New owner needs a boat hook for CD 25
mccml
City/Region: Montoursville, PA
Vessel Name: Crystal Sea
Photos: Crystal C
PostPosted: Tue Apr 17, 2007 7:30 pm    Post subject: New owner needs a boat hook for CD 25 Reply with quote
I am in the process of order things on the West Marine Web site. Do any CD 25 owners have a favorite boat hook they recommend for a newbie? A certain fixed length or is a telescopic pole better?
PostPosted: Tue Apr 17, 2007 7:53 pm    Post subject: Reply with quote
Telescopic. I have two--one is the twist to lock--and it is about 8 feet long. The second is the push button, and has push button end attatchements, which will allow brush, boat hook, happy hooker, etc on t, he end.
The twist to lock is faster to use, the button lock is more versitile. There are times when two boat hooks are good--like some of the narrow slot canyons of lake Powell...
mccml
Photos: Crystal C
PostPosted: Tue Apr 17, 2007 8:26 pm    Post subject: Reply with quote
Thanks for the info. Bob.[/quote]
PostPosted: Tue Apr 17, 2007 8:57 pm    Post subject: Reply with quote
mccml-
I have the twist-lock poles on two boats and they're pretty good, but I think the pin/hole type would be longer lived. The twist-lock ones do experience wear and get loose or sticky with age, and can be fouled by dirt and sand.
Store it where you're going to use it in a convenient location to grab in a hurry. It's not too convenient on top of the flying bridge!
Joe.
PostPosted: Tue Apr 17, 2007 9:32 pm    Post subject: Reply with quote
One can keep the twist lock poles clean and lubricated and they can continue to be used for quite some time. I have two--one on my 18 footer I have owned about 20 years.
PostPosted: Tue Apr 17, 2007 9:36 pm    Post subject: Reply with quote
Bob-
Better clean up my act!
What do you lube the mechanism with?
(I've got part of the translucent vinyl sticking out of the sliding mechanism.)
Joe.
C-WEED
City/Region: New Brockton
State or Province: AL
Vessel Name: C-Weed
Photos: C-WEED
PostPosted: Tue Apr 17, 2007 10:28 pm    Post subject: Reply with quote
I find the paddle and boat hook combination to be handy. Since it is two tools in one it saves space. I know. You won't paddle a 25 far. Sometimes you find yourself a-drift just a few feet from a dock or another boat. A few strokes can usually swing the stern right over. And the boat hook is well, like any other telescoping boat hook.
See what-cha think...
Chris
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Wed Apr 18, 2007 2:41 am    Post subject: Reply with quote
I also have a double telescoping pole, about 12 ft. I mounted mine vertically along the right side of the rear door (as you're exiting). I use it alot, easy to get to from the outside too.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
Bearbait
City/Region: North Pole
C-Dory Year: 1991
PostPosted: Thu Apr 19, 2007 4:13 pm    Post subject: Reply with quote
I use a pole made by Rich-Mar, it uses pushbuttons and is 12' when extended. It has many attachments available, I also made an atachment for a harpoon and gaff to reduce clutter in the boat. It works well for fending off sea lions when they think your boat is a refuge from killer whales, a noisey and generally unpleasent occurance.
Page generation time: 0.0323s (PHP: 73% - SQL: 27%) - SQL queries: 22 - GZIP disabled - Debug on
