Prop for Honda BF90
ripple
City/Region: Mill Valley
Vessel Name: Ripple
Photos: Ripple
PostPosted: Mon Jul 16, 2007 3:16 pm    Post subject: Prop for Honda BF90 Reply with quote
I have a 2006 Honda 90 with a 13.5 x 15 3 blade aluminum prop. It achieves about 5500 rpm WOT. My owners manual does not say what the max rpm should be, but I am wondering if it should be closer to 6000. Does anyone with the same engine on a CD22 cruiser have advice? What size prop are you using?
PostPosted: Mon Jul 16, 2007 6:09 pm    Post subject: Reply with quote
ripple-
Most four stroke engines like yours have a max rpm range of 5000-6000 rpm.
If you're getting 5500, your're right in the middle of that range.
The next common pitch prop would be a 13 inch.
This theoretically would give you 15/13ths of 5500 rpm, or 6350 rpm, or too much rpm or "spinneroos"!
If you could find a 14 inch pitch prop (probably have to be custom re-pitched), you'd have 15/14ths of 5500, or 5900 rpm, at least according to the numbers.
Another way to look at this is the standard formula that says 1" of pitch change equals 200 rpm. With this approach, the change to a 13 inch pitch prop will give you an additional 2 x 200 rpm, or + 400 rpm to total 5900. (Thanks, Dr. Bob for reminding me!)
Actually, you're 5500 is pretty much ideal unless you're going racing!
You won't get any more torque and very little, if any, horspower out of increasing the rpm. On the contrary, you'll just be increasing the wear rate on the engine!
As they say:
1. Don't mess with success!
or
2. If it ain't broke, don't fix it!
Just my Humble Opinion abd trying to make it entertaining to all!
Joe. Teeth
PostPosted: Tue Jul 17, 2007 9:32 am    Post subject: Reply with quote
The other thing to fiddle with is diameter...we had the Honda 14.5 x 15 x 3 SS prop on the BF150, and WOT ran up over 6,000 (how far I cannot say, because I did not keep winding to find out!)...David has a prop recommended by EQ Les, which is a 15.5 x 15 x 3 SS - I bought the same dimensions only in an aluminum prop (Quicksilver, from iBoats - $165), now WOT is 5,400 - and performance and economy all around are dramatically improved. I don't know the physics of diameter versus pitch here, but pitch is NOT the whole story...
mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
PostPosted: Tue Jul 17, 2007 9:39 am    Post subject: Reply with quote
Depending on load, I get 5500-5800 rpm. I think 5800 is peak. Maybe
6000. One of the nice things about the Honda is that it does not feel like
it is going to explode at max RPM. I never had that feeling when running
at 4200 rpm with a GM small block.
Anyhow, we cruise anywhere from 3800 - 4600 rpm. Every once
in a while I run for a while at 5000 rpm, but it takes pretty smooth
water to do that.
Mike
ripple
Vessel Name: Ripple
Photos: Ripple
PostPosted: Tue Jul 17, 2007 11:55 am    Post subject: Reply with quote
Mike - are you also using a 13.5 x 15 prop?
PostPosted: Tue Jul 17, 2007 4:29 pm    Post subject: Reply with quote
Increasing a prop diameter in diameter is similar to increasing the pitch by one inch. The engine RPM will decrease at the high end. But there are some further dynamics here. The larger prop diameter has larger blades (depending on shape, rake and cup), and will give more thrust, but less speed....A larger prop will give a better hole shot, with a little less at the top end---if the prop is pitched correctly..
Also you have to consider blade tip clearance--if there is not enough between the cavitation plate, or other parts of the motor leg, it will cavitate, and thus loose thurst.
I personally like the Suzuki outboards because they swing a larger prop than some of the other engines (but they have a lower grear ratio).
C-Hawk
Vessel Name: C-Hawk
Photos: C-Hawk
PostPosted: Fri Aug 22, 2008 4:05 pm    Post subject: Reply with quote
New Honda 90 EFI on CD22 loaded for a week at the islands and towing the dinghy.
Prop- 13.25 X 17
max rpm- 4000
max speed- 12 knots
fuel burn- 6 gph
Changed props at the island-
Prop- 13.5 X 15
max rpm- 5300
max speed- 21 knots
fuel burn- 7.4 gph
Our Honda Guy wants to check the throttle setting, thinks it should be better.
2008- CD22- "C-Hawk" Sold
KJ6VVB
A Brat I am, At sea I be
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Fri Aug 22, 2008 11:05 pm    Post subject: Reply with quote
Quicksilver makes a nice stainless 13.375 "X 14 P 3 blade . Just the ticket for the 90 Honda .......
