Fuel tank capacity for TC255??
Gene Morris
City/Region: Eureka CA
Vessel Name: Reef Madness
Photos: Reefmadness
PostPosted: Wed Mar 21, 2007 7:33 pm    Post subject: Fuel tank capacity for TC255?? Reply with quote
What is the fuel capacity of your Tom Cat? I noticed that the older literature on the TC stated 150 gal fuel cap.. The C-Dory web states 130gal. And I believe that mine is 130. Are the earlier hulls different?
Gene Morris
tight lines
Brock
City/Region: Deltaville
PostPosted: Wed Mar 21, 2007 7:47 pm    Post subject: Reply with quote
I have hull #16. 130 gallons.
Brock
Brock and Kelly
a.k.a. Brockelly
Alok
City/Region: League City
State or Province: TX
Photos: Top Cat
PostPosted: Wed Mar 21, 2007 10:33 pm    Post subject: Reply with quote
Earlier hulls had 130 gallons capacity; this was subsequently increased to 150 gallons. I do not know exactly when the change was made, but I do know that Bob Austin has hull #39 with a fuel capacity of 150 gallons- so it must have been between #17 and #39.
Alok
Dreamer
Photos: Dreamer
PostPosted: Thu Mar 22, 2007 1:16 am    Post subject: Reply with quote
Hull #26, 150 gallons.
Dreamer- Sold 25 Feb. 2013
drjohn71a
City/Region: Wichita
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
PostPosted: Thu Mar 22, 2007 12:01 pm    Post subject: Reply with quote
Hull #75 ... one side took 62.5 gal, the other took 63 gal.... so a bit less than 130 total.
Brock
PostPosted: Thu Mar 22, 2007 7:11 pm    Post subject: Reply with quote
Wait a minute. I have always assumed that my tanks (hull #16) were 65 gallons each, based on the early literature and info provided by the dealer. Today I was replacing my fuel vents (the old vents inhaled water in heavy rain) and I noticed a white sticker on top of both tanks. Using a small mirror I was able to read clearly "capacity 75 gallons." I have never actually filled the tanks all the way (didn't want to take out a second mortgage) so I had just assumed they were 65 gallons each. Does a "75 gallon" tank only take on 65 gallons? Or do I really have 150 gallon capacity. I'm assuming it is more likely the latter. Some day I'll bite the bullet and fill them all the way.
Brock
Jeff Brigner
State or Province: TN
Vessel Name: C-Pearl
Photos: C-Pearl
PostPosted: Thu Mar 22, 2007 9:33 pm    Post subject: Reply with quote
I do not have a TC but remember a post about Thataway having fuel expand out of the vents and damaging the graphics. Make sure to leave plenty of room for expansion.
drjohn71a
Photos: Tom-a-Hawk
PostPosted: Mon Mar 26, 2007 9:45 am    Post subject: Reply with quote
Jeff,
The fill, vent, and effluent lines have all been proportionately repositioned, so less chance of the overfill from expansion, but still there if overdone. Diesel seems to have alot more expansion problems than gasoline, though.
PostPosted: Mon Mar 26, 2007 4:10 pm    Post subject: Reply with quote
The first boats had 130 gallons, then 150 (Mine definately has 150, and I put in about 73 to 74 gallons per tank). I ran the boat 30 miles and still had an expansion problem on hot days. The initial fill was with the boat on the trailer. It is only the port side which overflows thru the vent line--I suspect that when the vent tube was welded in place, it was put further into the the tank, than being right at the surface. The fill and vent are both in the back of the tank--the vent should be in the front of the tank.
Later boats--and I don't know exactly when, boats only have 130 gallons.
So early and boats toward the end of 2006 have 130, the early part of 2006 have 150 gallons--my hull is #39 and was started about May 1, finished about June 1.
Gene Morris
Photos: Reefmadness
PostPosted: Wed Mar 28, 2007 10:25 am    Post subject: Reply with quote
I receive a call from the factory yesterday. As That-A-Way states the first TC's were 130 gal then they switched to 150 gal capacity. This is great another 40 km range for only $75.00. Thanks for all the response the factory still shows 130 gal capacity on the web site.
Thanks again
Gene
drjohn71a
Photos: Tom-a-Hawk
PostPosted: Wed Mar 28, 2007 10:31 am    Post subject: Reply with quote
Gene,
Are you sure they have not changed it back to 130 gal? My boat was delivered empty (they say) and I put about 63 gal to full on each side.
Ron on Meander
City/Region: Powell River
Vessel Name: Meander
Photos: Meander
PostPosted: Wed Mar 28, 2007 11:59 am    Post subject: Reply with quote
Gene,
John,
Maybe you filled up too close to the Canadian border and they used Canadian (imperial) gallons. Laughing That would be just about the right amount for 150 US gal.
drjohn71a
Photos: Tom-a-Hawk
PostPosted: Wed Mar 28, 2007 12:10 pm    Post subject: Reply with quote
Wow, I guess global warming has caused the Port of Edmonds and Friday Harbour to convert to Imperial now? JJ
Initial fill was at Edmonds.
Gene Morris
Photos: Reefmadness
PostPosted: Wed Mar 28, 2007 3:07 pm    Post subject: Reply with quote
DrJohn;
My boat completed construction in Oct 2006. The factory guy said he is sure that all TCs built at that date or later would have 150 gal capacity. The only time that I filled the tanks I thought they were 65s. I will run my starboard tank near dry then fill, so that I would have confirmation of capacity.
Gene
drjohn71a
Photos: Tom-a-Hawk
PostPosted: Wed Mar 28, 2007 3:15 pm    Post subject: Reply with quote
Thanks, Gene,
I don't have my TomCat here and ready for the water yet, so can't experiment with that. The guy at the marina in Edmonds said C-Dory delivers their boats with empty tanks - I don't know if that is the case for certain. As mentioned, they filled with about 63 gallons apiece.
As such, they're either 130 total or about 10 gallons was in each tank at delivery... Interesting question.
As someone has mentioned, it is a bit dicey to run the tanks empty and then totally fill them, unless you're going on a long cruise or something.
I'll be waiting to see what you find out.
I am wondering where that sticker was that showed the total capacity. Do you think a guy coudl look at that without having to take the deck apart?
Page generation time: 0.0527s (PHP: 51% - SQL: 49%) - SQL queries: 32 - GZIP disabled - Debug on
