Canvas back storage
Jeanie P
City/Region: Alexandria
Vessel Name: Jeanie P - sold 11/08
PostPosted: Tue Sep 25, 2007 9:51 am    Post subject: Canvas back storage Reply with quote
Very Happy What do most of you do with the canvas back covers when your out motoring and don't need them? I'm thinking of getting some kind of stuff sack to roll them up in. They would be wiped down and dry before doing this.Any thoughts? Thanks
Allan
Papillon
Vessel Name: Papillon
Photos: Papillon
PostPosted: Tue Sep 25, 2007 9:56 am    Post subject: Reply with quote
We made a stuff sack out of scrap pieces of Sunbrella material we had left over from several projects and put a rope draw string in it. It works well for storing the camper enclosure. If I get tight on space, I just stick it up on top. If it gets rained on , the Sunbrella material protects the contents from getting wet as well.
Mike Taylor
330-936-1030
Ashley Lynn
City/Region: Panhandle
Vessel Name: Ashley Lynn
Photos: Ashley Lynn
I store mine on top of the water tank of my 22'. Port side aft locker.
Not much fits in there for anything else.
Bob & Nancy (Ashley Lynn)
Boating, where its ok to play with your dinghy!
drjohn71a
City/Region: Wichita
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
PostPosted: Tue Sep 25, 2007 10:51 am    Post subject: Reply with quote
Most vinyl window manufacturers recommend against "wiping" them clean. The windows should be "dabbed" clean as much as possible.
I lay out old bedsheets and lay a panel on one, fold the sheet over, then another panel on that, then roll them up and store alongside the forward bunk, up against the hull. That helps insulate the bed area, allows a place to lean on when sitting up, etc..
I am thinking of getting a large PVC pipe and rolling the window panels up on that to reduce the bending angle.
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Tue Sep 25, 2007 7:42 pm    Post subject: Cheap stuff sack Reply with quote
I went down to the local sporting goods store and bought a good qualitiy light canvas game bag (elk size), plus some real inexpensive fleece blankets from Freddy's. I just roll the side panels up between the blankets, then put them up on the vee berth. Works well, total investment under $20, and I have a couple of extra blankets if it gets too chilly.
Steve
oldgrowth
City/Region: Rochester
Vessel Name: C-Voyager
Photos: C-Voyager
PostPosted: Tue Sep 25, 2007 7:52 pm    Post subject: Reply with quote
I remove the sides and back, then fold the top back on the frame and put a boot around it. It is about 20 inches above the engine and out of the way. Easy to redeploy if necessary. The sides and back are gently folded and placed in a plastic container under the V-berth.
________
PostPosted: Tue Sep 25, 2007 8:09 pm    Post subject: Reply with quote
We do the sheets and roll it up, like Dr. John. Rolling is much better on the eisenglass than any folding. We leave it in the truck so it doesn't take up v-berth space. If we're going to be away from the truck and trailer for an extended time, the camperback stays set up on the boat - nice to have the zippered eisenglass and screens in that circumstance.
For warm weather cruising (and, yes, that's subjective), we generally leave the camperback off and run with just the bimini top. In the past year, the camperback has been ON a lot more than off.
http://captnjim.blogspot.com/
416rigby
Vessel Name: Foggy Dew
Photos: Foggy Dew
PostPosted: Tue Sep 25, 2007 8:11 pm    Post subject: Reply with quote
We bought a big duffle bag from Cabelas. All the pieces fit nicely in it and we throw it in the V-Berth. Like others, if we need the space, it goes up top.
Rick and Donna
Jeanie P
PostPosted: Wed Sep 26, 2007 8:26 am    Post subject: Canvas Camper back Reply with quote
Thanks for the replies.
I like the idea of wraping them in a blanket. I also like the Cabelas duffel bag idea to conserve space. I might incorporate the two and use both depending on day trip or longer.
Allan
drjohn71a
Photos: Tom-a-Hawk
PostPosted: Wed Sep 26, 2007 9:29 am    Post subject: Reply with quote
Yes, I think the idea of fleece blankets would be less abrasive than the old sheets. I may convert to that!
Page generation time: 0.0437s (PHP: 68% - SQL: 32%) - SQL queries: 27 - GZIP disabled - Debug on
