naptime Guest
Posted: Tue May 22, 2007 7:58 pm Post subject: 16' Cruiser transom |
I am becoming concerned about the hull of my 16’ C-Dory. I recently installed a sounder on the transom. I drilled 3 holes in the transom to permanently attach a starboard plate so I could easily attach and adjust the sounder without removing and replacing screws in the transom. When I drilled the holes in the transom the balsa material that came out with the drill was brown in color. After being in the air for a while this material became blond. I did not have a moisture meter so I was unable to check for moisture. Does anyone know if the balsa core is treated with something that evaporates in air?
Other than the motor mounts there are no holes in the transom. The boat is kept on a trailer and is completely covered with a waterproof and breathable fabric. I have only used the boat 1 season and I estimate it has been in the water about 200 hours. At the time I drilled the holes the boat had not been in the water for 6 months.
Any ideas? |
Joined: 02 Nov 2003 Posts: 21607 City/Region: Pensacola
Posted: Tue May 22, 2007 8:03 pm Post subject: |
I don't have an answer for your question. Normally Balsa is installed dry and is light in color. But if there was uncatalized resin, it might be browinsh r. However it would not change in the air. Wet balsa, feels moist, and you can squeeze moisture out of it. If the boat is kept covered, it should not have any water in the bilge. I suspect that the 16 is similar to the origional 22, so you can see any water in the bilge. _________________ Bob Austin
naptime Guest
Posted: Wed May 23, 2007 9:27 am Post subject: |
Bob,
With the cover I never have water in the bilge. After each use I clean the boat and dry any water in the bilge. Where I drilled the holes in the transom is above and about a foot away from the bilge pump well.
Also, I was under the impression that construction with end grain balsa used an encapsulation technique so that any water intrusion would be limited to that local area.
Dick Clagett |
westward
C-Dory Year: 1985
Vessel Name: TBD
Photos: Steady Eddy
Posted: Wed May 23, 2007 10:35 am Post subject: |
Greetings to all. I've been following with interest the recent batch of postings detailing construction flaws, cut corners, etc. cropping up in C-Dory boats. I for one absolutely encourage this kind of feedback! I love my Dory, but have long questioned some of the construction methods, particularly the manner in which my fuel tanks were replaced by the factory a few years back. Let me clearly state that I have been treated courteously and fairly by the factory, that I love the boat, and that I wish nothing but success to the company. But I also think the factory needs to be held to acccount for its construction methods for such expensive boats. I also want my boat to maintain its value. In my opinion this website and the associated "cult" following helps to create the strong demand and high resale value for the C-Dory line. We should not apologize or rationalize for what are clearly shoddy construction methods. I have seen too many factory photos showing GE silicone used as bedding compound, seen too many screws placed directly into the deck/hull to mount equipment (my boat), too many inappropriate fasteners, through-hulls, and other half measures. Those who read Passagemeker's recent review of the new tug can clearly see between the lines Passagemaker's sense that the vessel falls short of being a robustly built yacht. Every growing company comes to the crossroads of quality vs. quantity. My sincere hope it that C-Dory chooses solid growth based on impeccable quality, similar to the Accura or Lexus car brands. PS I get to put the boat in the water this weekend!!! Happy boating, Mike. |
Posted: Wed May 23, 2007 10:41 am Post subject: |
Dick, do you have a bilge pump in that well? If so, how is it held to the floor/transom?
K4KBA |
naptime Guest
Posted: Wed May 23, 2007 7:25 pm Post subject: |
Charlie,
Yes, I have a bilge pump. It appears that it is epoxyed down. I don't see any screw heads but I am not sure do to the thickness of the epoxy.
Dick |
Posted: Wed May 23, 2007 7:31 pm Post subject: |
The theory is that water will not go from one group of end grain chunks to the next--these are about 2" square (depending on the manufactuer)--but in reality water can migrate between the squares. They are not encapsulated. There will be a bit more about this on my CD 25 Transom thread today. |
