help, engine trouble
DAVEY5205
City/Region: TACOMA
Vessel Name: HONEY DO LIST
Photos: HONEY DO
PostPosted: Sun Sep 23, 2007 5:15 pm    Post subject: help, engine trouble Reply with quote
ok i was on the water today with the "honey do list", when i noticed my motor reving way up and no propulsion!!!!!!!!!!!!! so i slowed down and everything was great till i hit abt 3500rpm same thing, so what should i look for or how do i fix it. its a honda 40hp with 55 hours on it. Cry
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Sun Sep 23, 2007 6:37 pm    Post subject: Reply with quote
I once spun the center out of a prop....if you look at the prop you will see that there is a rubber bushing between the shaft and the body of the prop... mine spun when I was really putting power to it...but once I slowed down it took hold and I could go again.... kinda a funny feeling...
Joel
SEA3PO
mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
PostPosted: Sun Sep 23, 2007 11:38 pm    Post subject: Reply with quote
Other than something actually on the prop, or a damaged blade, then a
spun hub is the most likely answer.
Mike
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Tue Sep 25, 2007 9:23 am    Post subject: Hub Reply with quote
Ditto...sounds like a text book spun hub.
Captain Matt
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Tue Sep 25, 2007 7:47 pm    Post subject: How to check for a spun hub... Reply with quote
I would suggest pulling the prop on the suspect engine, then scribing a line across the back end. That is, put a scribed line across the metal and rubber portions. Reinstall, run it, then pull and check to see if the line is still aligned if it happens again.
Steve
DAVEY5205
City/Region: TACOMA
Photos: HONEY DO
PostPosted: Fri Sep 28, 2007 1:02 am    Post subject: Reply with quote
thanks for the info
Page generation time: 0.0308s (PHP: 56% - SQL: 44%) - SQL queries: 23 - GZIP disabled - Debug on
