Posted: Mon Aug 06, 2007 5:56 pm Post subject: Installing a radar arch |
All,
I'm finally getting around to installing the radar arch that I bought at the factory garage sale in Jan and the used radar that I bought a month or two later. I've already positioned the arch where it needs to be and drilled the holes in the roof to attach the base of each leg to the roof. I've also done a test fit to see if the cable from my Furuno 1712 will fit through the currently existing hole in the cross member (it won't) and though the arch in general (it will fit through the tube but I am fairly certain it won't make the bend). Before I complete the installation, I have a few questions...
1) Since the cable won't make the bend in the radar arch, I am left with cutting a slot in the tubing just below the bend or on the corner at the top. I'm leaning towards cutting a long slot (2-3") just below the bend on the inside of the bend.
a) does this make sense or is there a better way?
b) How to cut a decent slot in the side of stainless steel tubing? I have a normal collection of tools but am not sure on how to approach this.
2) What should I use a sealant to seal the holes in the roof? I was planning on 5200 but recent posts from Bob Austin in another thread (vague memory) make me think maybe I should use a more standard silicone.
3) I am also thinking about spacing the bases a bit off the roof with perhaps a silicone pad that is slotted or even some stainless washers. The though is to leave room for water that condenses or otherwise finds it's way inside to escape. Another option is to drill a small hole through the tube at the low side of each support base. Again I have a vague recollection of someone complaining about water collecting inside the radar arch legs - comments, thoughts?
4) Any other gotcha's I should consider?
The radar arch was purchased as much for the radar as for the rocket launcher rod holders so the simpler PVC pipe mount that Bob Austin is fond of is not what I'm after. Advice on how to best install what I have would be much appreciated. _________________ Roger on Meant to be |
drjohn71a
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
Posted: Mon Aug 06, 2007 6:43 pm Post subject: |
Hey, Roger,
'Good to hear about the radar arch improvement. Here are some of my thoughts:
1 - It's difficult to cut cleanly into Stainless steel with ordinary tools - maybe grinder, but a plasma cutter is the best. Maybe some shop would consult and do the cuts. Do you have to cut into the arch? Could you just run the cable in a sheath outside the arch?
2 - I believe 4200, or silicone on non-submerged parts, is the sealant of choice on a removable item, but you're probably going to leave the arch in place a long time and 5200 is not too bad to get off a small flat area. They advise sealant only on the outside roof area so any moisture that gets thru that shows up in the cabin and you can fix the leak before wood damage occurs. Sealing the bottom could accumulate water.
3 - My arch has holes thru into the cabin at the leg bottoms. Anywater can leak thru that, I guess. You could line those holes with epoxy.
If you can, I'd mount it flat and sturdy on the roof with no overhangs for maximum strength. Is it too wide to fit that way?
Good Luck on the Mod' - I'm certain you'll get the info you need,
John |
Joined: 02 Nov 2003 Posts: 21375 City/Region: Pensacola
Posted: Mon Aug 06, 2007 7:23 pm Post subject: |
Basically I agree with Dr John. I am not a fan of silicone as a beding compound, but it can be a sealant (see below) The only place that Boat life Life Caulk (which is a combination silicone and urethane)--is when putting plastic items onto decks etc. Never under SS. Plain silicone has very few uses in the exterior of the boat.
I advocate coating the inside of the holes you have drilled with epoxy--best to route out the first 1/8 to 1/4" of the balsa core, and then fill this with thickened epoxy, then redrill the hole the size as the bolt. (No screws for radar arches!) The sealant of choice would be 5200. Secondary is 4200. If you can get the fittings in the tubing, then you should be able to get them around the bend. (Use the lubricant which is used for fishing wires in conduit (steel or PVC). You want to both push and pull. Secure the pulling "tape" around the cable exterior with tape, not to the radar fitting. (plus you probably will pull the cable up from the cabin which has not fitting on the end which attatches into the radar dome in the Furuno. Don't put a spacer or pull the arch off the top of the boat--bed it properly and leave it there.
If you seal the holes in the arch, and keep them under the SS tubing, there is little chance of getting water in the tubing. Now for sealing the hole where the various cables into the SS tubing--that may be a place for a good silicone sealant.
Roger, you don't like my commode flange fittings and PVC radar support? Wateproof, cheap and durable. We did this on a trawler about 8 yrs ago, and it is still working perfectly. That boat has done the loop plus--well over 20,000 miles. It all started when a visiting trawler owner couldn't find the proper tubing and fittings at our local metal scrap yard. I came up with the PVC pipe idea, and we developed it from there. Actually I started using the PVC pipe 4" 45 degree "el's" for holding wind instruments and speedo on racing boats back in the 60's...Some manufacture picked up on this and made the first pods...So it is not really a new idea.
