Gelcoat Repair
Post new topic   Reply to topic    The C-Brats Forum Index -> Documents
C-Hawk
Vessel Name: C-Hawk
Photos: C-Hawk
PostPosted: Wed Feb 28, 2007 8:49 pm    Post subject: Gelcoat Repair Reply with quote
This was found at
Gelcoat Scratch Repair
by Don Casey
Surface scratches can be buffed out of gelcoat with polishing compound, but deep scratches must be filled. When the gelcoat surrounding a scratch is in good condition, the filler of choice is gelcoat paste, which provides both filler and finish in a single application-but not a single step. Because the surface of the cured paste will be uneven, sanding and polishing are required to smooth the repair and blend it with the rest of the hull. Except for color matching, gelcoat repairs are easy and straightforward.
Gelcoat Choices
You will find gelcoat available as both a resin and in a thicker putty form called paste. For scratch repair you want paste. Repair kits comprised of a small amount of gelcoat paste and hardener, a selection of pigments, mixing sticks, and sealing film can be purchased for less than $20. Buy a flexible plastic spreader if you don't already have one. You will also need sheets of 150-, 220-, 400-, and 600-grit wet-or-dry sandpaper. A single sheet of each will be more than ample to fair all the paste in a repair kit.
If you are repairing several scratches, add a small bottle of styrene to your list of supplies. Wiping each scratch with styrene just prior to filling it partially reactivates the old gelcoat, resulting in some chemical bonding between the old gelcoat and the new. Otherwise the bond between old and new is strictly mechanical-like a coat of paint. A mechanical bond is normally adequate, but the more extensive your repair, the more certainty you want.
Color Matching
The hardest part of a repair to the surface of a fiberglass boat is matching the color. Professionals who do gelcoat repairs daily still have difficulty getting a perfect match. Even "factory" colors don't match exactly after a boat has been in the sun for a few years.
White has the significant advantage of being fairly easy to match, and once a small repair is buffed out to a gloss, shading differences will be unnoticeable. Matching colored hulls is somewhat more challenging.
A color-sample card from your local paint store that matches your hull can provide valuable help. Ask the store clerk the formula; they custom-mix the color by adding tints to a white base. The formula may call for a half-dozen different tints, but the important ones are those specified in the largest quantities. You can use the tints in your repair kit to approximate the formula.
Always color gelcoat paste before you add the catalyst. Put exactly one ounce of paste into a mixing cup and add the tints a drop at a time. Keep track of the number of drops of each tint. When the color looks close in the cup, touch a drop of the mix onto the hull. Make needed adjustments until you are satisfied with the match-don't expect perfection-then write down the formula so you can duplicate it for the rest of the paste.
Preparing the Scratch Never try to repair a scratch by simply painting over it with gelcoat. Gelcoat resin is too thin to fill a scratch and gelcoat paste is too thick. Instead of penetrating scratches, gelcoat paste will bridge them, leaving a void in the repair. To get a permanent repair, draw the corner of a scraper or screwdriver down the scratch to open it into a wide vee.
This is the time to wipe the open scratch with styrene to reactivate the old gelcoat.
Catalyzing
The hardener for gelcoat is the same as for any polyester resin-methyl ethyl ketone peroxide, or MEKP. Gelcoat resin usually requires 1 to 2 percent of hardener by volume (follow the manufacturer's instructions). As a general rule, four drops of hardener will catalyze 1 ounce of resin at 1 percent. The mix shouldn't kick (start to harden) in less than 30 minutes. Hardening in about two hours is probably ideal. Always err on the side of too little hardener. Also be certain to stir in the hardener thoroughly; if you fail to catalyze every bit of the resin, parts of the repair will be undercured.
Spreading Gelcoat Paste
Work the gelcoat paste into the scratch with a flexible plastic spreader. Let the putty bulge a little behind the spreader; polyester resin shrinks slightly as it cures, and you're going to sand the patch anyway. Just don't let it bulge too much or you'll make extra work for yourself.
Scrape up any excess paste beyond the patch area.
Covering the Repair
Gelcoat will not fully cure in air. To seal the surface of a scratch repair, cover it with a sheet of plastic film. The kit may include sealing film. Otherwise a section of kitchen "zipper" bag works especially well because it tends to remain smooth and the gelcoat will not adhere to it. Tape one edge of the plastic to the surface just beyond the repair, then smooth the plastic onto the gelcoat and tape down the remaining sides.
Sanding and Polishing
After 24 hours, peel away the plastic. The amount of sanding required will depend on how smoothly you applied the gelcoat.
A 5 1/2-inch length of 1 x 2 makes a convenient sanding block for a scratch repair. Wrap the block with a quarter sheet of 150-grit paper, and use the edge of the block to confine your sanding to the new gelcoat. Use short strokes, taking care that the paper is sanding only the patch and not the surrounding surface. Never do this initial sanding without a block backing the paper.
