CD 25 fuel tank
PostPosted: Mon May 07, 2007 9:21 am    Post subject: CD 25 fuel tank Reply with quote
Frequent Sea is a 2003 (#30) CD 25 which still has the fuel fill on one side and a plastic fuel tank.
I wonder how many of the plastic tanks had problems and were replaced.
I would appreciate a link to the specific article on the cutting out of the deck, if anyone still remembers where it was. (A quick search didn't find it--sorry)
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Mon May 07, 2007 10:53 am    Post subject: Reply with quote
Bob, I have that style tank, no problems to date. I did learn though to just fill till the 'first click' of the gas pump. But more accurately I listen to the gurgling of the vent when it gets nearly full, when it stops gurgling, I stop the pump. That leaves about 5 gals to go, enough airspace for storing in hot conditions.
Sorry, don't know the link you're looking for on removing the deck, I don't believe I read it.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
PostPosted: Mon May 07, 2007 2:07 pm    Post subject: Reply with quote
I have heard from one private party who is currently having the plastic tank replaced in a 2004 boat. When an aluminum tank is placed in a boat, one has to be sure that the bottom of the tank does not rest on the bottom of the boat or a board. It needs to be supported on some battons, so that any water can drain free, and air can easily circulate around the tank.
Dora~Jean
Photos: Dora~Jean
PostPosted: Mon May 07, 2007 7:40 pm    Post subject: Reply with quote
The first alum tanks didn't have baffles I understand. Bad. Evidently my plastic does, no sloshing problems or 'vent geysers'! So might want to check the newer alum tanks to verify baffles.
PostPosted: Mon May 07, 2007 8:20 pm    Post subject: Reply with quote
Talking to Brent Reynolds he says that only one plastic has been replaced because of leaks since he has been in charge of customer relations.
Basically if the tank leaks they will replace it. However it is not entirely clear if warantee on the 2003 boats is transferable to a second owner. I do believe that the fuel tank would be for the five years.
Page generation time: 0.026s (PHP: 60% - SQL: 40%) - SQL queries: 18 - GZIP disabled - Debug on
