Mouse on a C-Dory
Goto page 1, 2, 3  Next
CaptMac
City/Region: Amelia Island / Jacksonville
Photos: Blue Manatee
PostPosted: Fri Mar 02, 2007 2:07 pm    Post subject: Mouse on a C-Dory Reply with quote
I went out to check on the boat the other night and noticed a few unusual looking pellets which I later confirmed as mouse droppings. I don't store any food or drink on board. How did a mouse get inside, I wondered, because the door was shut and the window screens were closed? I found the access point by looking under the starboard gunnel at the rear of the cabin where the steering cable passes through. I soon found the little fella by looking in the sb battery compartment before he squirmed out of sight.
Questions: (1) What is the best way to seal off the steering cable opening from a mouse having access? (2) Any ideas for a solution to ward off the pests in the future? I understand poison is not the preferred method because they'll crawl under something and die. Baited traps left on the boat are probably not the answer because my backyard borders on hundreds of state park acres and the smell of food will likely attract other pests.
Capt Mac Daniel
Flounder Gigging Charters
Amelia Island, Florida 32034
http://www.floundergigging.com
"The Adventure of a Night-time"
904-556-0230 Cell/Text
SGIRhino
Dealer
City/Region: Eastpoint
PostPosted: Fri Mar 02, 2007 2:19 pm    Post subject: I Hate Meeses to Pieces! Reply with quote
Mac,
Your best bet to get rid of mice is a .44 Magnum...oops, maybe not in the boat!!!
Seriously, think about an ultra-sonic emitter. It will not only chase the little bugger out, but keep others from boarding.
Until then, stuff any openings with steel wool sprayed with corrosion block and wrapped in plastic. Mice won't chew through steel to get in and the other two will keep it from rusting.
Two new TomCats in stock...and can order your blue one at any time!
Wefing's Marine
It ain't a Hobby and it's not Mission Work...it's a PASSION!!!
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
MOOSE
State or Province: MN
Vessel Name: MOOSE
Photos: MOOSE
PostPosted: Fri Mar 02, 2007 2:22 pm    Post subject: Reply with quote
I seal that opening with a sponge to keep insects out. Dampen it, stuff it in the hole, and it will expand and dry to seal the area, but is easily removed. Spray it down with some awful tasting stuff if the little bugger chews on it.
Al
PostPosted: Fri Mar 02, 2007 2:26 pm    Post subject: Reply with quote
Mice can get in the anchor rode hause pipe--alse they are able to squeeze thru incrediably small places. I would consider foam, like "great stuff"--but put a couple of pieces of PvC pipe in first for furture wires or cables.--Put a pvc cap over the outboard end of the pipe.
sailor-d
Photos: Sailor-D
PostPosted: Fri Mar 02, 2007 3:00 pm    Post subject: Mice and others Reply with quote
I use scotchbrite pads in the cableway holes to the cabin under the gunwales. Just wrap around the cable(s) and slide into the hole. I don't think mice or rats find the material appetizing and it won't rust.
Cheers - Dave
patrick and linda
City/Region: somerset
State or Province: KY
C-Dory Year: 1986
Vessel Name: "Fan-A-Sea"
Photos: Misty Seas
PostPosted: Fri Mar 02, 2007 3:23 pm    Post subject: Reply with quote
hey capt. mac
there is a spray foam substance, i believe it's called fire stop. works great and should you need access to the port hole, easy to penetrate. doesn't mean they can't chew thru it but has worked thus far. also, i was concerned with this problem so in addition to the pass thru under the gunnel i also glassed over the water vent at the bottom of the aft cabin bulkhead, where the cockpit water flows to the bilge pump reservoir, under the galley cabinet. hate those little creatures, also the little lady wouldn't sleep in the boat with the possibility of mice crawling about.
need the little lady aboard for proper ballast.
hope this helps
pat
Island Ranger
City/Region: Whidbey Island
C-Dory Model: R-25 Tug
Vessel Name: Island Ranger
Photos: Two Lucky Fish and Island Ranger
PostPosted: Fri Mar 02, 2007 3:55 pm    Post subject: Reply with quote
I use bronze wool to seal up the gaps - no rust as with steel wool, easy to pull out when you need to get to the wiring.
Mac
patrick and linda
C-Dory Year: 1986
Photos: Misty Seas
PostPosted: Fri Mar 02, 2007 3:59 pm    Post subject: Reply with quote
what about the possibility of chaffing?
Larry Q
City/Region: Rochester, Wa
Vessel Name: C-ya
PostPosted: Fri Mar 02, 2007 4:37 pm    Post subject: Reply with quote
CapMac-
The best way to catch the little buggers is to use glue boards with a piece
of chocklat for bait. Check the glue board every day, they sure do start to stink if left very long.
I used scotchbright pads to fill small entry ways. It's worked so far. Good luck and happy hunting.
Chris Bulovsky
City/Region: Washburn
C-Dory Year: 1998
Vessel Name: SCOUT
Photos: SCOUT
PostPosted: Fri Mar 02, 2007 5:21 pm    Post subject: Reply with quote
Poison the rotten little buggers! Angry Then also use the sticky traps. Poison the boat storage building if you use one............DON'T BE NICE TO MICE! They are very destructive to boats and wires Angry Angry . An all out genocide of the local mouse population is necessary to control them. Its a war to me.
The potential down side to the poison is a smelly little dead mouse........ Easier to fix than new wires and chewed upholstery.
Good Hunting!!!!
Chris Bulovsky
pcator
City/Region: Fletcher
Vessel Name: Donna Marie
Photos: Donna Marie
PostPosted: Fri Mar 02, 2007 5:26 pm    Post subject: Reply with quote
We have 12 cats = zero mice.......
PostPosted: Fri Mar 02, 2007 6:27 pm    Post subject: Reply with quote
I think I'd only have room for 8 cats, or so, on my 22. You're lucky you've got a 25 and room for all those cats! Shocked Cat Cat Cat Cat Cat Cat Cat Cat Cat Cat Cat Cat
Darn, that's lots of kitties!!
We've found also, in our camping trailer (28' Coachmen) that those Dryer Softner Sheets (Bounce) work well too. Just spread them around. Don't have to feed them or change their litter boxes either... Cry
PostPosted: Fri Mar 02, 2007 9:33 pm    Post subject: Reply with quote
DID SOMEONE SAY THEY NEEDED SOME HELP WITH A MOUSE?
PostPosted: Fri Mar 02, 2007 10:03 pm    Post subject: Re: Mouse on a C-Dory Reply with quote
CaptMac wrote:
<stuff clipped> (2) Any ideas for a solution to ward off the pests in the future? I understand poison is not the preferred method because they'll crawl under something and die.
Snakes!!!
Snakes on a boat - could be a great movie....
PostPosted: Sat Mar 03, 2007 12:12 am    Post subject: Re: Mouse on a C-Dory Reply with quote
rogerbum wrote:
Snakes!!!
Wasm't there just a movie about snakes let loose on an airplane? (Didn't see it, just the ads on TV.)
Joe.
Page 1 of 3
Page generation time: 0.0456s (PHP: 66% - SQL: 34%) - SQL queries: 32 - GZIP disabled - Debug on