When the new gelcoat is flush, put 220-grit wet-or-dry paper on your block and wet sand the repair, this time with your block flat. Use a circular motion and keep a trickle of water running on the sanding area. Feather the repair into the old gelcoat until your fingertips cannot detect a ridge. If the hull is curved, take care not to sand the repair flat.
Abandon the block and switch to 400-grit wet-or-dry paper. Wet sand the surface until the repair area has a uniform appearance. Follow this with 600-grit wet-or dry. Wear cloth garden gloves-the kind with the hard dots-to save the tips of your fingers.
Dry the area and use rubbing compound to give the gelcoat a high gloss. Swirl a soft, folded cloth over the surface of the compound to load the cloth, then rub the compound onto the repair area. Buff it with a circular motion, using heavy pressure initially, then progressively reduce the pressure until the surface becomes glassy. If the gelcoat shows swirl marks, buff them out with a very fine finishing compound.
Finish the job by giving the repair area a fresh coat of wax. If your color match is reasonably good, the repair will be virtually undetectable.
2008- CD22- "C-Hawk" Sold
KJ6VVB
A Brat I am, At sea I be
PostPosted: Wed Feb 28, 2007 10:34 pm    Post subject: Reply with quote
Specturm color makes factory match gel coats and sell kits which are easy to use: http://www.spectrumcolor.com/ Fortunately the C Dory line is represented.
Also remember that polyester resin hardener works by temperature and amount of hardner, unlike epoxy is a fixed ratio of hardner. In cold tempeatures you need more hardner than in warm temperatures. I would pay to experiment with a small amount of gel coat to try first to see how much hardner you will need at the ambient temperature.
Polyvinyl Alcohol (PVA) is also used to occlude air from the gelcoat. This is sprayed on the surface as the gel coat is just beginning to cure. Many times there are multiple small gouges which may difficult to cover with a film and the PVA sprayed on is a better solution. A Preval spray can be used for this: http://www.prevalspraygun.com/ . A Preval sprayer can be used on gelcoat, but although Gel coat can be sprayed, it is often difficult to do in a repair setting--and one must be cautious about adding too much styrene to the gel coat in an attempt to thin it for spraying. Excess styrene will leave the gel coat too soft.
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Thu Mar 01, 2007 1:35 am    Post subject: Reply with quote
Great info from both of you. It gives answers to all those questions that a fiberglass bumpkin needs to ask.
Jack
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
patrick and linda
City/Region: somerset
State or Province: KY
C-Dory Year: 1986
Vessel Name: "Fan-A-Sea"
Photos: Misty Seas
PostPosted: Thu Mar 01, 2007 10:42 am    Post subject: Reply with quote
HI ROGER,
GREAT INFORMATION!
THIS ONE DESERVES TO BE PRINTED OFF AND PLACED IN THAT, HOLLY $*#%, WHAT DO I DO NOW FILE.
BEST REGARDS
PAT
Chris Bulovsky
City/Region: Washburn
C-Dory Year: 1998
Vessel Name: SCOUT
Photos: SCOUT
PostPosted: Thu Mar 01, 2007 11:09 am    Post subject: Reply with quote
Don Casey's book Sailboat Hull & Deck Repair is a must have for do it yourself boat work. I learned so much from it. It has good illustrations and step by step procedures to do a job. I'm pretty sure you can get used copy's off the Net if you search a little. Here is a source. I think its the best book available for repair.
http://www.amazon.com/Sailboat-Hull-Deck-Repair-Casey/dp/0070133697
Chris Bulovsky
C-Hawk
Vessel Name: C-Hawk
Photos: C-Hawk
PostPosted: Thu Mar 01, 2007 12:46 pm    Post subject: Reply with quote
Chris Bulovsky
Or just follow the link I supplied in the first post for his "on-line" articles.
C-Hawk
Vessel Name: C-Hawk
Photos: C-Hawk
PostPosted: Mon Mar 19, 2007 3:13 pm    Post subject: Reply with quote
I finished the repair of the holes after relocating the antennes. It was a fairly simple job.
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Mon Mar 19, 2007 3:17 pm    Post subject: Reply with quote
Fishtales: Thanks for the updates....and the info prior to... now... show us your finished pics as to allow us to grade your work.
Glad you took the jump.
Byrdman
Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
C-Hawk
Vessel Name: C-Hawk
Photos: C-Hawk
PostPosted: Thu Jul 05, 2007 10:42 am    Post subject: Reply with quote
Another site for info from Jim (jstates)
Islander
City/Region: Channel Islands Harbor
Vessel Name: Islander
Photos: Islander
PostPosted: Thu Jul 05, 2007 11:02 am    Post subject: Reply with quote
I just had some gel coat repair done on my 1990 22ft Cruiser, by our local C-Dory dealer at Channel Islands Harbor. Catalina Yacht Anchorage fixed me right up! It really is great having great local C-Dory support!
Ron
Islander
Post new topic   Reply to topic    The C-Brats Forum Index -> Documents All times are GMT - 5 Hours
Page generation time: 0.0426s (PHP: 67% - SQL: 33%) - SQL queries: 27 - GZIP disabled - Debug on
