cbull
Joined: 27 Aug 2007 Posts: 117 City/Region: charleston
State or Province: SC
Vessel Name: knot yankee
Photos: Knot Yankee
Posted: Fri Jun 06, 2008 10:22 am Post subject: honda fuel lines leaking. |
The fuel lines starting leaking on my 90 honda the other day. The bad thing is the carbs have to come off to get at connections. I spoke with the shop and they state the hoses need to be honda fuel line and had to order the lines. What is the difference between honda fuel line and any other of same size? Has anybody else had this problem? $10 dollar fuel line resulting in a couple hundred dollar repair. |
flapbreaker
Joined: 26 Jan 2005 Posts: 878 City/Region: Hillsboro
Vessel Name: Playin' Hooky
Photos: Playin' Hooky
Posted: Fri Jun 06, 2008 11:30 am Post subject: |
This is on an 04' motor? What the heck happened? Are the lines cracking or something? _________________ -----------------
Spencer |
cbull
Photos: Knot Yankee
Posted: Fri Jun 06, 2008 11:57 am Post subject: |
not cracked. leaking where the line goes into carbs. problem is you cant get to them without taking carbs off. Maybe the zip ties went bad with the heat. Clamps would have solved this problem. the engineer who designed the fuel system could have also put the intake lines on the outside. |
