and being able to be brought back to like new condition.
blackfish
Photos: Raincoast
PostPosted: Sun Oct 14, 2007 3:04 am    Post subject: Reply with quote
Thank you for the info
I'll try it out when we get the boat and let you now how it goes
Jeff Brigner
State or Province: TN
Vessel Name: C-Pearl
Photos: C-Pearl
PostPosted: Sun Oct 14, 2007 9:57 am    Post subject: Reply with quote
I have seen a product called "on/off" and was told it worked great and was very easy to use.
PostPosted: Sun Oct 14, 2007 8:25 pm    Post subject: Reply with quote
According to the MSDS the Mary Kate "On/Off" contains:
Hydrochloric acid: 20 to 25% by weight
Phosphoric Acid 5 to 10% by weight
Oxylic Acid 1 to 5% by weight
You want to watch the skin and eyes.
Tad and Toby Jackson
City/Region: Merritt Island
Vessel Name: Comfy Dory
Photos: Comfy Dory
PostPosted: Mon Oct 15, 2007 1:09 pm    Post subject: Hull Cleaner Reply with quote
Blackfish,
Polyglowproducts.com is the website for a company that is advertised on Ship Shape TV. I have used the products to re-finish the gelcoat on my 1995 22' cruiser and I am sold on it. The kit includes Poly-prep which is used to clean the gelcoat in general and Poly-glow which restores the shine of the gelcoat. If you have very stubborn staining near the waterline or on the transom from oil exhaust, you can add Poly-ox to the kit which did a great job on mine.
Good Luck...Tad
Photos: Comfy Dory
PostPosted: Mon Oct 15, 2007 1:13 pm    Post subject: Hull Cleaner Reply with quote
Blackfish,
I just tried to go on the website I gave you. I gave the wrong spelling! It should have been www.poliglowproducts.com with an i.
Tad
Page generation time: 0.0332s (PHP: 62% - SQL: 38%) - SQL queries: 21 - GZIP disabled - Debug on
