Source for Teak
Rob & Karen
City/Region: Franklin
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
PostPosted: Thu Jun 07, 2007 11:12 pm    Post subject: Source for Teak Reply with quote
I would like to get some teak wood to make some small cabinet doors...maybe 3 doors that are 11" x 18.5" by 0.75". Also a trim strip maybe 3/8" or 1/2" by 2" by 6 feet to hang curtain hardware.
Is there a good source for this wood? Thanks.
Rob
PostPosted: Fri Jun 08, 2007 5:50 am    Post subject: Reply with quote
Rob-
When we lived in the S.F. Bay Area, we had several local sources of teak and all kinds of other exotic wood building materials because of the proximity of the marine building and repair industry there.
It was also desirable and important to be able to go into the store / lumber yard (indoor) and pick out each piece of wood for grain pattern, quality, and size to avoid unnecessary waste of expensive wood.
So I'd first suggest you look to find a local source, if you can. Any local lumber company will be able to direct you to the closest alternate source if they do not stock the marine grade wood of your choice.
I've also bought some pieces of teak veneered marine grade mahogany backed plywood on ebay that were small but very usable that came as left-over cut-off stock from custom boat manufacturers.
If all else fails, try Google!
Good Luck!
Joe.
PostPosted: Fri Jun 08, 2007 8:56 am    Post subject: Reply with quote
Here is the Glen-L list of boatbuilding lumber suppliers by state...
mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
PostPosted: Fri Jun 08, 2007 12:09 pm    Post subject: Reply with quote
You want to find a local hardwood supply house. There aren't a huge
number around. They cater to people doing custom woodwork
for homes, etc. The place I go carries perhaps 20-30 hardwoods
in the rough. They will surface two sides for free, and a third for
a minimal charge.
I will say that they have decided to only mill teak twice a month because
it causes excessive wear on their planer and jointer blades. This is
one reason I ended up with Brazillian Cherry. Also, teak is around
$20/ft and the Cherry, $5, I think.
Cool places to go...you should get to know one if you like working in
hardwood. So much cheaper than buying surfaced four sided oak
at Home Depot.
Mike
Last edited by mikeporterinmd on Mon Jun 11, 2007 10:46 am; edited 1 time in total
Alasgun
Guest
PostPosted: Fri Jun 08, 2007 12:17 pm    Post subject: Source for Teak Reply with quote
E-bay!
Mike
PostPosted: Fri Jun 08, 2007 12:52 pm    Post subject: Reply with quote
just a odd story that fits here. a friend of my brother is building a large sail boat in the coos bay area. The guy is really a craftsman and a cheap bastard. Well one day he's down by the commerial docks and looking for pallets to use as fire wood for his shop. He came across a stack of pallets that were different. they were all made of teak. The pallets came from over seas some were and where sitting there in the scrap pile. he took all 300 of them home and used the wood on his boat. A lot of it he surfaced and sold on ebay and other placed for a mint. He kept a look out for more pallets but none ever showed up after that one load. Some time you just get luck.
PostPosted: Fri Jun 08, 2007 3:57 pm    Post subject: Reply with quote
My father had an almost 'endless' supply of teak--his brother was in the millitary and stationed several times in the orient. Each time, all of his shipping crates were made of solid teak.
Check with area boat builders and carpenters. Often they will have some extra teak they will sell, or can add what you need when thier order is delivered.
jdahlfin
City/Region: Salem
PostPosted: Wed Sep 12, 2007 11:53 pm    Post subject: TEAK WOOD FOR SALE Reply with quote
I have 50 pieces 1 1/2x1/4 x 6ft 6 pieces 2x1/4x6ft was going to make a floor for my 22ft cruiser, you can e mail me at jdahlFIN@AOL.COM OR CALL ME AT 503-507-7569 OR 503-588-0859 THIS IS OVER $500 VALUE FOR $275. Laughing Teeth CoolSmile
Page generation time: 0.044s (PHP: 46% - SQL: 54%) - SQL queries: 20 - GZIP disabled - Debug on
