C-Brats Online! Boating Forums for C-Dory People Forum Index
Choice of anchor
Post new topic   Reply to topic    C-Brats Online! Boating Forums for C-Dory People Forum Index -> All C-Dorys, All The Time
Chester
City/Region: home
Vessel Name: Chester
PostPosted: Sat Mar 17, 2007 2:12 am    Post subject: Reply with quote
Dear Craig, this forum is for C-Dory owners and fans. Should you attempt to spam us the way you do the SSCA Discussion Board or Wikipedia we will show you the door.
Yes, you do build a good anchor, but I find your sales tactics offensive.
Chester
City/Region: home
PostPosted: Sat Mar 17, 2007 2:29 am    Post subject: Reply with quote
By the way folks, don't believe the chart in Craig Smiths first post. It is his adjusted version designed to make his Rocna anchor look good. That chart was not published by West Marine, Yachting Magazine, or Sail. It's just set up to look that way.
Craig, we're not bumpkins you can baffle with self serving BS. If you try to drag this forum down to sell your product the way you have elsewhere, we'll run you off.
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Sat Mar 17, 2007 4:28 pm    Post subject: Reply with quote
Craig Smith,
Are you on this forum for any reason other than to sell your anchors?
We are not about commercial advertising disguised as a members post.
ON EDIT: Craig is gone, thanks administrators! Thumbs Up
I hope his anchors are better than he is! Wink
Larry H
A C-Brat since Nov 1, 2003
Puget Trawler 37 'Jacari Maru'
1991 22' Cruiser,'Nancy H'--1991-2006
MacMini Intel 2.53Gh--4GB ram
Not For Hire
City/Region: Cadillac, MI
Vessel Name: Not For Hire
Photos: Not For Hire
PostPosted: Sun Mar 18, 2007 1:25 pm    Post subject: Reply with quote
Some other anchoring considerations:
If you have seven to one scope you should have a circle of clearance equal to eight times the water depth and the center of the circle is the anchor. I think a scope of five to one with a mixed chain and nylon rode is enough.
In a big blow if the anchoring system fails it will fail at the weakest point. On the C-Dorys that may well be the bow roller. I don't think it could take the intermittent shocks sustained over time. Yet how many of us have proper fair leads (skene chocks) installed, and how many of us take the time to move the rode out of the roller, through the fairlead and to the fore cleat? Better yet would be a proper bridle system but how many C-Dories have two suitable cleats installed on the bow as sturdy as the stem cleat? If the bow roller is broken or bent or removed the rode can chafe all too soon.
A proper storm anchor should be three times the weight of your regular anchor. So for the 22 that would be 30 to 50 lbs. (approximate for any spade type anchor, danforth, bruce, delta, cqr, etc., less for the lightweight models such as Fortress) Nice to have but hell to store aboard. If I was anchoring and leaving the boat for any length of time I would want one.
Chapman is ambivalent about sentinels but does suggest a sentinel/kettle affixed to the chain at the point of attachment to the main rode could be a good thing.
Daily use includes trailering, launching, anchoring, retrieving. No single anchor design is best. Some hold the best in sand and mud - danforth, some skate the most and foul the most on weeds, etc - danforth. Some set and reset easiest, bruce, delta, cqr types, some launch easier, some hold better in weeds and rock and coral (hook types, kedges) etc.
Has anyone used a floating sentinel. That is -- a sturdy buoy between boat and anchor. The buoy supposedly receives much of the up and down shock and the force exerted on the boat is more horizontal.
A combination nylon and chain rode is best in a storm to have elastic anchoring.
My compromise is to have 20 feet of chain (when I see the chain I know I can get underway) and a 16 lb bruce. This suits most Great Lakes conditions. A delta or cqr or similar would have been dandy too, but I wanted one of those types for day in day out use. Besides I don't anchor out near enough but am looking forward to the day.
Regards,
Mark
Mark S
Cadillac, Michigan
Vessel Name: Thataway
PostPosted: Sun Mar 18, 2007 4:56 pm    Post subject: Reply with quote
Althugh most of us use the bow anchor roller, I agree that this is not the best way to attatch a rode. You are far better off using a snubber line, to a cleat directly on the side of the boat. This way there is no chafe on the main rode--since few if any C Dories have all chain, the snubber and chain hook don't necessarilly apply. However we use snubbers tied on the nylon 3 strand rode with a rolling hitch. This allows adjusting the point of chafe, changing chafing gear etc easily in a real blow. On our larger boats, we always used a snubber, which never took the load on the bow roller.
As for the weight of a storm anchor--yes, we generally like a much heavier storm anchor for the "ultimate storm" but the fluke area is also an extremely important consideration--maybe even more so than weight. In larger boats I used to say that the minimum size plow should be 35 lbs. That is way too heavy for a C Dory.--it is also very difficult to store.
