Best way to take boat numbers off hull to put new ones on
mccml
City/Region: Montoursville, PA
Vessel Name: Crystal Sea
Photos: Crystal C
PostPosted: Fri May 25, 2007 9:50 pm    Post subject: Best way to take boat numbers off hull to put new ones on Reply with quote
I have to take the old boat number stickers off the hull and then put my temporary sticker on for PA. What is the best way to take off the old numbers and sticker without damaging the gelcoat?
Our Anchor holds,
Mark and Carol
(Crystal Sea)
C-WEED
City/Region: New Brockton
State or Province: AL
Vessel Name: C-Weed
Photos: C-WEED
PostPosted: Fri May 25, 2007 10:07 pm    Post subject: Reply with quote
Warm up stickers with hair dryer.
Use single edge razor blade to lift off sticker.
Use Goo Gone or similar to remove any sticky residue.
Apply new stickers.
Use clear nail polish to seal edges if desired to prevent lifting.
Chris
mccml
Photos: Crystal C
PostPosted: Fri May 25, 2007 10:14 pm    Post subject: Reply with quote
Thanks Chris!
PostPosted: Fri May 25, 2007 11:11 pm    Post subject: Reply with quote
I just removed the stickers from Frequent Sea and do it a little differently.
I use a heat gun (a little hotter than a air dryer--and has two heats).
The major difference is that I then use a plastic spatchla or spreader (for bondo or filler). A razor blade can cut the gel coat--but the plastic spatchla will get under the letters (and I was able to peel these off with my finders after lifting a corner--no potential damage to the gel coat).
I also use Goof Off, Goo Off etc--and then Finessit II to cmpound the boat and bring the color equal to where the letters prevented fade, then two coats fo Colinite fleet wax. The photos of the boat I don't believe you can even see a ghost of the numbers or sticker.
mccml
Photos: Crystal C
PostPosted: Sat May 26, 2007 9:47 am    Post subject: Reply with quote
Thanks Bob!
Page generation time: 0.0277s (PHP: 60% - SQL: 40%) - SQL queries: 18 - GZIP disabled - Debug on
