Like to take the new Dory for Halibut at Sekui - is it open?
Beartrack
PostPosted: Fri Jun 29, 2007 4:30 am    Post subject: Like to take the new Dory for Halibut at Sekui - is it open? Reply with quote
I just got my first C-Dory from Teri back in Ohio from the "For Sale by Owner" section. It arrived last night. It's a 2001, and after a little testing and having replaced both batteries tonight I'd like to go out for halibut with a buddy this weekend. Local shop told me that there should be some reasonable catching still going on up around Sekui, WA. Does anyone know if that area is still open for Halibut right now or have they reached their limit? I know they are open until they either reach their limit or August 3rd, whichever comes first.
... I'd like to go give it a shot this weekend if possible. Thanks for any info!!!
-Beartrack
Beartrack
Jazzmanic
Photos: C-Dancer
PostPosted: Fri Jun 29, 2007 1:39 pm    Post subject: Reply with quote
As far as I know, the Halibut season is still open Thursday - Monday until Aug 3rd. I checked the WDFW site and don't see any emergency closures or anything like that.
If you're going out there, good luck and be safe!
Peter & Caryn
Email: pjamero@gmail.com
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Fri Jun 29, 2007 3:32 pm    Post subject: Reply with quote
From the email below I would say area 4 is closed but the regs show area 5 as being open Thursdays through Mondays.
WDFW FISHING RULE CHANGE
Washington Department of Fish and Wildlife
600 Capitol Way North, Olympia, WA 98501-1091
http://wdfw.wa.gov
June 27, 2007
Sport halibut season re-opens for
one day in marine areas 3 and 4
Action: Open recreational fishing for halibut in marine areas 3 and 4 on June 28, 2007, for one day only.
Effective date: Open 12:01 a.m. through 11:59 p.m., Thursday, June 28, 2007.
Species affected: Pacific halibut.
Reason for action: This rule conforms to federal action taken by PFMC. There is sufficient recreational halibut quota to provide for an additional fishing day.
Information contact: Carol Henry, (360) 249-4628 ext. 254
Fishers must have a current Washington fishing license, appropriate to the fishery. Check the WDFW "Fishing in Washington" rules pamphlet for details on fishing seasons and regulations. Fishing rules are subject to change. Check the WDFW Fishing hotline for the latest rule information at (360) 902-2500, press 2 for recreational rules. For the Shellfish Rule Change hotline call (360)796-3215 or toll free 1-866-880-5431.
Gary Johnson
KB7NFG
Beartrack
PostPosted: Sat Jun 30, 2007 1:46 pm    Post subject: Reply with quote
Thanks gang! I worked late into the night last night backflushing the carbs, replacing the fuel filter and the water separator filter, etc. but am still having trouble with the engine running rough. It sounds like during the trip out the vibration of the trailering it 2480 miles must have lodged something loose and (I'm guessing) lodged it in the carb jets. Taking it down to the shop to put her in line a bit later if changing out the spark plugs this morning doesn't fix it. For now the halibut will just need to get along without me I guess. Sad Hopefully the spark plugs will do the trick. Thanks for the info on area 5!!!
Page generation time: 0.0295s (PHP: 54% - SQL: 46%) - SQL queries: 17 - GZIP disabled - Debug on