The solution can be a light weight anchor which breaks down--such as the Fortress FX 37. This anchor weighs 21 lbs, breaks down for easy storage and will hold up to 3000 lbs. It is comperable to a 35 to 50 lb steel anchor in holding power (comperable bottoms, ie sand) This is what we carry on the Tom Cat 255 as a "storm anchor" On our larger boats we had anchors up to 150 lbs (but they broke down into 50 lb sections)--and 1/2" chain (weight 2.5 lbs a foot, or 50 feet weight was 125 lbs additional weight, plus 1" diameter rope--in other words, you don't only have to increase the anchor size, but also the rode and all gear associated with it).
We like the 7 : 1 scope--this has been well established, based on the Danforth type of anchors, to give the best shot at both penetration of the bottom and maintaining a downward migration of the anchor shank during a load. The anchor shank needs to remain parallel to the bottom, the fluke angle is 32 degrees in Danforth and Fortress anchors, and the rode angle with the shank needs to be 8 degrees or less. Remember that the "depth" includes the distance of the bow off the water, plus the depth of the water. There are some instances where we will set with a 7: 1 scope, power back and check for dragging, and shorten up scope if there are other boats nearby. However generally we stay with the 7:1 scope which is recommended for combination rope and chain rode--10:1 recommended for the all rope rode and 5:1 may be fine with all chain, until it begins to really blow.
As for the ball as a shock absorber; this is more likely used in coral infested waters, where there is a chance of the rode being entangled under a coral head and severed. Also a large bouy can hold the "weight" of the chain and keep this from depressing the bow--allowing it to rise more rapidly. All in all, one needs a longer rode to do this, because the float tends to effectively bring the rode to the surface before the bow of the boat. We have used this effectively in open water where there were coral head (for example we anchored on the Salvage Islands to dive on wrecks--pretty much out in the open and used this technique). It is not something I would use every day, especially with a C Dory. But it is a "Trick" which might help in some cases, to releive the strain on the boat.
TomCat 255 150 Suzukis
Caracal 18 140 Suzuki
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Sun Mar 18, 2007 5:45 pm    Post subject: Reply with quote
I was under the (perhaps mistaken) impression that a boat should always be anchored from the bow (I have noted carefully the many warnings not to anchor solely by the stern.) If you anchor by one of the forward side cleats on the TC, as I assume you are suggesting, is there a problem with the boat's bow not pointing to the anchor?
How about a bridle connected to both of the forward cleats? How would you connect the rode coming off the windlass to the bridle?
Doryman
M/V Lori Ann
Anacortes, WA
PostPosted: Sun Mar 18, 2007 7:29 pm    Post subject: Reply with quote
Our Tom Cat only has one bow cleat, and it is athwartships and just aft of the windlass, so that if the line is attatached to it, and leads foreward it will hit the windlass casing on either side. (Not a good design) In our case, I made a line, with an eye spice, thimble and shackle which I place thru the bow eye on one end, and run a rolling hitch around the anchor rode with the other end. the rolling hitch will hold---and it tightens as the load increases. see:
http://www.animatedknots.com/rollinghitchboating/index.php
I allow slack between the end cleated to the cleat and the place where the rolling hitch on the snubber line attatches to the main rode.
I probably will eventually add bow cleats to each side of the bow. or a cleat on each side of the roller... The boats don't come from the factory with any other bow cleats. There are spring line cleats on the side deck at about the foreward end of the wheel house--I think that making a bridle from these would be awkard and subject to chafe. (one might make a case for these to be bow cleats, but with the position as far aft and right on the edge of the gunnel, the line to the dock would be very short and subject to jerking loads.)
Some C Dories have a cleat on each side of the bow, some have fairleads with a single cleat in the center. In this case, one can place the snubbers thru the fair leads and then cleat to the center cleate (if there is no windlass in the way) Even smooth fairleads can cause chafe, so I would prefer to go directly to a cleat on the edge of the gunnel. If you pass a rope under load thru a fair lead, it is a good idea to have chafing gear.
Some folks anchor their boat so that all of the strain is on one side of the bow. I prefer not to do that, and to use two snubbers (at least one lighter than the anchor rode.) with one on each side. Thus the pull of the anchor rode is straight foreward off the bow. However, there is something to be said for anchoring with the bow slightly off of the eye of the wind--there tends to be less sailing--or more properly put--the sailing tends to be more in one direction. I have yet to own a boat which does not sail to some extent at anchor. No, I don't normally anchor by the stern as the only anchor.
teflonmom
City/Region: Red Lion
Vessel Name: SOLD AUG 08
PostPosted: Sun Mar 18, 2007 8:02 pm    Post subject: Anchoring Reply with quote
One other small point I would like to make about our C-Dorys.
Many times because of our shallow draft we can get into places with very good protection from heavy wind other cruising boats could not get into these holes. We have anchored on the lower eastern shore of the CBay hiding up small channels. The tall grass growth deflected the wind over our head, of course you must find a spot with room to anchor.
Don't forget to factor in the tidal range when you figure your scope. With a big range you could end up with less scope than you planned.
