Moisture
dchurch3
City/Region: Mukilteo
Vessel Name: C-Cruiser
Photos: C-Cruiser
PostPosted: Thu Aug 02, 2007 1:55 am    Post subject: Moisture Reply with quote
I am still considering the purchase of a C Dory and am wondering what the moisture problem is that some have referenced? Whats the cause and how is it dealt with?
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Thu Aug 02, 2007 2:00 am    Post subject: Reply with quote
So far have not experienced any condensation to speak of after cruising with the Tom Cat. Might be different in the fall.
Doryman
M/V Lori Ann
Anacortes, WA
PostPosted: Thu Aug 02, 2007 2:46 am    Post subject: Reply with quote
Dave-
There are two condensation problems commonly experienced in these boats:
1.) Condensation on the windows when underway in rain, snow, and other cold, moist situations, and..
2.) Condensation on the inside walls of the cabin from moisture originating from breathing, which is especially noticable when sleeping in the boat at night.
The windows problem requires two or more fans placed near and directed on the front windows, and can be helped greatly by the use of a cabin heater to raise the ambient temperature. Additionally, all really safe cabin heaters that burn fuel of some type are externally vented, so 1.) the combustion moisture from their burning fuel is vented outside the cabin, and 2.) they help eliminate cabin moisture through their use of air for combustion. Window condensation at rest can also be controlled somewhat by an electric heater when on shore power, but some provision must be made to vent some cabin air to eliminate excessive moisture. Also, RAIN-X and others make solutions that can be placed on the inside of windows to limit condensation, much in the same way they do on diver's masks.
Condensation on the walls, particularly at night during sleeping, produces the "Wet Cave" effect! Moisture from respiration can amount to a liter or more per person (if I remember Dr. Bob's post correctly). Condensation of this water vapor into liquid on the cabin walls and windows in cold weather is bothersome and unplesant to say the least. Several possible solutions are possible, and often they're used in combination.
A.) Open (crack) a window for ventilation to let some of the moisture out.
B.) Run a heater to keep the temperature up and help remove moisture as it uses up cabin air for combustion. (Second half not applicable to electric heaters.)
C. Spray foam insulation (See the "Pain Free Insulation Solution" thread by B~C), or cover the inside of the cabin with carpet or special insulation padding that can be applied to the walls with spray adhesive. These help to eliminate the cold surfaces that help support condensation.
D. Treat the windows with RAIN-X as above.
E. Draw straws or play Strip Poker with the looser sleeping and breathing out in the cockpit! Laughing NOT!
It helps to have a good heater on board with at least two if not three or more 12 volt fans to move the air around and in and out. I like to have some of them moveable (mounted to Stanley squeeze clamps) so that they are adaptable to different uses. I also like two or three speed ones, and fans that can be set to either oscillate back and forth or remain stationary.
One other point: Going in and out of the cabin to an uncovered cockpit in the rain brings moisture into the cabin in such amounts that you may not be able to keep up with eliminating it. Best to fish with a covered cockpit in those conditions!
Generally, however, condensation on a C-Dory is mostly just an annoyance, and can be delt with effectively with a little thought!
HTH!
Joe. Teeth
PostPosted: Thu Aug 02, 2007 10:04 am    Post subject: Reply with quote
Just a quick addition to what Joe said.. It's important to note that this type of problem - e.g. condensation from moisture while breathing - is a general problem with all boats of this size and similar construction. Unless you have a lot if insulation, simply breathing in a small volume generates moisture. Most of us lose about 1 pound of water weight each night which is about a pint of moisture into the air (weigh yourself just prior to going to bed and just after waking up). In a big volume, this amount of moisture goes unnoticed or can be held in the air. In a small volume (like a v-berth), it's very noticeable. As Joe says, the best solution is ventilation + a little heat (when it's not too hot).
Sarge
City/Region: Edmonds
Vessel Name: Sea Badger
Photos: Gigi
PostPosted: Thu Aug 02, 2007 10:29 am    Post subject: Reply with quote
Dave,
I'm just down the shore from you in Edmonds, where my boat sits in the water 24/7/365.
If you want to SEE how I avoid the moisture problem, then send me a PM and I'd be glad to show you my boat and speak to you in person about my experience.
For conversation sake, moisture in a boat is a common issue. Everything I use to keep it in check is available through West Marine or advertised in SEA magazine. They are common items in the boating world.
