Swee Pea
Vessel Name: Swee Pea
Photos: Swee Pea
Posted: Tue Jan 09, 2007 2:08 am Post subject: Honda 5hp or Tohatsu/Nissan 6? |
Hate to bother you nice folks (can't sleep tonight/this AM). I've narrowed my choice for a dual purpose outboard - kicker/inflatable to either a 5HP Honda or a 6HP Tohatsu/Nissan, both in a 20" shaft. Have done a lot of searching and seems to be two schools of thought - never use a 20" shaft on a boat designed for a 15" shaft, or use a 20" shaft and don't worry. However, this advice is usually directed to larger boats. Many users of inflatables that use a 20" shaft report that using such a small engine, it will not have any dangerous effects - just won't function at optimal levels. Can still use a transom elevator to lift the motor 5" (a little expensive unless I build one myself) for the inflatable. Talked to the manufacturer of the transom elevator - should work fine.
Since I have trim tabs, will use the Mini Jacker for kicker attachment when not in use on the inflatable.
Now for comments on either motor. I know that alot of you do not like the Honda 5. Some dealers say it is due for a redesign due to plastic? flywheel. Other dealers say this puppy has been around for a long time and has proven itself. What say you? The Tohatsu/Nissan is looking good - better price, lighter weight, same warranty; too bad it isn't Honda grey. I am becoming way too anal these days.
Any thoughts/comments would be appreciated.
Swee Pea |
Moldy
Posted: Tue Jan 09, 2007 6:31 am Post subject: |
I had a 2005 Nissan 5 horse 4 stroke kicker and I really loved it!
Sold it with the boat only thing was being it is a one cylinder it does shake a bit but I didnt think it was a problem. The motor goes forever on fuel |
drjohn71a
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
Posted: Tue Jan 09, 2007 9:51 am Post subject: |
Swee Pea..... some magazine had a head to head evaluation of all the small outboards. I may have it at home.
I think the Nissan/Tohatsu was the same block as their 9 hp (or similar) model, detuned for the 5-6 hp, so was very heavy, but water cooled.
The Honda had alot of plusses, but it was air cooled, so louder, but much much lighter and easier to handle. The Honda had easier oil check access, but some thought the rubbery cover snap was hard to place.
Brent and Dixie use the Honda, and some friends of mine here use a Honda. I think you have to swivel for reverse. The Honda has a storage for spare shear pin and cotter also.
John |
Joined: 01 Mar 2005 Posts: 7481 City/Region: from island boy to desert dweller
Posted: Tue Jan 09, 2007 10:20 am Post subject: |
Dr. John, I think you may be thinking of the Honda 2 regarding the air-cooled and rotating the motor for reverse. We had a Honda 5 for a dinghy and found it to be a heavy, noisy, cold-blooded motor. The 5 is a single cylinder and vibrates quite a bit. Most owners have had problems with the shear pins and have bought the pins for the 8 hp and filed them down. We've had other Hondas and found them to be the best in their class... I think the 5 is definitely due for a makeover. Not meant to sound harsh, it just seems that the Honda 5 isn't up to their usual design/performance standards. My 2¢.
http://captnjim.blogspot.com/
drjohn71a
Photos: Tom-a-Hawk
Posted: Tue Jan 09, 2007 10:26 am Post subject: |
thanks, Jim. I was not sure what hp ratings the article was about. Glad you cleared that up! John |
Posted: Tue Jan 09, 2007 10:43 am Post subject: |
Journey On has a 10 hp Honda with a 20 " shaft, used as a trolling/get-me-home motor and for the dingy.
It's like all Hondas: heavy. Changing from the CD25 to the inflatable is done by hoist. I've often thought I should have gotten a Tohatsu, since it's about 20 lbs lighter. Get it from Defender (cheapest.) Also I'm going to have to raise the transom height. When the dingy gets up on plane, water is scooped up over the transom by the motor. Who makes a commercially avalable transom height increaser?
Boris |
Posted: Tue Jan 09, 2007 10:52 am Post subject: |
We've got a Merc 6HP on our Sailboat and it's a great engine. The instruction book is for both a Merc and Tohatsu, so I thought they were the same engine. Not sure about the Nissan connection?
K4KBA |
Swee Pea
Photos: Swee Pea
Posted: Tue Jan 09, 2007 11:01 am Post subject: Honda Tohatsu |
Thanks for the fast responses. The transom elevator is made by T&R Marine http://www.trmarine.com/cat.html They are a little pricey. Don't know if I can make one out of plywood. Will wait for the arrival of the Mercury inflatable.
Charlie, the Nissan connection is that evidently Tohatsu makes both Nissan and Mercury outboards in the small size. How small, I don't know, but the Tohatsu, Nissan, and Mercury 4 cyl 6 hp and below are all the same motors, just different paint and graphics.
Thanks again, and keep the input coming.
