davehogue555
State or Province: TX
C-Dory Model: R-21 Tug
Vessel Name: Soulmate
Photos: Soulmate
Posted: Mon Dec 25, 2006 5:36 pm Post subject: Embarrasing Question |
I've been on the water for 50 years. There's been several boats, from a 14' outboard to, for the last 21 years, a 20' Kayot with a 260 hp Mercruiser but all have had a "pointable prop". I have just bought a 2005 Ranger R21 Classic with a 30hp Yanmar diesel and I have never operated a fixed screw and rudder boat ( with the exception of 6 years in the Submarine Service). Any recomendations as to books to read or old posts on this forum to read before I put it in the water? Thanks!
Dave |
Posted: Mon Dec 25, 2006 6:10 pm Post subject: |
Since this site has been primary devoted to C-Dorys and since the C-Rangers are a bit new to the site, I doubt you'll find much in the way of relevant previous posts to answer your questions. There's some old salts here who can certainly help you out with specific questions. As for books, the old standard of Chapman Piloting:Seamanship and Small Boat Handling has extensive writing on how to handle all types of boats including single screw/rudder combo. _________________ Roger on Meant to be |
davehogue555
Photos: Soulmate
Posted: Mon Dec 25, 2006 6:32 pm Post subject: |
Just ordered Chapman Piloting.....Thanks |
Joined: 02 Nov 2003 Posts: 21373 City/Region: Pensacola
Posted: Mon Dec 25, 2006 7:24 pm Post subject: |
Congratulations on the C Ranger. I had the opportunity to one one for a few hours and they are very well behaved. If you get the thruster options, you can almost stand the boat on its head! Generally the thrust of the prop wash against the rudder is what kicks the stern around. In reverse the boat will "walk" one way--this is because the water is denser on the lower blade of the prop, than the top blade, thus it will kick the boat sideways. (I'll confess I am not posititive if the boat had right hand prop or not). Although the boat has a fair amount of windage, there is enough keel and boat in the water, that it does not blow around as easily as some of the outboard boats.
When backing the boat will start to one direction because of the prop walk effect, but you can either use a thruster, or put the rudder over the opposite way from the way the stern is turning and give a short burst ahead to swing the stern back to the direction you want. My experience was that the C Ranger 25 backed quite consistantly and was fairly easy to master. Good luck with the new boat--and welcome!
Get out and practice. In another post I mentioned putting a couple of fenders in the water, tide to a boat look, so they will keep a constant relationship to each other. Practice backing the boat, bringing the boat along side etc. First on a calm day, then when there is a little wind.
Boat docking (Close quarter maneuvering) by Charles T. Low is an escellent book on maneuvering both single and twin screw inboard boats. _________________ Bob Austin
Alok
Joined: 19 Mar 2005 Posts: 291 City/Region: League City
Photos: Top Cat
Posted: Mon Dec 25, 2006 9:18 pm Post subject: |
Dave:
My first boat was a single screw 33-foot trawler. In addition to the book Bob has mentioned above, I found "Dockmanship" by David Owen Bell helpful.
There were also a couple of useful chapters in "Getting started in Powerboating" by Bob Armstrong (you can probably read through them while sitting at your local bookstore- with your experience, its probably not worth buying the book).
Some things I learned as a new boater driving a single screw diesel (this is probably all old stuff for you):
I learned to use the wind and current as my friends...The flag on my boat was more than just a decoration...
I did not have a bow or stern thruster... I learned to turn while backing by first lining up the boat at the correct angle using a slight burst in forward gear, then backing the boat...(single screw power boats generally back like a brick)...
I learned to use spring lines a LOT when docking or coming alongside, and I learned to back out using a bow line when the wind was unfavorable (first go forward with the wheel turned towards the dock and a fender in place, then straighten the wheel and back off...). The C Ranger 21 is probably much easier to just push from the dock using hand-power, but is pleasing to see a single screw boat manuver gracefully!
I learned to walk to the stern and see good "water" coming from the exhaust as soon as I started the engine...
I also always added biocide to the diesel...some owner 10 years from now will thank you for having less sludge in the bottom of the tank.
The R-21 is a beautiful boat. Have a great time! _________________ Alok
C-Dory Tomcat (Topcat) sold January 2012 |
Sawdust
Joined: 01 Nov 2003 Posts: 1400 City/Region: Oak Harbor
C-Dory Model: 22 Classic
Photos: C-Salt
Posted: Mon Dec 25, 2006 9:50 pm Post subject: |
The Ranger 21 is a great handling boat. Large rudder well aft, and she turns on a dime. She will back either direction (not always true with a single screw), and very well balanced. Good choice.
Dusty |
davehogue555
Photos: Soulmate
Posted: Tue Dec 26, 2006 7:27 pm Post subject: |
Thanks for the replies..........got several books on order now, can't wait to get her in the water. Think I'll also get some 10"X26" fenders, just in case!
