Carb cleaning advice?
snal
City/Region: Asheville
C-Dory Year: 1994
Vessel Name: Thelma Lou
Photos: Thelma Lou
PostPosted: Thu Aug 09, 2007 7:12 am    Post subject: Carb cleaning advice? Reply with quote
I hope to have the pleasure of dealing with some carb cleaning issues this saturday. My (soon to be) C Dory has twin 45 Hondas, one of which seems to need this attention.
A fellow "Brat" has generously offered advice, so here's my plan...
1st...hook the engine up to a clean, portable fuel tank with fresh fuel, treated with stabil, and/or other additives, and check any filters for debris/water. 2nd....use aerosol carb cleaner on each carb. 3rd....go all out with a full tear-down of the carbs for thorough cleaning.
Any other suggestion would be much appreciated!
Snal~
(Larry and Jo)
1994 C Dory 22 Angler (sold 2012)
Currently looking for a steal of a deal on a 25' "Thelma Lou II"
C-WEED
City/Region: New Brockton
State or Province: AL
Vessel Name: C-Weed
Photos: C-WEED
PostPosted: Thu Aug 09, 2007 12:06 pm    Post subject: Reply with quote
I would also drain the float bowls, one at a time into a clean container for inspection. Very much water might be concern to clean the fuel tanks. Don’t forget to check the tank vents to make sure they don’t point forward. The presence of very much sediment might be reason to pull each float bowl for a good cleaning. If you don't know the past history of the operation vs. sitting for long periods you might just pull one of the float bowls to see how much varnish has formed. If much has formed the added conditioners may loosen it and then plug up the passages later. Nothing worse than having erratic engine operation when you really want to be out cruising. Especially with your new boat.
Good luck
Chris
snal
C-Dory Year: 1994
Photos: Thelma Lou
PostPosted: Thu Aug 09, 2007 1:48 pm    Post subject: Reply with quote
Thanks Chris! 1994 engines with 320 hours will likely mean varnish at the least.
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Thu Aug 09, 2007 3:01 pm    Post subject: Reply with quote
While you may be lucky and have the fuel treatment work. I would guess that you will need to simply pull the carbs from the get go if it has been sitting for any period of time. Especially if the motor already seems to be running bad.
BTW: Congrats on the new(to you) Boat!
Gary Johnson
KB7NFG
snal
C-Dory Year: 1994
Photos: Thelma Lou
PostPosted: Thu Aug 09, 2007 6:02 pm    Post subject: Reply with quote
Thanks for the advice Gary! Congrats are a bit premature, but much appreciated (only 42 more hours!).
I've rebuilt carbs before, but I'm not very familiar at all with getting them in sync. once they are back on. Or will I have to re-sync them? Never worked with multi-carb stuph. I suppose my first step should be to purchase a manual for these engines.
gljjr
C-Dory Year: 1982
Photos: gljjr
PostPosted: Thu Aug 09, 2007 7:05 pm    Post subject: Reply with quote
In Beartracks thread I posted about how I used to do multiple carb syncing. I used to use 2 (or more) cheap vacuum gauges rather than an expensive carb stick. They work just fine. I also used to use one of these (sorry for posting a link to an ebay add, I just don't know where to find them anymore).
This would probably work pretty well on a boat where it might be hard to find a vacuum port.
Do a google search on syncing carbs. There are several pages on this for motorcycles. The process would be the same on the outboard.
Sea Angel
Photos: Sea Angel
PostPosted: Thu Aug 16, 2007 4:32 pm    Post subject: Reply with quote
snal-
The device that was pictured on the e-bay site is called :
UNI-SYN
Multiple Carburetor Synchronizer
Model-A
It cost $10.95 in the early 60s.
The manufacturer is:
EDELBROCK EQUIPMENT CO.
LOS ANGELES, CA 90016
www.edelbrock.com
check under 'carbs& access.'
They are still in business.
These are used to first set the vacuum draw at idle with the linkages disconnected. The balance is done with the throttle-stop-screws; so the additional carbs are 'balanced' with the same vacuum indication as your reference carb by watching the red float in the glass tube as you adjust their respective throttle-stop-screws.
When you reconnect the linkage, this same procedure can be used to match the linkage. It is all about balance so each carb draws the same amount of air.
Hope this is helpful and not too wordy.
Art ka1rx
CBRAT #208
USCGAUX (RET), USN(RET)
Broadcast TV ENG(RET)
ka1rx@verizon.net
SKYPE: Art.Bartlett4
snal
C-Dory Year: 1994
Photos: Thelma Lou
PostPosted: Thu Aug 16, 2007 4:55 pm    Post subject: Reply with quote
Very helpfull thank you! I haven't had time to tinker with them yet, hopefully next week.
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Thu Aug 16, 2007 10:25 pm    Post subject: Reply with quote
Snal, check the Honda service manual (get it somewhere). I'm not familiar with the Hondas but my Yami 80's have vacuum ports to hook up either a single vacuum gauge that you move from carb to carb (must replug when thru with that port of course), or, buy cheap auto vacuum gauges and hook all up at the same time (best method). I tuned many an SU carb with my Unisyn, but access to the carb throat inlets is not possible with my engines.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
PostPosted: Thu Aug 16, 2007 10:29 pm    Post subject: Reply with quote
Definitely drain the float bowls first. Mine had a bunch of stuff in them
that I avoided running into the carb bodies.
Mike
Page generation time: 0.0575s (PHP: 46% - SQL: 54%) - SQL queries: 23 - GZIP disabled - Debug on
