Sonar(FF ?) For Dinghy
Adeline
City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
PostPosted: Thu Aug 30, 2007 7:22 pm    Post subject: Sonar(FF ?) For Dinghy Reply with quote
I've only had my inflatable dinghy out one trip but some kind of sonar seems desirable. Beaching her on the Columbia has taught me that I can't read the bottom with my aging eyes. What are my options since I don't have a battery to tap(Johnson 4). I came across this after a brief google search. Integral battery and suction-cup mount transducer. Is this the way to go ?
Pete
Adeline
Photos: Adeline
PostPosted: Thu Aug 30, 2007 7:31 pm    Post subject: Reply with quote
Or This ?
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Thu Aug 30, 2007 7:52 pm    Post subject: Reply with quote
FWIW, I know a lot of float tube fly fisher types who like the fishing buddy.
Doryman
M/V Lori Ann
Anacortes, WA
Pigman
State or Province: DE
PostPosted: Thu Aug 30, 2007 8:40 pm    Post subject: Reply with quote
We use a Humminbird Piranha max 210 Portable in a 14' inflatable. We use a small motorcycle battery in a plastic box for power. Gives us 3 full days of fishing before I recharge. Unit sits on seat or cooler and transducer clips to a small bracket on the transom. It's worked well enough for the last 3 years fishing salmon in Alaska.
Big dave
Vessel Name: Raven Dancer
Photos: Raven Dancer
PostPosted: Thu Aug 30, 2007 8:55 pm    Post subject: Reply with quote
I use a 4 oz sinker on a 5' piece of fish line i'm about 6'2" so if the sinker don't hit bottom............Stay in the dingy.
Low tech, nothing to maintian, cheap to replace, and it can fit in yer pocket !
Big Dave. Laughing [/img]
PostPosted: Thu Aug 30, 2007 10:23 pm    Post subject: Reply with quote
We have used a setup similar to Pigman, but with both Hummingbird and Interphase depth sounders and the small motorcycle or garden tractor batteries. Mounted the FF under the passanger's hard thwart.
PostPosted: Fri Aug 31, 2007 8:25 am    Post subject: Reply with quote
Try a boat hook. Waterproof, cheap and multi-tasking. Also good for pushing off when you screw up. When you're in shallow water, with rocks and weeds, a sonic depth sounder tends to give false readings.
Worked for us for years, and never runs out of power.
Doryman
Photos: Lori Ann
PostPosted: Mon Sep 03, 2007 2:45 am    Post subject: Re: Sonar(FF ?) For Dinghy Reply with quote
HERE is something I found recently that might meet your needs (as well as mine!)
Page generation time: 0.0502s (PHP: 66% - SQL: 34%) - SQL queries: 21 - GZIP disabled - Debug on