Dave |
Posted: Tue Dec 26, 2006 8:22 pm Post subject: |
Sawdust wrote: | The Ranger 21 is a great handling boat. Large rudder well aft, and she turns on a dime. She will back either direction (not always true with a single screw), and very well balanced. Good choice.
Dusty |
Dave, Dusty is right on (as usual). That Ranger 21 backs in either direction because of the big rudder. As you get a little sternway, the water action on the rudder has a greater effect than the prop does and it will swing the stern in either direction.
I know that first hand because when I was on my Guided Missile Destroyer in the early '80s (1980's for those of you who will say you didn't have engines on sailing vessels!!) we did it and to stop had to drop the anchor in the harbor next to the pier. Unfortunately, it was the wrong anchor and it was dropped ON the pier, right on top of a phone booth...
Fortunately I was not the OOD (Officer of the Deck) but I was the Chief Engineer and had to figure out how to get the anchor out of the phone booth and back into the water....
K4KBA |
Sneaks
Joined: 06 Jun 2004 Posts: 2020 City/Region: San Diego (Encinitas)
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
Posted: Tue Dec 26, 2006 8:54 pm Post subject: |
Captains Choice wrote: | I know that first hand because when I was on my Guided Missile Destroyer in the early '80s (1980's for those of you who will say you didn't have engines on sailing vessels!!) we did it and to stop had to drop the anchor in the harbor next to the pier. Unfortunately, it was the wrong anchor and it was dropped ON the pier, right on top of a phone booth... Charlie |
Sea story time, Charlie - and Dave will definitely relate: After torpedo tests, our 425 ft. nuclear submarine approached the Christiansted, BWI pier unaided by tug or thrusters, with the skipper on the bridge and yours truly down below as diving officer. On final approach, someone in engineering accidentally shut the valve supplying hydraulics to the rudder. Fortunately the rudder was amidships but it made for a few pretty exciting moments and a chance for the skipper to demonstrate some pretty awesome seamanship.
For the non-submariners, you can get an idea of what it's like in a sub by putting a blindfold on while sitting at the C-Dory helm and having someone else talk you into a slip with rudder and engine control commands only. Try it some time....
Don |
davehogue555
Photos: Soulmate
Posted: Tue Dec 26, 2006 11:26 pm Post subject: |
I started out on the diesel boats (SS303) in New London, Conn. and we routinely steamed up the Thames River and tied up to one of the piers at the Sub Base without the aid of tugs or anything else. The combination of river flow, tide and wind sometimes made it a challenge to twist the boat to line up with your assigned place and then get up next to the pier. I stood maneuvering watch helmsman watches and was one busy dude. I remember approaching the mouth of the Thames going home one time and the railroad drawbridge across the river had a derailed train on it...... couldn't open for us, so we flooded down till the deck was awash and went on in under it. A little off topic here but I can't resist sea stories!
Dave |
cmdnav
Posted: Tue Dec 26, 2006 11:56 pm Post subject: |
Hey Dave congratulations on your new boat,
Your question is a good one. Far better to prepare for handling your new vessel ahead of time than through the expensive "school of hard knocks". One thing I would recommend is be generous with your fenders. Even the best boat drivers will have an occasional "oops". Far better to bounce off a good sized fender than your shiny new gelcoat. It always amuses me to see an expensive boat approaching with undersized Walmart fenders.
Although not a book, a resource that I have recommended for some of my students is the Stentec Motorboat Simulator for the PC.
http://www.stentec.com/motorboatsimulator_i/
It is a nice method to practice some of your dockside skills, especially during the too-long off seasons. They model inboard single and twin boats and even include bow thrusters. Just remember this software was developed in the Netherlands so "red, right, returning" does not apply.
Enjoy,
Chris |
Sneaks
Vessel Name: C-Brat
Posted: Tue Dec 26, 2006 11:59 pm Post subject: |
davehogue555 wrote: | A little off topic here but I can't resist sea stories!
Dave |
Hey, you started the thread and you're satisfied with the answers, so why not sit back and share a few.
SS303? I might have run into you down on Bank Street, Dave. Kind of an old boat but not as old as my dad's. He's the big guy closest to the bow.
 _________________ Mary & Don Anderson
Brat #483
"C-Brat" 1993 C-16 angler/50 hp |
Joined: 23 Oct 2003 Posts: 5328 City/Region: Warrenton
Posted: Wed Dec 27, 2006 12:05 am Post subject: |
Quote: | ...so why not sit back and share a few. |
By all means, please. As much as I enjoy reading this stuff and seeing pics like Don's, it is a pretty safe bet that a bunch of us young fellers do. Too cool - thanks. _________________ TyBoo Mike
Sold: 1987 22' Cruiser |
davehogue555
Photos: Soulmate
Posted: Fri Dec 29, 2006 9:52 am Post subject: |
Now, that is an old boat! Any idea of the year that picture was made? |
davehogue555
Photos: Soulmate
Posted: Fri Dec 29, 2006 9:57 am Post subject: |
I ordered the download version of Motorboat Simulator. Had no idea how much 29,95 Euro was till this morning when the charge showed up......$41 US....not bad I guess. |