Looking foreward to photos of the project as it evolves. _________________ Bob Austin
Posted: Mon Aug 06, 2007 7:36 pm Post subject: |
Thanks for the advice. The fitting will fit in the tube but it is about 1.5" long and won't clear the bends. I'm am also considering just running it on the outside of the tubing and then bringing it in under the side overhang of the roof. That would be easiest but not as aesthetically pleasing ( I mean if I ugly up my 22, I might as well buy a 29... )
I not criticizing your mount, it just doesn't have space for 4 rod holders on it.... I was just trying to cut-off others in advance who might suggest that I should solve my radar arch problem with a non-radar arch solution. I also know that I could entice (entrap) you into replying if I mentioned your mount and your advice is highly valued (pretty tricky, eh?).
So, I'll use 5200 to seal it. The roof, I believe is fiberglass coated plywood (not balsa core) - am I wrong on this? Either way, epoxy filling would be good. Do you have a recommended epoxy brand/type? |
Posted: Mon Aug 06, 2007 9:16 pm Post subject: |
Roger,
I don't claim beauty and the whole Commode radar mounting is a great laugh for use--especially when folks ask us how they are made--now if you want the "improved model" with 8 PVC rod holders attatched, that can be arranged....
Roger, have you looked at fishing the radar end of the cable thru the tubing? As I recollect on the 1715(the 1712 was the predicessor) has a smaller diameter connector on the radar end of the cable. Even if you had to round some of the plastic fitting corners, it should fit into the tubing.
Although you could run the cable outside or cut the tubing with a grinder, I would really advise against that, unless it was the last resort. You can use a cable clam to give a water proof route thru the roof. |
Joined: 07 Nov 2003 Posts: 7932 City/Region: marysville
Posted: Tue Aug 07, 2007 12:49 am Post subject: |
roger. I had a hard time getting my cable thru the tube, both the bends and the slot at the radar. I had to cover the fitting with tape and form it in to a point. Then I taped it to a metal wiring tape thing( sorry cant remember the right name. ) its a stiff metal tape for pulling wire. If you need help I could come down this week and lend a hand after work. _________________ Thomas J Elliott
Joined: 23 Oct 2003 Posts: 5328 City/Region: Warrenton
Posted: Tue Aug 07, 2007 1:13 am Post subject: |
Quote: | The roof, I believe is fiberglass coated plywood (not balsa core) - am I wrong on this? |
Roger, I do believe your roof is glass through and through. No coring in the post-86 CD22 roof that I know of. It's about 1/4" thick.
When I had my Furuno that went haywire, I suspected the cable because the sheathing had been cut/torn. I asked a shop about cutting the thing because the bad spot was near one end and refitting the connector. He said it wasn't worth trying because of one "optical" cable (his words) that was near impossible to reconnect. So he sold me a new cable for $110. Then I talked to one of the electrician nerds at work and he said there wasn't a cable, optical or otherwise, that he and a handful of other electrical nerd types at the mill could not repair and I should have brought it to him. Surely you have some electrical nerd types in some lab there at that fancy place you work? I say whack the damn thing off, shove it where you want it, then challenge your most trusted nerd to the task of repairing it.
So sure am I that the guy you trust is capable of making it work I will give you the $110 cable for nothing if yours gets fouled up. I think the 1700 series uses the same signal cable as the 1600 series Furuno, but you may want to compare part numbers before whacking. However, if you foul up and get a dork instead of a nerd to do your splicing, then the cable goes for garage sale price of fifty bucks. There is a fine line between nerd and dork, so choose wisely. _________________ TyBoo Mike
Sold: 1987 22' Cruiser |
Posted: Tue Aug 07, 2007 1:40 am Post subject: |
TyBoo wrote: | There is a fine line between nerd and dork, so choose wisely. |
Ah... this reminds me of the "Lest we forget DaNag and Tyboo" thread.
(of course when things really matter - we're all lucky they don't forget us - thanks for the offer Mike) |
Not For Hire
Joined: 20 May 2004 Posts: 347 City/Region: Cadillac, MI
Vessel Name: Not For Hire
Photos: Not For Hire
Posted: Wed Aug 08, 2007 10:08 am Post subject: |
Hi Roger,
I have the low model arch. I installed the arch. One year later installed the radar. On the reinstall I removed the arch altogether to pull the bulky cables through and because it was leaking rain around one of the bases. I did push/pull the radar cable through the pipe with a nylon cord pulling and me pushing. I had the fitting taped, I had the various other wires running through the arch taped to the cable behind the fitting. When I then reinstalled the arch on its four feet I used 4200 caulk and I also put a disk of neoprene between the arch and roof and another disk between roof and backing plate. The neoprene compressed and with the new caulking = no leaks. Don't know how long it will last but so far so good. I got the neoprene by cutting up an old dive suit.
Regards to you and thanks for your past help,
Mark _________________ Mark S
Cadillac, Michigan |
Posted: Wed Aug 08, 2007 10:33 am Post subject: |
A brief update:
1) Tyboo Mike is right of course the roof is simply fiberglass so no epoxy needed. If I had paid more attention while I was drilling, I would have known this.
