Lotsa' Part-throttle.
barefoot
City/Region: St. Johns River
Vessel Name: Altered Attitudes
PostPosted: Sat May 05, 2007 7:24 am    Post subject: Lotsa' Part-throttle. Reply with quote
Some may remember that I have an EFI 4-stroke 50 BUT am coping with seemingly endless manatee zones, no-wake zones, marina zones, some very shallow water, and now, chunks of houses a tornado dumped in the open water. You may also remember that with almost all slow running I've considered swapping for everything from a 9.9 main engine to twin 20s.
Airplanes and outboards are made for steady high cruising rpm, but cars are fine with "light and variable" throttle. What I want to know comes down to what I saw addressed here once but can't find now: how well will my modern 50 hold up to running like a car: mostly at idle, just off-idle, light throttle, part-throttle, and rare slow planing?
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Sat May 05, 2007 7:41 am    Post subject: Reply with quote
Keeping the water flow clean is a good thing to avoid over heating...not sure how much/many house parts you are dealing with....or sand. With a lot of sand, I'd be pron to change the impeller annually along with the lower unit oil/lubes.
You may want to also use a fuel additive due to the minimal fuel burn you have, several day/night temp changes could produce a bit of moisture in your tank. I did not have EFI four strokes on my pair of Honda 90s, and often ran them at idle for about 6 hours a day just poking around Lake Martin look'n-&-cook'n and loving life on the boat.
Now that is simply from a user's prespective...and experiences.
Great waters down your way and we really need to some day set us up a little loop trip down your way on the St. Johns.
Byrdman
Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
Capt. Jim
City/Region: Lafayette
State or Province: LA
C-Dory Year: 1998
Vessel Name: Cajun Dory
Photos: Cajun Dory
PostPosted: Sat May 05, 2007 9:26 am    Post subject: Reply with quote
Not to worry, these engines will last when properly maintained. Keep fuel conditioner in your gas and change the oil at recommended intervals or perhaps more often than that. Kind of like stop and go driving in traffic in the city.
Capt. Jim
flagold
City/Region: Abbeville
State or Province: AL
Vessel Name: C-Dawg-E
PostPosted: Sat May 05, 2007 9:31 am    Post subject: Reply with quote
I agree, they're really good now, compared to the engines of old. I'm running slow most of the time as well, no problems.
>Film: C-Dory Buyers Guide<
barefoot
PostPosted: Sun May 06, 2007 2:44 am    Post subject: Reply with quote
Thanks for the feedback, all. Glad to hear the 50 should be OK with "stop and go driving." Mainly, I still think a pair of 20s would be so cool, but am glad I won't have to swap before I want to. No sand in it as the water has been too shallow even to launch. Already have stabilizer in the gas. The house parts in the water (and bottom) are hunks of lumber, paneling, roofing foam, aluminum sheds, etc. Back when a neighbor could still launch, he limped home with a great gob of wire around the prop.
Page generation time: 0.0292s (PHP: 60% - SQL: 40%) - SQL queries: 18 - GZIP disabled - Debug on