-Sarge
2001 2150 Bayliner, sold
2007 CD25, sold
2007 Harbercraft Kingfisher 2850, sold
2011 Stabicraft 2250SC, sold
2011 Eastern 18cc
Blog: http://theseabadger.wordpress.com
View user's profile Send private message Visit poster's website AIM Address
PostPosted: Thu Aug 02, 2007 11:03 am    Post subject: Reply with quote
Just thought of another issue, which the effect of condensation when the boat is unoccupied, either moored or on the trailer.
Condensation left alone in an empty boat can lead to mildew (mold/fungus) problems.
There are several ways to deal with this, again utilized alone or in combination:
The main solution is to provide for ventilation.
This can be done with either a solar/electric powered vent:
or a passive vent, operating with with the action of simple convection currents (moving of warm air) inside the boat during the daily heat cycle:
cowl vent, used more commonly on larger boats, and with dorade box underneath to eliminate rain water as well as spray underway.
C-Dory roof top showing crank up vent on the left and heater exhaust vent (stainless steel) on right, Both provide ventilation at rest and when underway. The crank up vent has a screen across it to keep out bugs, and if only opened a little bit, provides quite a bit of ventilation but still keeps rain out.
There are additional ways to deal with condensation at rest.
Some folks use an 120-volt electric heater specifically designed to drive condensation up and out of the lower cabin area. Ventilation of the cabin by one of the methods above then removes it from the boat.
Link to description is HERE. Many other types are available.
There are various configurations of these heaters, but the essential differences beween them and a home heater are that they are 1.) operating at a much lower temperature and electrical current draw, and that 2.) they are marine rated, which means they are designed to be sparkproof to insure against ignition of gasoline and other flamable vapors.
Additionaly, there are chemicals which are utilized to remove moisture from the air. These are desicated (dried out) crystals that are hydroscopic (attract and absorb moisture), but I can't see where they would absorb enough moisture to really get the job done in cold/humid climates.
One other issue is moisture accumulating underneath the bedding in the V-berth where body moisture can accumulate in the bedding due to contact with the cold fiberglass panel underneath the sleeping area. The result is damp and cold bedding. Ick!
There are specific padding maetrials used tp combat this, and I'll let someone with experience with them describe them and their use. They usually come in flat stock and can be cut to fit the v-berth.
That's all for now!
Joe. Teeth
PostPosted: Thu Aug 02, 2007 11:05 am    Post subject: Moisture (Prevention) Reply with quote
So far we have had very little moisture issue on Sleepy C. One of our first outings, with 6 adults on board and in the rain, it took a bit to get the fog of the inside window, but the fans, and keeping the windows ajar, did the job. When sleeping on board, we keep the fore-hatch open, the center front window open to the first notch, and the side windows open 2-4 inches generally.
I have been considering putting one of the Nicro Day/Night Plus Solar vents (West Marine prod # 7868490 for the 3" Stainless) in above the Wallas, (Starbd, aft cabin roof). Would be interested in comments on: How well the Solar vent works. and if the 600cfm would be adequate for 2 adults use. I know it would be better than none, but the time to change to the 1000cfm would be now before I start, rather than after the smaller one is in.
Would like to hear from anyone with experience with the Nicro vents, solar or not. Thanks,
Sleepy C Moon
C-Dude
C-Dory Year: 2013
Vessel Name: Gryphon
Photos: C-Spirit
PostPosted: Thu Aug 02, 2007 12:34 pm    Post subject: Reply with quote
I had similar condensation problems whcich I have solved in the following way:
1. Installed small 12V fans, 1 on the starboard and one on the port helm, they are adjustable and can be aimed at the area of highest condensation
2. Installed a 12V/Solar Nicro fan in the hatch over the v-berth
3. Run a Wallas heater/stove, which dries the air and does not add moisture (combustion air is exhausted)
These remedies are sufficient to deal with condensation here in Alaska
Jeff and Julie
City/Region: Juneau, AK
Vessel Name: Atka
PostPosted: Sat Aug 04, 2007 2:38 pm    Post subject: Reply with quote
C-dude,
Where did you get your fans? I like the style of them and have been looking for something like that.
Jeff and Julie
Page generation time: 0.0522s (PHP: 52% - SQL: 48%) - SQL queries: 22 - GZIP disabled - Debug on
