Adeline
Joined: 03 Nov 2003 Posts: 985 City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
Posted: Sat Aug 11, 2007 2:23 am Post subject: Water Tank Level Gauge |
I came across these electronic water tank gauges and wondered if anyone uses them. The neat thing is they rely on external sensors so the installation is simplified and they can't be fouled by waterborne debris. I'm looking at the "Smart Mini". _________________ Pete
Alyssa Jean
Joined: 02 Nov 2003 Posts: 2376 City/Region: Guemes Is.(Anacortes)
Vessel Name: Alyssa Jean
Posted: Sat Aug 11, 2007 10:19 am Post subject: |
Looks like a great way to keep track of your tank. The problem will be to get to the tank to install the exterior sensor tape and senders.
Smart Mini LED Kit (includes moda, tape and installation guide) $129.95 _________________ David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51 |
colobear
Photos: C-Cakes
Posted: Sat Aug 11, 2007 11:10 am Post subject: |
Looks very sophisticated. My water gauge, on the other hand, is extremely unsophisticated. With the boat level, I drained the tank, filled it with a known quantity of water in 5Gal increments, and labeled the vinyl tube with a tape labeler at 10, 15, and 20 gallons. Incidentally, anything less than 10 gallons does not show on the vinyl tube. _________________ Patti and Barry
formerly C-Cakes, now
rving around N. America |
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
Posted: Sat Aug 11, 2007 1:56 pm Post subject: |
colobear wrote: | Looks very sophisticated. My water gauge, on the other hand, is extremely unsophisticated. With the boat level, I drained the tank, filled it with a known quantity of water in 5Gal increments, and labeled the vinyl tube with a tape labeler at 10, 15, and 20 gallons. Incidentally, anything less than 10 gallons does not show on the vinyl tube. |
Are you talking about a rigid tube inserted through the fill that you would put your thumb over the upper end and lift out? Same idea as a straw and a glass of water? Where did you get the tubing and how long does it have to be?
M/V Lori Ann
Anacortes, WA
colobear
Photos: C-Cakes
Posted: Sat Aug 11, 2007 3:17 pm Post subject: |
Warren,
I am referring to the vinyl tube installed at the factory from the bottom of the tank. It has a 90 degree elbow and extends up about 3 feet right next to the port side cabin door frame. I believe its official function is to serve as an air intake so water can be drawn out of the tank without creating a partial vacuum. As water seeks its own level, I use it to determine the level of water in the tank. It is about 1/2" ID and clear. I will be happy to take a picture and post it if that would be helpful. |
Doryman
Photos: Lori Ann
Posted: Sat Aug 11, 2007 5:07 pm Post subject: |
Colo, thanks, but that might not be helpful for me as I have a different boat. I am not sure whether the TC is set up with a similar tube or whether it is accessible.
Warren |
Dora~Jean
Joined: 09 Mar 2004 Posts: 1518 City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
Posted: Sat Aug 11, 2007 5:46 pm Post subject: |
I put a hatch in front of my tank (max corrected to 16 3/4 gals -- tank installed on a bias), or you could use a 1/2" or so slot. Not sure where your tank is though, might not be suitable.
 _________________ Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
+4 Previous, 1/2 sail, 1/2 power |
Joined: 02 Nov 2003 Posts: 21497 City/Region: Pensacola
Posted: Sat Aug 11, 2007 7:05 pm Post subject: |
Colobear, I would be interested in the photo of the tube. My 22 didn't have such a tube. The vent is usually at the top of the tank. A vent under the water, would cause a partial vacuum when water was withdrawn. Maybe this was put in as a "guage"?
Steve, interesting that the "20 gallon" water tank will only take about 16 3/4 gallons. I wounder if you relocted the vent, if you could at least get 20 gallons in it? I picked up a 35 gallon bladder tank for the CD 25, looks like a good "investment" if the boats only carry 16 gallons! _________________ Bob Austin
CAVU
Vessel Name: CAVU
Photos: CAVU
Posted: Sat Aug 11, 2007 8:38 pm Post subject: |
On my 2002 the plastic tube must be a rudimentary gauge. I think the vent is to the outside of the hull near the fill. _________________ Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas |
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
Posted: Sat Aug 11, 2007 8:42 pm Post subject: |
I also have the factory installed vinyl tube like Colobear's. Works fine, though if I fill too vigorously it'll spurt a litle water into the cabin. Much less expensive than the electronic version and pretty darn accurate.
Don _________________ Mary & Don Anderson
Brat #483
"C-Brat" 1993 C-16 angler/50 hp |
Doryman
Photos: Lori Ann
Posted: Sat Aug 11, 2007 8:56 pm Post subject: |
Bob, what would be required to get access to the water tank on the TC for the same purpose?
Warren |
Posted: Sat Aug 11, 2007 9:04 pm Post subject: |
For any of you who were's around the last time we discussed the water level sight tube, you might want to peruse through these two threads.
Fresh Water Level on a 25?
and
Water Tank Gauge
Dr. Bob will have to address the feasibility/difficulty of adding a water level sight tube to the innards of the TC 255!
Adeline
Photos: Adeline
Posted: Sat Aug 11, 2007 9:51 pm Post subject: |
Quote: | For any of you who were's around the last time we discussed the water level sight tube, you might want to peruse through these two threads.
| Boy, Joe, that's embarrassing. 2 1/2 years ago I was tossing out these gauges for feedback and I'm still in "ANALYSIS PARALYSIS". I guess that's why I'm single. I could never commit to a long term relationship...EXCEPT TO ADELINE. |
Posted: Sat Aug 11, 2007 10:33 pm Post subject: |
Pete-
Don't wory about it! We're still having fun, no?
I've gone cyclical myself on a few issues and come back to find myself standing in the same place scratching my head more than a few times!
Just means it's a problem worth reconsidering.
Maybe this time we'll get it right!
DeJa Vu!
Joe. |
colobear
Photos: C-Cakes
Posted: Sat Aug 11, 2007 11:37 pm Post subject: |
I'll get a photo up tomorrow. Yup, a vent would have to be above the waterline so it must be a rudimentary gauge.  |
