New tires for my tow rig
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Tue May 15, 2007 1:11 am    Post subject: New tires for my tow rig Reply with quote
I have a 2002 Dodge 2500 Quad Cab 4x4 with the Cummins diesel. After towing the Lori Ann to Lake Powell from the PNW I am ready to switch my current 305/70R17 M+S Goodyear Wranglers to a smaller tire with an all-season tread. In the past I have had good luck with Michelins for this application. I would be interested in recommendations for other tires to consider.
Doryman
M/V Lori Ann
Anacortes, WA
dogon dory
Vessel Name: DogOnDory
PostPosted: Tue May 15, 2007 1:39 am    Post subject: Re: New tires for my tow rig Reply with quote
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Tue May 15, 2007 11:02 am    Post subject: Reply with quote
OUCH!! Sounds like we have a GM guy among us.
Warren, I have the same truck with Goodyear Wranglers, but they are 265/R75 16's, and they seem to work fine. I travel with about 2800 pounds of camper on them and pull the C-Dory as well, with no problem. I will not claim however than I don't know all that weight is there, and height, especially when you test the clearance of the street trees in Cathlamet.
How come you want smaller tires, just curious.
PostPosted: Tue May 15, 2007 6:36 pm    Post subject: Reply with quote
We are running Firestone Steel Tex R 45's. LT 265/75/R16 120R, Load Range E (3415 lbs rated load per tire at 80 #)--seem smooth riding with good tread on a Ford Excursion 7.3 diesel. I am probably running less weight that some.
Doryman
Photos: Lori Ann
PostPosted: Tue May 15, 2007 10:48 pm    Post subject: Reply with quote
I had a lot of problems on the tow to Lake Powell from Anacortes, which I discussed at length with Brent and Jim (Discovery and Wild Blue). The consensus is that I need to get the trailer balanced better so that it has the correct weight on the tongue. They also felt that I would have a better ride if I went back to stock size tires. I am willing to give it a try and keep the big tires for when I need something more aggressive. I should also get better gas mileage with street tires.
PostPosted: Tue May 15, 2007 11:36 pm    Post subject: Reply with quote
I sent a PM to Warren, and then decided I might share the thought. The TC and CD boats have both a higher windage profile and sit higher on the trailer than many boats. Typically boats are 5% to 7% tongue weight. I tend to run 10%, beccause of this higher windage, which is more like travel trailers. Considquently my boats seem to track very well. Wonder what others are running as tongue weights?
Page generation time: 0.0225s (PHP: 74% - SQL: 26%) - SQL queries: 19 - GZIP disabled - Debug on
