Posi-Lock Connectors
Casey
City/Region: The Villages(FL)
Vessel Name: "Dessert 1st"
Photos: Dessert 1st
PostPosted: Sun Dec 24, 2006 10:45 am    Post subject: Posi-Lock Connectors Reply with quote
Sometimes an electrical installation is simple, and other times it requires a electrical connection that isn't very handy. Like most, I've used crimp connectors, wire twists and tape, and sometimes even solder to make a good connection.
I recently ran across Posi-Lock Connectors ( http://www.posi-lock.com/ ). I haven't tried them yet - but plan to. Here's an evaluation from a motorcycle site ( http://www.webbikeworld.com/Reviewed-motorcycle-products/posi-lock/ ) that rated them highly; and motorcycles present a pretty challenging environment for electrical stuff (mega vibration, moisture, cramped wiring situations, etc.).
Has anyone tried Posi-Locks?
Casey
C-Dory Naknek
PostPosted: Sun Dec 24, 2006 12:39 pm    Post subject: Reply with quote
Casey-
Haven't tried these, but, assuming they're as good as advertised, two comments come to mind.
They may be a bit bulky around electrical panels and some connectors, where the space is often pretty tight.
The factory packages are $30 for 30-45 connectors, depending on the size. Purchasing a usable asssortment would be prohibitive for the average individual. Hopefully, one would be able to find a auto, marine, or motorcycle shop that would stock them and sell them individually.
Also, I'm still wondering how salt water would affect them if allowed to get down into the interior of the connectors. Perhaps a dielectric grease could be added to the junction area.
Joe.
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
PostPosted: Sun Dec 24, 2006 1:11 pm    Post subject: Reply with quote
Sea Wolf wrote:
The factory packages are $30 for 30-45 connectors, depending on the size. Purchasing a usable asssortment would be prohibitive for the average individual.Hopefully, one would be able to find a auto, marine, or motorcycle shop th at would stock them and sell them individually.
I may be suffering from OldTimers, Joe, but I think Walmart carries them in small quantities. I found them in the auto parts area but not in the normal connectors spot. Our Walmart had them near the RV section. Bought a few but haven't tried them yet. If I remember correctly, they were in packages of two or three and in various sizes.
Mary & Don Anderson
Brat #483
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Sun Dec 24, 2006 2:54 pm    Post subject: Reply with quote
Marine connectors are usually nickel plated, automotive fastiners are not...same with marine quality wire...it costs more but does not corrode like copper (automotive) core wire.
Anytime a connector is used a film of silicone grease should be applied...(not silicone sealer) It is sold at West Marine but is really expensive...if you can catch the phone guy or the cable guy in your backyard you can always get them to give it to you fer free,....same stuff..anytime they make a connection at the pole they use silicone grease...keeps out water and insures a corrosion free connection. They get the stuff in 1 oz. tubes and only use a tiny bit...my guy gave me a handfull of the tubes.
Joel
SEA2PO
Dreamer
Photos: Dreamer
PostPosted: Sun Dec 24, 2006 2:59 pm    Post subject: Reply with quote
A marine electrician that I used suggested Waytek wire as a source for all things electrical. I ordered and used some grease filled crimp-on connectors for light instrument connections. See bottom of this page.
http://order.waytekwire.com/IMAGES/M37/catalog/219_026.pdf
They are very small and compact, easily installed with needle nose pliers.
Their catalogue has many boat applicable items. They have an electrical tape that seals like shrink wrap for waterproof connectors.
Dreamer- Sold 25 Feb. 2013
SEA3PO
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Sun Dec 24, 2006 3:07 pm    Post subject: Reply with quote
Normally I don't like crimp-on connectors......but I bought some of those from West Marine and they worked super... sometimes you can't solder the connection...
I bought a tiny propane soldering iron at West Marine...it is filled like a cigarette lighter and is about the size of a fat ink pen....works well and perfect for use onboard... kinda expensive but well worth it... I also bought some shrink tubing at Fry's....lots of different sizes and in long tubes...
