I need a replacement part for my Orca door
skagitorca
City/Region: Sausalito, CA
Vessel Name: Dark Star
PostPosted: Mon Feb 16, 2004 2:22 pm    Post subject: I need a replacement part for my Orca door Reply with quote
Sorry if I am posting in the wrong place. The sliding door to my 27 foot short cabin Orca will not close; the gripping mechanism inside the edge of the door appears to have disintegrated and needs replacement. Can you (c dory) send me a replacement set? Thanks so much for your help.
PostPosted: Mon Feb 16, 2004 3:55 pm    Post subject: Whale Door Reply with quote
Sorry but this is not the site for the manufacturer, it's put together by a few hard working C-Dory owners and used by a lot of other lucky owners and fans. We know a lot about C-Dorys and someone may know something about the Orca. Good Luck....Take a look at the C-Dory!!
PostPosted: Mon Feb 16, 2004 3:59 pm    Post subject: SkagitOrca Door Reply with quote
http://www.westernboatshop.com/about-skagit-orca-boats.htm
Try these guys, they advertise the boat and can probably get you a door! There's a phone number on the home page.
skagitorca
PostPosted: Mon Feb 16, 2004 4:04 pm    Post subject: Reply with quote
Thanks for the reply. I believe C Dory purchased the Skagit Orca Line so . . . . I believe this *is* the proper venue. I will check out Western Boat and very much appreciate your lead.
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Mon Feb 16, 2004 4:49 pm    Post subject: Reply with quote
Hi Skagit Orca,
You are entirely correct that C-Dory has purchased the Skagit Orca and is now manufacturing them at the same C-Dory plant that manufactures the 24' C-Dory TomCat and the 25' C-Dory cruiser. Probably the best way for you to obtain help with your vessel would be to telephone the C-Dory Factory at 253-839-0222.
They apparently respond much better to phone calls than to e-mails.
As to the origin of this site. It was set up by one of your Calif. neighbors as a C-Dory owners group site and we certainly welcome all visitors.
I do hope that this helps you with your fine vessel.....there are a lot of them plying the waters of Northwestern Washington. CoolSmile
Dave S.
"Sea Shift"
C-Brat #16
skagitorca
PostPosted: Mon Feb 16, 2004 4:54 pm    Post subject: Reply with quote
thanks for the reply. I stand very humbly corrected.
Page generation time: 0.048s (PHP: 46% - SQL: 54%) - SQL queries: 19 - GZIP disabled - Debug on
