Extended Hull design
D5800877351
Vessel Name: N/A
Photos: D5800877351
PostPosted: Mon Aug 09, 2004 3:43 am    Post subject: Extended Hull design Reply with quote
What are extended hulls? Arima boats have the design up onto every of their boats would be a start. Trim tabs are pretty much the same as extended hulls, to an extent. But, would a custom c-dory that would have a extended hull like the arimas act better on all speeds?
D5800877351
Vessel Name: N/A
Photos: D5800877351
PostPosted: Mon Aug 09, 2004 3:48 am    Post subject: Reply with quote
+ better floatation as it helps balance the weight created by twin or heavy motors
+ no need for trim tabs?
+ with the bottom of the hull supporting the weight of the boat, the top end could increase space for more efficient use of boat
Page generation time: 0.0346s (PHP: 44% - SQL: 56%) - SQL queries: 16 - GZIP disabled - Debug on