Joel
SEA3PO
PostPosted: Sun Dec 24, 2006 3:18 pm    Post subject: Reply with quote
I drive mixer truck for cadman in seattle and as you can imagine the trucks see a lot of mud and water on the road and at the plant. our mechanic uses a ele. grease that comes in a spray can. has a long straw on one end and you just spray in to the connector before inserting the wires. I do not know the name of the product or were he gets it but will find out after my trip.
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Sun Dec 24, 2006 4:09 pm    Post subject: Reply with quote
You can get small amounts of silicone grease in the plumbing dept at Home Depot, it is used for faucets, etc. and comes in about a 1oz. can. Any plumbing supplier should have it.
Patti and Barry
formerly C-Cakes, now
rving around N. America
PostPosted: Mon Dec 25, 2006 8:29 pm    Post subject: Reply with quote
Agree with silicone grease--and there are many less expensive sources than WM.
Crimping is the proper way on a boat--not soldering. Soldering, unless well supported leaves a brittle connection (I really like soldering, but not on boat wiring). Soldering is generally not to ABYC standards.
Crimping should be done with quality ratchet crimpers, which catch both the wire and the insullation. The best connectors are heat shrink, adhesive filled. These rarely if ever fail when done properly. Agree that all boating wire and connectors should be tinned.
I carry crimpers on the boat, along with an assortment of connectors of all sizes and types. Not sure that I see a reason for a diffrent connector than the standard.
PostPosted: Mon Dec 25, 2006 11:04 pm    Post subject: Reply with quote
Here's a product of synthetic lubricant that works as a diaelectric grease and water proof lubricant: SUPER LUBE.
I use the paste like clear lubricant in the left two tubes.
We used in in high vacuum work in school. The silicone based grease has no vapor pressure, hence doesn't dry out. Worked great on racing sailboats, such as on suction bailers, and also on powerboats, such as on propshafts.
Works great in plumbing washers and valves. Appears harmless to most rubber and neoprene like products.
It can be bought in most hardware stores.
The big calking gun sized tube lasts years for about $7-8 as I remember.
Joe.
james
City/Region: CRYSTAL RIVER
Vessel Name: COOL CHANGE
Photos: COOL CHANGE
PostPosted: Tue Dec 26, 2006 11:18 am    Post subject: Reply with quote
I have found in most cases I use a wire nut( what I call it) filled with liquid tape. I cannot imagine a better connection for most applications.
built in stress relief, VERY tight , and impervious to moisture, vibration.
James
"Beware of the man with no weaknesses, he is not to be trusted." Lin Yutang, The Importance of Living.
PostPosted: Tue Dec 26, 2006 2:34 pm    Post subject: Reply with quote
For what it is worth ABYC does not allow the use of Wire nuts--and most surveyors will make you remove them and redo the splices.
james
Photos: COOL CHANGE
PostPosted: Wed Dec 27, 2006 2:54 pm    Post subject: Reply with quote
Interesting, maybe because most do not fill them with liquid electric tape.
I would not use them either if not for the hermetically sealing propertys of the the liq. tape.
I would like for someone to explain to me the deficiencies of such a electric connection.
James
james
Photos: COOL CHANGE
PostPosted: Wed Dec 27, 2006 3:01 pm    Post subject: Reply with quote
of course, if I need a inline joint, I will reluctantly use a butt connection, then back fill the openings with liquid tape also.
James
PostPosted: Wed Dec 27, 2006 4:53 pm    Post subject: Reply with quote
A wire nut is often used in household wiring, where there is solid wire. Boat wiring is fine stranded (finer than automotive for the most part). There is less chance of both a good bite by the spiral spring in the wire nut, and of comming loose with vibration with a wire nut. The wire nut uses the wire to support the splice--a proper crimp uses the insullation to support the wire and splice. Liquide tape is good--but heat shrink with adhesive is better--it gives a better bond and better support.
Wire nuts for houses.
Crimped connectors for boats.
Page generation time: 0.0456s (PHP: 67% - SQL: 33%) - SQL queries: 28 - GZIP disabled - Debug on
