Garmin GMR21 problems...
ahasiec
City/Region: Michigan
PostPosted: Fri Jun 08, 2007 12:37 am    Post subject: Garmin GMR21 problems... Reply with quote
Ok, My brand new 4208 came in today, as well as my GMR21 radome, had everything hooked up nicely...and then no power, I check my RJ-45 connection, wires were in order, copper shielding tape on the draw wire, not sure what is going on...The battery that it is connected to os about 20 ft away from the radome, is it possible that A - the 14 gauge wire is not supplying enough juice during startup
Battery may not be fully charged?
As mentioned the network cable is good, made sure I had the A and B connections corrected...so I am thinking maybe I am not getting the right amount of juice to get her started>>HELP!
ahasiec
PostPosted: Fri Jun 08, 2007 12:41 am    Post subject: ... Reply with quote
Also, can anyone confirm the fuses rating on the inline fuse provided by Garmin for the power cable, I think it say 6 1/4 but my eyes aren't that great. Thanks.
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Sat Jun 09, 2007 1:00 am    Post subject: Radar Reply with quote
My GMR-18 uses a 6.25 amp fuse as well. I would make sure you have at least 11.0 Volts, most of my Garmin stuff will still run with that, 12 Volts would be much better. I know when I turn on my 3210 you can hear the radar spin up and goto standby.
Jody Kidd
KE7WNG
Northern, Utah
ahasiec
PostPosted: Sat Jun 09, 2007 2:53 pm    Post subject: ... Reply with quote
I am almost think at this point to get a seperate battery for my marine electronics, I have so much other stuff running...thoughts, this might be helpful?
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Sat Jun 09, 2007 4:00 pm    Post subject: Reply with quote
ahasiec
What kind of boat and engine(s) size do you have? Current output, battery size/type are related.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
jkidd
PostPosted: Sun Jun 10, 2007 2:19 am    Post subject: Reply with quote
ahasiec
I would Run the Electronics off of a house battery. I don't care to have the electronics feel the voltage drop when you crank the motor. A lot of devices out there will turn off when you crank the motor from the voltage drop.
ahasiec
PostPosted: Sun Jun 10, 2007 8:01 pm    Post subject: .... Reply with quote
Thanks for the reply guys, I am running a 25'2 Sportcraft, Mercruiser 5.7, and yes I do see a voltage drop when the motor is started...should add a battery onboard just for the electronics...probably a wise decision since I have a ton of them now..
Page generation time: 0.0338s (PHP: 54% - SQL: 46%) - SQL queries: 20 - GZIP disabled - Debug on
