Restoring the gelcoat
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Mon May 28, 2007 9:16 am    Post subject: Restoring the gelcoat Reply with quote
Okay, I have done the hard part. Drove to Sacramento and back with the 16. After removing the state excise stickers and other registration numbers etc, I can see what color the red was. Now what is the best way to restore the colors? I have read about 3M Finesset II, but can't find any mention of it on the 3M site. Also good things are said about 3M Restorer and Wax. Barkeepers friend has been spoken well of. Is the best method good old elbow grease with any of these or should I use my neigbors electric car buffer? I have removed the teak rails and handles and need to strip some varnish off of them before sanding and refinishing.
How about the minor corrosion spots on the aluminum window frames?
Answers anyone??
Cute boat.
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
C-batical
City/Region: Pinckney
Vessel Name: C-Batical
Photos: C-Batical
PostPosted: Mon May 28, 2007 9:53 am    Post subject: Reply with quote
David;
My suggestion is to first use 1000 or 1500 grade automotive wet/dry "sand"paper. To a bucket of water, add a squirt of dish detergent and use this solution to keep the paper and boat wet while you are sanding off the oxidized gel-coat. You should also use a small, I prefer a 2"x2" rubber sanding block for small areas. Use plenty of water and be careful not to introduce any dirt or sand into your sanding process. Also pay watchful eye as to not sand through the gel-coat. Corner and edges are very susceptible. After you have achieved a uniform color then you can buff out with the 3M product or any other light compound. Then apply your wax. This is the process I use on the cars I paint and kayaks I build. My son has a red/gray Master-Craft that I have restored in this manner. Any local automotive store that carries automotive paint/body supplies should have all the materials you need. I also purchase my supplies from Ketone Automotive at: http://www.ketone.com/ It is not a difficult job and it is very rewarding to see a boat that looks like new.
Best regards,
Rollie/C-Batical
Pinckney, MI
PostPosted: Mon May 28, 2007 12:15 pm    Post subject: Reply with quote
Frequent Sea looks like new after compounding and buffing, then a wax. I would try the compounding before sanding. It is amazing how well the gel coat color comes back. The colors really need to be waxed at least every 6 months--better every 3 months.
If it is really bad, then the wet sanding will do wonders.
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Mon May 28, 2007 12:23 pm    Post subject: Reply with quote
Can you suggest a safe way to wax the boat while it is in the water? I have a power buffer but don't think that dropping it in the water while running would be a good idea. Laughing
I suppose elbow grease is a viable alternative. Sad
Doryman
M/V Lori Ann
Anacortes, WA
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Mon May 28, 2007 12:48 pm    Post subject: Reply with quote
Do they make battery operated buffers yet -- they make everything else! Then I'd tie a light line to the handle tied to the boat (or you).
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
PostPosted: Mon May 28, 2007 1:17 pm    Post subject: Reply with quote
I have avoided electricuting myself for a number of years. I do tend to use battery operated tools near the water--but good battery operated tools are a relitatively new item. I used to use a "Craftsman 1 1/2 hp buffer--weight was about 50 lbs--huge thing--always kept the cord well above the water.
Waxing can be done by hand, if the compounding is done. Often you just need to wash, use a cleaner wax and then a good wax.
duckman
City/Region: bismarck
State or Province: ND
Vessel Name: no name yet
PostPosted: Tue Jun 19, 2007 12:29 pm    Post subject: those gel coat dings Reply with quote
Speaking of waxing...after a good waxing and lets of elbow grease the reward can be tempered by the wax highlighting numerous rock dings.
Tried rubbing out but still there.
Question is what protection method is best to prevent dings, (have good wide tire flaps) and are dings just to be lived with?
Frank
2004 22 footer
"in the far north"
Beartrack
PostPosted: Wed Jul 04, 2007 3:57 am    Post subject: Reply with quote
I have a similar issue on the 22' I just bought re: oxidized chalky finish on the sides. Is running 1000 or 1500 grade paper (wet) on a 4" random orbital Makita sander acceptable to make the process easier / faster? The I assume the process after that would be identical of course with the buffing and waxing; but I was hoping to speed up the initial step. Thoughts? This Dory is not in the water so I don't have any concerns about the electric tools and dropping it in the drink. Smile
Beartrack
AstoriaDave
City/Region: Astoria
PostPosted: Wed Jul 04, 2007 5:18 am    Post subject: Reply with quote
I've used 600 grit wet or dry on gel coat to clean off the oxide, and followed that with compound, on a cloth pad, same ROS. A 4-inch Makita will be pretty slow. You might want to check out one of the 5-inch ROS units. The Dewalts are not bad.
Don't punch holes in the sandpaper!
Dave Kruger
Astoria, OR
iggy
City/Region: Hillsboro, OR
Vessel Name: Edward Gallaher
PostPosted: Wed Jul 04, 2007 1:35 pm    Post subject: Reply with quote
Here's a really naive question - When polishing with increasingly fine compounds, do you use a different pad for each compound? Do you clean a single pad as you move to the finer compounds? Obviously (?), just moving to a finer compound on the same pad with the coarser compound doesn't make sense . . (does it?).
iggy
PostPosted: Wed Jul 04, 2007 2:41 pm    Post subject: Reply with quote
iggy
No, you have to use a different buffing bonnet with each successive finer compound or the remaining abrasives from the former compound will be present and the "scratch size" (for lack of a better term) will remain the same.
I've machine washed bonnets between compounds and found that to be acceptable.
The best wet sanding I've ever done before compounding like this was with a National Detroit brand wet sander that was pneumatically driven, had a forward/backward stroke (rather than orbital), and had water jets on it's sides and was connected to a water hose. It was specifically designed to wet sand automotive finishes. I used it to wetsand hulls on small racing sailboats. Still have it!
Joe.
PostPosted: Wed Jul 04, 2007 4:38 pm    Post subject: Reply with quote
Agree with Joe, that best results are with wet sandpaper in the finer grits.
I also feel that air tools are in many ways superior to the electric tools. They are lighter and often easier to use. However, you have to have a pretty good size compressor for some of them. One has to be careful with scratching from sandpaper. Definately change bonets with grits.
Page generation time: 0.0748s (PHP: 44% - SQL: 56%) - SQL queries: 25 - GZIP disabled - Debug on