2) I did manage to get the cable through the radar arch. Even the small end of the cable was too large to go through the round hole in the tubing and make the turn but after the encouragement of you all (a "Patrickism"), I decided that it likely would make the bends. Hence, I went out this AM with a dremel tool and 30 mins and 4 cutoff wheels later, enlarged the hole in the tubing to a nice slot through which I could get the connector. Just a little pushing, and the cable came through.
3) Tonight, I'll complete the job, I'll bed the feet in 5200 and run the wiring for the all around light down one leg and the radar down the other. The front two legs are in tubing with no holes in it, so I'll just seal them off with some 5200 when bedding the feet. I couldn't find stainless steel 1/4-20 bold that where short enough (need 5/8-3/4") so I'll have to cut some 1.25" ones down. Need to pick up a 1/4-20 dye tonight so I can be sure I don't bugger up (a "Tybooism") the threads too much. I think if I just put a nut on the end of bolt and use the cut-off wheel to cut flush with the nut, I'll be OK. Probably will go through another 4-6 cut-off disks, but there cheap and I have about 30 of 'em. |
drjohn71a
Photos: Tom-a-Hawk
Posted: Wed Aug 08, 2007 10:51 am Post subject: |
Roger,
You could run a VHF antenna wire or two thru while you are at it. They put two on mine - one for VHF and one for FM.
Glad to hear you conquered the problem!!!
John |
Posted: Wed Aug 08, 2007 12:46 pm Post subject: |
Rogerbum wrote (stuff clipped):
" I couldn't find stainless steel 1/4-20 bold that where short enough (need 5/8-3/4") so I'll have to cut some 1.25" ones down. Need to pick up a 1/4-20 dye tonight so I can be sure I don't bugger up (a "Tybooism") the threads too much. I think if I just put a nut on the end of bolt and use the cut-off wheel to cut flush with the nut, I'll be OK. Probably will go through another 4-6 cut-off disks, but there cheap and I have about 30 of 'em."
Cutting off bolts and machine screws needn't be too complicated. Here's a trick that so simple it evades discovery.
Take the longer than necessary bolt/screw and put a nut on it all the way up to the head or end of the threads.
Clamp the end to be cut off in the vice.
Cut off the bolt/screw where desired. Even a hacksaw is good here. No need for a precision tool.
Now go to a grinder and gently smooth off the end of the cut and round down the threads at the end at a 45 degree angle to provide a taper.
Now back the nut off the bolt/screw slowly over the end and the tapered threads several times to straighten them out.
This will eliminate the need for a die, and you won't have to buy dies for all the common thread patterns, although it's great to have a good tap and die set.
Incidently, you can get an inexpensive 60 piece tap and die set from Harbor Freight Tools for $21.95 HERE.
The T&D set can save you some money and time. We broke off the end of a $130 reverse cable on our jet ski the other day, and I was able to re-thread the end of the broken rod and add a barrel nut and some threaded stock and re-use the original cable: Savings: $128 + quite a bit of time!
Grumpy
Joined: 10 Oct 2005 Posts: 1607 City/Region: Whidbey Is
Vessel Name: Kingfisher II
Photos: Kingfisher
Posted: Wed Aug 08, 2007 12:53 pm Post subject: |
Roger,
If you are already going to the trouble of cutting bolts to the right length, I would suggest you fit a washer and a dome nut. It makes a nicer looking finish.
Merv |
McMike
Joined: 16 Feb 2008 Posts: 31 City/Region: Hampton Roads
Posted: Sat Mar 01, 2008 10:52 am Post subject: |
TyBoo wrote: | Quote: | The roof, I believe is fiberglass coated plywood (not balsa core) - am I wrong on this? |
I'm going to stick my newbie neck out here. Before I retired from the Navy last year I was a radar tech for 16 years. Be careful with cable fixing. While all said is 100% true, there are caveats. When dealing with RF cable length becomes an issue as a function of wavelength. While I'm used to long range military radars and just now diving into the recreational civilian versions, radar principals are pretty much the same. Also, fiber optic cables are VERY difficult to splice and there are some pretty tight tolerances for loss. Can it be done? Of course it can. I work with fiber regularly now and I'm here to tell you we don't splice; we just replace it. It's more cost effective.
If I'm completely off my rocker somebody let me know!
Mike _________________ McMike
Lifetime Sailo |
Posted: Sat Mar 01, 2008 10:59 am Post subject: |
McMike wrote: | TyBoo wrote: | Quote: | The roof, I believe is fiberglass coated plywood (not balsa core) - am I wrong on this? |
Mike |
Right on Mike and welcome to civilian life. I was an ETN back in my early Navy days, not an ETR though. I just bought a 4KW Raymarine system with the 5 meter cable vice the 15 meter cable. I asked a Raymarine Tech through the website if I'd have timing issues and he said that he didn't think so but to check for sure, take a look a couple of miles away at a straight bridge. If it looks straight on the display, it's OK, if not, things need to be adjusted.
K4KBA |