Love this site.
Swee Pea |
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
Posted: Tue Jan 09, 2007 12:02 pm Post subject: |
I'm thinking of buying an 8'10" Alaska Series inflatable (for the weight, to make it easier to get it on the roof). This would be the dinghy, not the sportboat.
I'm thinking of powering it with a 2.5 horse four-stroke Yamaha.
Would appreciate feedback on the Yamaha (and the Alaska Series dinghy.)
Thanks.
P.S. After I posted this I noticed that the 2.5 Yamaha is not available with a long shaft. That may be a problem. May have to go to the 4 hp. _________________ Doryman
M/V Lori Ann
Anacortes, WA
Posted: Tue Jan 09, 2007 9:30 pm Post subject: Re: Honda Tohatsu |
Swee Pea wrote: | Thanks for the fast responses. The transom elevator is made by T&R Marine http://www.trmarine.com/cat.html They are a little pricey. Don't know if I can make one out of plywood. Will wait for the arrival of the Mercury inflatable.
Love this site.
Swee Pea |
Thanks John, I think they make Kamashita, Doncarealota, and Kamakazie too!
charlie |
Wefings Dealer
Photos: Cruise Ship #4
Posted: Tue Jan 09, 2007 10:09 pm Post subject: |
We sell Honda and Nissan/Tohatsu as well as Suzuki. You cant go wrong with any one of them, but your wallet will remain thicker with the Tohatsu,you will get the longest warranty with Suzuki . The 9.8 Tohatsu is also the lightest in the class at around 84LBs for 20" shaft . If you move the motor around alot , thats a consideration. Just my 2 cents,
Marc _________________ Wefings Marine Website
Since 1909 |
C-WEED
Joined: 14 Mar 2004 Posts: 338 City/Region: New Brockton
State or Province: AL
Vessel Name: C-Weed
Photos: C-WEED
Posted: Tue Jan 09, 2007 10:56 pm Post subject: |
Swee Pea:
I would recommend a twin cylinder for smooth quiet operation and torque. Performance would be better for both the CD and the dink. I enjoy running the boat from the cockpit in hot weather. I don't know how most people move the motor to the dink. I would think one would pull close to shore (if possible) drop the dink. And step off and swap the motor over.
The tohatsu charging system is extra unless you get electric start. This option is about $150 from what I found. For my yamaha a charging rectifier was all of $30. Just plug it in, add two clamps and connect to either battery to charge. With a rope start kicker it is a nice back-up. Since you can putt-putt along at super economy sail boat speed why not charge the batteries too? Many a sail boat run to the Bahamas on 8 H.P when the wind won't blow.
With such a great looking boat you have, No motor would ever look as good as one that matches your main. A real package deal. If you ever sell her it would look better to the buyer, too. ($$$) Next year if you get anything but a Honda you won't remember what you spent the money on that you saved by buying the Tohatsu. But you will be reminded every time you see the engines on the stern which ever way you went.
Now is a good time to shop for a left over model at a discount. I found one out of state and had it shipped to my door for less than the sales tax would be. I didn't have to pay tax out of state.
One complaint of the Honda 5 is the carb jets getting gummed up very easily as they are so small. Resulting in balky operation unless ran weekly.
Check the RedFox website. He made an extention for an 8H.P. on his dink. Basically a couple boards thru bolted if I recall. Ask. if you don't see it posted.
Lori Ann: See the Red Fox website for information on the Yamaha 2.5. He loves his. _________________ Chris |
Jazzmanic
Photos: C-Dancer
Posted: Tue Jan 09, 2007 11:52 pm Post subject: |
Warren,
We bought the Alaska Series Dinghy at the Seattle Boat Show last year. I believe it was the 240 TDS model, which is 7'10" and 45 lbs. They are very well made boats but pricey. At 45 lbs, they are not too heavy to handle and we added the grizzly claw bottom for beaching on rocks and gravel.
You can see ours on top of the cabin in our signature picture.
As for Redfox, you can find his site here:
RedFox _________________ Peter & Caryn
Email: pjamero@gmail.com |
Swee Pea
Photos: Swee Pea
Posted: Wed Jan 10, 2007 7:12 am Post subject: |
To Marc at Wefings:
As a dealer and in your experience, what has been the track record of the Honda 5? What is your impression of the motor? And since you sell all, not wanting to go over a 6 hp, as a dealer, which motor would you recommned for my particular application?
How's that for putting someone on the spot?
I appreciate your honest input.
Swee Pea |
Doryman
Photos: Lori Ann
Posted: Wed Jan 10, 2007 1:36 pm Post subject: |
c-dancer wrote: | Warren,
RedFox |
Thanks. I found the RedFox site earlier but could not find any reference to his dinghy or the Yamaha motor for it.
Do you have a motor for your Alaska Series dinghy? If so, what is the make and hp, and what do you like/not about it?
Warren |
