Kicker Autopilot
Island Ranger
City/Region: Whidbey Island
C-Dory Model: R-25 Tug
Vessel Name: Island Ranger
Photos: Two Lucky Fish and Island Ranger
PostPosted: Fri Sep 21, 2007 9:00 pm    Post subject: Kicker Autopilot Reply with quote
I'd like to add remote steering to the 9.9 kicker on the back of Island Ranger - R-25. I can't connect to my Raymarine system, cause I can't figure a decent way to connect the rudder to the kicker.
One extra requirement - I want to be able to remove the kicker from time to time. I don't plan to leave it on the boat and I move it from the swim step to the rail each time I use it. So...
Is easy to remove the TR-1 Gold autopilot? The pictures I've seen make it look quite difficult..
Has anyone any information about the Panther remote steering?http://www.cabelas.com/prod-1/0043168014744a.shtml
How about the TrollEze? http://www.goetztroleze.com/
Mac
Ron on Meander
City/Region: Powell River
Vessel Name: Meander
Photos: Meander
PostPosted: Sat Sep 22, 2007 12:30 am    Post subject: Reply with quote
Mac,
I have the TR 1 gold on my 9.9. It works fine and is a real help when fishing alone. I don't think it would be easy to rig it up for quick removal. Because it has hydraulic as well as electrical connections you'd have to rig quick disconnects for both. Its probably doable but more work than its worth.
Ron
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Sat Sep 22, 2007 11:49 am    Post subject: Reply with quote
I had a TR-1 on my Hewescraft. I was told by the factory after I had it (the TR-1) repaired that I should disconnect it when trailering (trailering caused the damage). I sold it right after that so I am not sure how you disconnect it, but I would recommend talking to the factory guys. Before they were bought out by Garmin they were very accessible and helpful. Dunno about now.
Doryman
M/V Lori Ann
Anacortes, WA
flapbreaker
City/Region: Hillsboro
Vessel Name: Playin' Hooky
Photos: Playin' Hooky
PostPosted: Sat Sep 22, 2007 12:54 pm    Post subject: Reply with quote
Ron on Meander wrote:
Mac,
Ron
I second what Ron said about the TR-1. I dont' have any experience with the other products.
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Sun Sep 23, 2007 3:44 am    Post subject: Reply with quote
Mac,
I would bet that you could put "Fuel Line" quick connects on the hydraulics for the TR-1. I have to wonder though how often you would end up having to bleed the system.
IFISH.Net has a thread that used to be watched by the guys at TR-1. You might ask your question there.
Gary Johnson
KB7NFG
Island Ranger
PostPosted: Sun Sep 23, 2007 11:30 am    Post subject: Reply with quote
Thanks Gary -
Someone already asked my exact question on Ifish - and yep, they say they offer quick disconnect fittings. Hurray!
Now..to start saving my pennies...
Mac
flapbreaker
PostPosted: Sun Sep 23, 2007 12:59 pm    Post subject: Reply with quote
Mac, don't forget that the TR-1 also has throttle control so you will have to route and re-route the wire each time you take it off. Maybe it won't be a big deal though. Just depends on where you mount the pump I suppose. Mine's mounted in the lazerette.
gljjr
C-Dory Year: 1982
Photos: gljjr
Mac,
You might consider locking the kicker straight ahead and using the big rudder. If that works you could then just get the TR-1 Gladiator instead. Then you can use it for fishing AND cruising. Wink
Island Ranger
PostPosted: Sun Sep 23, 2007 1:26 pm    Post subject: Reply with quote
Is the throttle connect an electric or mechanical connect? I'm assuming I can use quick connects for electrical as well as hydraulic. I already have to deal with the electric start / battery connect anyway, but if the throttle is a mechanical linkage, this could get complicated
I tried locking the motor and steering with the rudder - doesn't work. Not enough control - the rudder only works at low speeds when the prop is pushing water to it....
Mac
Ron on Meander
Photos: Meander
PostPosted: Sun Sep 23, 2007 3:27 pm    Post subject: Reply with quote
The throttle connect is electrical. It is the only electrical connection to the kicker from the TR!. The other is the two hydraulic hoses. If you can get quick disconnects from TR than it should be straght forward. Hell the #$#%&*******'s that stole my first 9.9 didn't even need the quick connects to remove the kicker in a hurry! They just cut everything off. Of course the reconnecting was a bit of a pain.
Ron
Page generation time: 0.0389s (PHP: 64% - SQL: 36%) - SQL queries: 23 - GZIP disabled - Debug on