Fred, Pat, and Mr Grey(the Cat)
Pat & Fred Messerly
dogon dory
Vessel Name: DogOnDory
PostPosted: Sun Mar 18, 2007 8:35 pm    Post subject: Reply with quote
FarNorthPhotography
Not For Hire
PostPosted: Sun Mar 18, 2007 9:16 pm    Post subject: Reply with quote
The line from bow eye to rode with a rolling hitch is great idea. Solves a number of problems! Could still run a second line to reduce hunting. Could add fairleads on bow but a little farther back than I had planned. Already have a small second cleat on bow to hold anchor in roller, could use to stow the line to the bow eye.
New project - cool, thanks.
I have seen this painter setup commonly on Bayliners and Dodges, always thought it was because they were so frequently towed.
<g>
Regards,
Mark
SeaSpray
City/Region: Brentwood, CA
Vessel Name: SeaSpray
Photos: SeaSpray
PostPosted: Sun Mar 18, 2007 9:45 pm    Post subject: Reply with quote
Okay, what is a skene chock?
It seems tha the Rocna has been hyped. But is it a good anchor or no better than the claw or delta for general use? Anyone use one or have opinions?
Steve
Doryman
Photos: Lori Ann
PostPosted: Sun Mar 18, 2007 11:15 pm    Post subject: Reply with quote
Bob, color me slow, but I am having trouble visualizing how this setup works for you. I thought the objective was to avoid strain on the bow roller. It seems to me that the anchor rode is still going through the roller, no? Or do you go down into the chain locker and untie the rode and take the anchor out of the bow roller altogether? A picture (from the next time you go out) would be very helpful.
Not For Hire
PostPosted: Mon Mar 19, 2007 8:54 am    Post subject: Reply with quote
Skene chocks are one type of fairlead. A fairlead is device to pass a line through to guide it around an obstruction or whatever. Skene chocks are typically located on gunwale to guide anchor or dock lines, etc. They have positive and negative aspects. Great to move line off center, to guide it away from windlass or bow roller or other lines, long term will cause chafing although less than a naked gunwale. They have angled slots so the line doesn't pop out and look like this:
Warren:
I will take a shot - Because the bow eye is not that easy to get to in a pitching sea (why the CG Aux carries specialized hooks to access bow eye from a different boat) I hadn't considered it as an alternate place to secure an anchor line. I don't like the strength or location of the spring cleats as an alternate place to secure an anchor line. So I was thinking of installing a pair of skene chocks (still a good idea as it would be quick and handy for pulling anchor, guiding, etc.) to get some of the pressure off the bow roller. My thought was to run the rode through the chock then tie off to the main bow cleat. The line through the bow roller would then be slack. This would be a good idea if it isn't real rough. What Bob suggests is to attach a line to the bow eye with a shackle. Presumably you would do this at the dock or in calm seas. The line could be 10 or more feet long. This line would be secured some way so it was out of the way, fed down deck pipe, tied off to cleat or whatever. Then when anchoring you would deploy anchor in normal fashion. Next you would take the line that was secured to the bow eye with a shackle, and tie the bitter end to the anchor rode with a rolling hitch. Then you would pay out a bit more of the anchor rode until the anchor rode was slack and the the line to the bow eye was taut. Now all the strain is on the bow eye which is quite strong. It is low to the water and the line is not rubbing on the gunwale or interferring with the windlass or bow roller. You would tie off the anchor rode to the main bow cleat with just a bit of slack in that line. It would act as a backup in case your rolling hitch gave way or something. Because the line to the bow eye is attached with a shackle (ideally with an eye splice and thimble as Bob describes) there is minimal chafing at that point, etc. If you wanted to try and move the bow off center you could still do it with a second (recommend lighter) line, hitched to the bow eye line and run to a spring cleat or maybe run through your shiny new skene chock and then to the bow cleat Smile
Thanks guys,
Mark
Doryman
Photos: Lori Ann
PostPosted: Mon Mar 19, 2007 11:58 am    Post subject: Reply with quote
O-Kay! I get it now. Seems to me that Mark's suggestion would be easier to deal with in that it would require less exposure on the foredeck -- which might be a factor if you had to re-anchor in a blow, for instance?
Thanks for the great explanation!
Chester
City/Region: home
PostPosted: Mon Mar 19, 2007 1:08 pm    Post subject: Reply with quote
Steve
West Marine carries the Manson Supreme which is very similiar to the Rocna. It is an effective anchor, costs less, and you're not supporting a shameless spammer if you purchase one.
The claw generally dosen't work as well as plow anchors in weedy bottoms.
As I mentioned earlier in this thread look at the Bulwagga and HydroBubble anchors. These are outstanding new generation anchors and I'll probably replace the claw that came on my boat with one or the other.
Post new topic   Reply to topic    C-Brats Online! Boating Forums for C-Dory People Forum Index -> All C-Dorys, All The Time All times are GMT - 6 Hours
Page 3 of 4
Page generation time: 0.0721s (PHP: 81% - SQL: 19%) - SQL queries: 28 - GZIP disabled - Debug on
