sprint 600 vertical windlass problem
terraplane
City/Region: chesapeake bay
C-Dory Model: R-25 Tug
Vessel Name: BANJO
Photos: Sally's Sister
PostPosted: Thu May 31, 2007 4:02 pm    Post subject: sprint 600 vertical windlass problem Reply with quote
I think i went through this before.
Windlass worked perfectly....tried to drop it today and no power..pushed the various buttons..red and the little black switch..nothing.
I think i did not disconnect it last time after using. Is there a simply solution.
terraplane
PostPosted: Thu May 31, 2007 4:36 pm    Post subject: Reply with quote
Sounds like a fuse Tom. Or a ckt breaker if you have one in that line.
PostPosted: Thu May 31, 2007 5:26 pm    Post subject: Reply with quote
You have to flip up the black lever on the circuit breaker to get power. I leave the circuit breaker off. (red button push to open the breaker, push the small black lever up to reset).
Page generation time: 0.0473s (PHP: 30% - SQL: 70%) - SQL queries: 21 - GZIP disabled - Debug on