Vengeance model
Stainless Steel 3X13.37514.0 RH 48-17314A46
Marc
Wefings Marine Website
Since 1909
PhilR
City/Region: Albany
State or Province: NY
C-Dory Model: 19 Angler
PostPosted: Mon Sep 22, 2008 9:17 pm    Post subject: Reply with quote
I have a 2007 Honda 90 w/ a 13.5 x 15 prop, on my 19' Angler and WOT is 6,200 rpms on my boat. The boat almost feels overpowered above about 5,400 rpms....a little hard to control. I wouldn't think there would be this much difference between this engine on a 19' versus a 22'.
ripple
Vessel Name: Ripple
Photos: Ripple
PostPosted: Tue Sep 23, 2008 12:05 am    Post subject: Reply with quote
I finally got around to getting a new prop and it seems to work great on my CD22 with the carb 2006 Honda 90. It is a stainless Solas HR Titan, 13.25 x 15 four blade. I will try to post speed vs. rpm and fuel flow rates when I organize the data better.
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Tue Sep 23, 2008 3:17 pm    Post subject: Reply with quote
I’m running the stock 13.5 x 15 3 blade aluminum prop and achieve about 5500 to 5600 rpm at WOT and 27 to 28 mph on the GPS. I haven’t installed the paddle wheel yet so never know what my actually water speed is.
If the water is smooth I kick it up to about 5200 rpm and level trim, if it’s rough I drop back to 4200 to 4400 rpm and full down trim; these seem to be the sweet spots at cruise; have a Permatrim and no trim tabs.
We usually run heavy with gear, food, tackle, shrimp pots, water, extra fuel, tender, dink kicker, large cooler with ice for fish, small cooler with food, 2 adults and one 8 year old.
On average I get about 3.75 to 4 mpg.
If it’s possible to achieve better mpg at higher speeds with a different prop that would be wonderful, but reality of physics dictates otherwise.
Boatless for now but looking
Chris Bulovsky
City/Region: Washburn
C-Dory Year: 1998
Vessel Name: SCOUT
Photos: SCOUT
PostPosted: Tue Sep 23, 2008 11:49 pm    Post subject: Reply with quote
I also have a 22' Cruiser with a 90 Honda. I have a 3 blade 13.25 X17 Alum. prop. It gets 30-32 MPH under ideal conditions on the GPS @ ???? RPM. I have considered a SS prop but feel ok with the lower cost aluminum.
My boat is probably a little lighter than most due to I pulled the water tank and still use the old style 18 gal. fuel tanks that rarely get filled all the way.
I wonder how height of the engine mounted on the transom will impact performance. Some are low and I was skeptical how high mine was mounted...... but pleased with the performance.
Like most here I run mostly at 4000 RPM and travel 16 to 20 MPH depending on wind and wave height.
Chris Bulovsky
tpbrady
Vessel Name: Bidarka II
Photos: Bidarka
PostPosted: Fri Sep 26, 2008 12:38 am    Post subject: Reply with quote
I agree with Marc (Wefings). I have the Quicksilver 14 pitch stainless prop and go right up to the 6300 MAX WOT with the motor trimmed up and making 31 mph. Great acceleration out the hole and good economy up to 4100 rpm 13 mph.
Tom
22 Cruiser Bidarka 2004-2009
42 Nordic Tug 2015-
28 KingFisher 2009-2014
14 Jetcraft 2000-
17 Scanoe 1981-
C-Hawk
Vessel Name: C-Hawk
Photos: C-Hawk
PostPosted: Tue Oct 14, 2008 12:57 am    Post subject: Reply with quote
Prop- 13.25 X 17
max rpm- 4000
max speed- 12 knots
fuel burn- 6 gph
Prop- 13.5 X 15
max rpm- 5300
max speed- 21 knots
fuel burn- 7.4 gph
Prop- 13.75 X 13
max rpm- 6300
max speed- 23knots
fuel burn- 7.5 gph
Montana Kev
City/Region: Bozeman/Yellowstone
State or Province: MT
Vessel Name: Grace
Photos: Grace
PostPosted: Mon Oct 04, 2010 2:45 pm    Post subject: Reply with quote
I am repowering a 22 cruiser with a used 2003 Honda 90. The dealer is giving me a new prop and wants to know what size I prefer. So, 80% of the time I am fairly loaded and above 5000 feet, Right at 8000 on Yellowstone lake where we will have the boat 3 months of the year. I have read thru this thread and gotten some ideas on size and looking to firm up the size (sizes) I should own.
Is there a consideration for the altitude?
Kevin
Page generation time: 0.1798s (PHP: 83% - SQL: 17%) - SQL queries: 32 - GZIP disabled - Debug on
